Old 03-07-2021, 10:18 AM   #1
Default Septic Service ?
I need to have my septic tank pumped this summer, and looking for recommendations and pricing ? When I purchaed house 3 yrs ago the seller had the tank pumped at that time.
FYI, I have a 3 bedroom size tank, only two members live at the house.
I live in the Gilford area.
Thanks !
Old 03-07-2021, 10:45 AM   #2
camp guy
camp guy's Avatar
Default Septic service
Have you considered calling the company that pumped it out at the time you bought the house?
Old 03-07-2021, 12:07 PM   #3
With only 2 in the house and a modern 3 BR system you should be good for 5 or 6 years.
The Following 2 Users Say Thank You to Slickcraft For This Useful Post:
Biggd (03-07-2021), JEEPONLY (03-07-2021)
Old 03-07-2021, 01:02 PM   #4
TheTimeTraveler
When I had my septic system put in my installer told me that if I routinely pumped it every other year then it would last a lifetime. And I have.
Now, there are other factors to keep in mind; Do you have a garbage disposal and do you use it routinely? A garbage disposal seriously taxes the septic system.
Also, do you have a dishwasher and clothes washer?
I do have a garbage disposal but don't use it other to clean the small crumbs out of the sink after a meal. I use the trash for 99% of my garbage.
Treat your system well and it will treat you well.
Old 03-07-2021, 01:40 PM   #5
TheProfessor
Mine hasn't been pumped in 10 years.
The last time pumped I was advised that mine was "clean".
Strict rules as to what goes into system.
How old is your system ?
Do you have a copy of system on paper?
The town and the state should have a copy.
If all was designed and installed properly. Shouldn't have issues.
But of course, if it makes you satisfied, have it pumped.
Lamprey is one company that does pumping.
LINK
Old 03-07-2021, 01:47 PM   #6
We went quite a while without a pumping and everything looked good, but for a couple hundred bucks every few years, it's cheap preventative maintenance.
Old 03-07-2021, 02:26 PM   #7
FlyingScot
And it's better for the lake! Unmaintained septic systems are a significant source of nutrients that promote plant growth, cloudy water, etc
barefootbay (03-07-2021)
Old 03-07-2021, 02:32 PM   #8
Used Roswell for the last 15 years or so. We pump every 3rd spring
Old 03-07-2021, 02:41 PM   #9
We know it is 3 BR. We don't know if it is "modern". Yes, I'd call the company that did it before--they likely have a recommendation for a pumping schedule, although your use may be different than the previous owner. Tank size isn't necessarily related to how many BR, usually yes, but as you go back in time, tanks were smaller. I have one 4 BR with a 750 gallon tank and another 4 br with 1000 gallon tank because that was the requirement at the time. Most "modern" systems have a 1250 gallon tank. If you do all the chores first thing in the morning, showers, dishwasher, laundry, cooking etc you put a heavier flow through the tank and there is less time for solids to settle and the leach field may be under more pressure. Same applies if you've been at home all year instead of using water at work on a sewer system. BTW, those disinfectant wipes that say "flushable" on the container will clog both a septic and a sewer system Do not flush them.
The company that pumped previously will likely have a location map for the cover to be dug up, saving time for a search. If you do the digging yourself you may save $100.
Old 03-07-2021, 03:19 PM   #10
Woody38
Default No pumpout
When we lived on the Cape there was a problem with the septic. It was pumped and they told me to use Rid-X and it would be fine. Did that and it was perfect when we sold it years later. Advance forward to today. We have been in this house for 15 years and the septic was pumped and checked 2 years before we bought. Since then I have put Rid-X in every 3 months. There are only 2 of us in the house. Garbage disposable is used only for leftovers. We have a clothes washer and use HD detergent. Dishwasher is run approximately 3 x weekly. We have not had a problem with the system in that time. Last time I used the contractor Rid-X
_______________________________________
Old 03-07-2021, 03:50 PM   #11
MeredithMan
MeredithMan's Avatar
Default Every other year...
...Rule of thumb is to have it pumped every other year. We've done that with several septic-system homes over the years and it has served us well. Also, make sure they check the Distribution Box, (D-Box), each time you have it pumped if it is a system that is over 10 years old. They tend to fail beginning around 15 years old.
When we sold our house in MA in 2019, the D-Box on that house had to be replaced as a result of the Title V inspection...about an $1800 repair out of our pocket. When we bought the house in Bedford shortly thereafter, I had the septic people inspect the D-Box on the place we were buying and it was on the verge of failure, so the sellers had to cough up the $1800 to replace that one. Both houses were about 17 years old.
We use Lamprey for the Meredith house. Very good to deal with. I think they charge us $550-600.00...somewhere in that range, for a 2500 gal tank.
Old 03-07-2021, 04:20 PM   #12
Stilljester
We've always had great service from DJ’s septic, we are on a similar 3 yr pump-out schedule.
P: +1 603-569-5286
Web: http://www.djsseptic.net/
Stilljester is offline   Reply With Quote
Old 03-07-2021, 05:09 PM   #13
Thanks !
I would say you're good for at least 5 years.
Old 03-07-2021, 05:30 PM   #14
Default Gosse
Gosse Septic Services in Barnstead. 603-269-3441
We're have used them since around 15 yrs. Highly recommend.
Old 03-07-2021, 06:03 PM   #15
Yes we have used Gosse here in West Alton and agree on the good service. They do not list Gilford as part of their service area but probably would go there.
https://gosseseptic.com/
Alan
Old 03-07-2021, 06:04 PM   #16
P: +1 603-569-5286
Same here!
Old 03-08-2021, 12:18 AM   #17
DesertDweller
We were told every three years so we have stuck to that schedule. We use Lamprey. Nice people.
This page was generated in 0.10688 seconds
