04-11-2022, 07:10 PM | #1 |
Composite Decking
Does anybody know if you can paint composite decking?
If so, has anybody done it? And what product did you use? The decking I have is about 15 years old. I regretted the color of the decking as soon as it was put down. It would be nice to be able to change color. Thanks for any information you may have. |
04-11-2022, 08:22 PM | #2 |
Hi:
Google rustoleum rocksolid composite deck refresh. I haven’t tried it but it might be what you are looking for. ABOUT COMPOSITE DECK REFRESH RockSolid® Composite Deck Refresh Toner is an exceptional water-base exterior toner designed to refresh the color and restore the finish on faded composite wood decks. It provides protection against water damage, UV graying and mildew. It is easy to use, dries fast and cleans up quickly with water. One coat application Protects against UV damage Resists Mold & Mildew growth Provides superior water repellency with hydrophobic Properties Covers up to 300 sq. ft. FOR BEST RESULTS Be sure to choose the tone that best matches the original composite deck color. AVAILABLE SIZES 1 Gallon FIND Good |
The Following User Says Thank You to secondcurve For This Useful Post: | ||
eillac@dow (04-13-2022) |
04-12-2022, 10:45 AM | #3 |
Which composite?
Early forms of Trex could be... current forms cannot be. |
04-13-2022, 04:35 AM | #4 |
Thank you John and Secondcurve for your responses.
I’m not really sure what type of composite decking it is. Not even sure if we have the paperwork from when we purchased it. I’ll have to check. Thank you very much for the information that you provided on the RockSolid It sounds good but it does say you should probably stay as close to the original color as possible. Unfortunately The color I have a similar to a brick color and I was looking to maybe change the color to something in the gray family. Appreciate your thoughts and comments. |
The Following User Says Thank You to eillac@dow For This Useful Post: | ||
secondcurve (04-16-2022) |
04-13-2022, 06:50 AM | #5 | |
The Following User Says Thank You to tis For This Useful Post: | ||
eillac@dow (04-18-2022) |
04-13-2022, 08:28 PM | #6 |
Mold shouldn't be able to attach itself to a capped composite... and bleach will weaken the plastic binding material that is the major component of the board.
04-14-2022, 07:01 AM | #7 |
Well, we certainly had it, but then again mold can attach it self to anything. Maybe the bleach did weaken it but at least it looked better.
04-14-2022, 08:33 AM | #8 | |
The Following User Says Thank You to codeman671 For This Useful Post: | ||
04-14-2022, 05:31 PM | #9 | |
It turns black when it runs out of organic matter to consumer or dries due to a lack of moisture. The manufacturer suggestion is to wash the deck twice per year... once to remove pollen... the second to remove leaves/etc. Spots/areas that are not responding to just hose pressure should be brushed with a soft bristle, and then rinsed. The ''wash'' may be no more than rinsing off with the hose if no areas of concern are noted. That process also creates the situation where the owner will inspect the deck twice per year and note any situation that might need a repair. |
04-14-2022, 05:44 PM | #10 | |
04-14-2022, 06:16 PM | #11 |
The Azek should be washed twice a year also. Though mold cannot eat it either, mold will appear whenever spores and moisture present the condition for the mold to grow then die.
Azek will scratch easier than a composite... and care needs to be taken on certain products - things like sunscreen/lotion - getting on its surface. But like a composite deck, using a shovel with a plastic edge... and keeping it clean should avoid most of the negatives. Its greatest use was as a dock material. Very light - more like cedar - compared to PT or composite options. They even make a new version called MAX that can handle a two foot on center substructure here in New England. And due to width options (4/6/8), it can make a very dramatic statement without a lot of additional cost. |
04-15-2022, 06:51 AM | #12 | |
04-15-2022, 05:03 PM | #13 |
Depending on the line of Azek, the color should go all the way through.
The maintenance for composite/PVC is roughly the same... wash and inspect. The products should last a lifetime... or in Azek PVC's case several lifetimes. The inspection is mostly due to issues that might arise with the substructure. |
04-16-2022, 09:40 AM | #14 |
Has anybody used Endeck pac decking?
04-16-2022, 12:25 PM | #15 |
Sorry, I have never heard of that name locally.
Is like Azek or ZURI? |
04-16-2022, 01:27 PM | #16 |
Sorry, PVC. out of Florida
04-16-2022, 01:42 PM | #17 |
AZEK and ZURI are both PVC.
ZURI has a PVC core with a laminated photo-realistic print and then top coated with a hard layer of acrylic to resist scratching. My guess is that Endeck is possibly like the ZURI. |
04-16-2022, 03:27 PM | #18 |
Back to painting
Our house has a composite board deck from the '90s. Not sure what brand as it was installed by the previous owner. My wife went at it with Behr solid deck stain. She cleaned thoroughly then two coats. Although I hate the color (battleship gray). It has held up since then. Has no roof over it and gets full southern sun. I have been quite surprised.
The Following User Says Thank You to bobkatfly For This Useful Post: | ||
04-16-2022, 05:43 PM | #19 |
The 90s most probably was Trex Generation 1.
That composite was uncapped, and expected to be stained. Trex has problems selling it, as it required the same maintenance as PT/Cedar decking but at a premium price. I've seen it on some older decks, but can no longer get that product. |
