I finally got here to open up our house on Sleeper’s Island. Trying to get water up and running, but we have had a break in a 1/2 copper line from freezing (first time that’s ever happened). This line just goes to a main floor toilet, but there is no valve to shut off the line, so we can’t turn on the water. Does anyone have suggestions for someone who could fix this, even better if it could be done today?? Left a message with Island services, looking for additional options. TIA!
Call Archie at 603-387-3168
He is our favorite over the years! |
#3 | |
#4 | |
https://www.lowes.com/pd/SharkBite-1...ing/1000182685 https://www.lowes.com/pd/SharkBite-1...ing/1000182685 https://www.lowes.com/pd/BrassCraft-...tter/999903185 |
What're the thoughts on quick connect fittings today? Used to be that they should only be used temporarily or for exposed applications.
Sent from my Moto G (5S) Plus using Tapatalk |
Use one of these... they're pretty simple!
https://www.lowes.com/pd/SharkBite-1...ing/1000182579 |
This video is what I think you might want to consider. It is code compliant and easy to do.
#9 | |
Good luck! Steve |
any opinions if this approach is good for a situation where camp is up on piers, pipes are exposed to freezing temps. Sure the pipes are drained via gravity but a little bit of water, a little bit of plastic and freezing temps make me think they may not stand up too long.
#11 | |
#12 | |
Sent from my iPad using Tapatalk |
#13 | |
This is his cell#. He has a Baja outlaw on the water on Long Island. It's set up for Plumbing service calls and rapid response to island properties on Winnipesaukee. http://bellemoreplumbing.com |
#14 | |
#15 | |
They may not yet be open, but I bet if you ask around, you'll find many islanders have developed some handy skills. You might also be surprised at the parts inventory that exists in those sheds behind the camp, as well as specialty tools. I had a boat sink at the dock once (pinholes in the bellows) and shortly after we arrived a friend showed up with a jack intended to level his boat house, and a couple of extra pumps.. We lifted it to gunwales at water level and had a drink while we watched the pumps work. Easy. Who knew? |
Any modern updates for this? Leaking how water tank and very ageing pump/pressure tank on Barndoor Island. Looking for a plumber with a boat. I don't really want to put a HW tank leaking rust in my boat :-)
#17 | |
The downside is you need the power capability in your electric box to run this unless you use natural or bottled gas. Also they are known for needing replacement around the 10 year mark. |
Never mind. They use a ton of power. I'm already out of breaker slots and the breaker panel is already in a non code place
#19 | |
With regards to shark bites, worlds greatest invention for those of us who suck a soldering with the added benefits that: 1) you can use them to go from copper to PVC or vice versa ; and 2) you can easily disconnect them (if they are in an accessible location) to drain the pipe. The only thing that might be better is the compression tool that plumbers are using now to avoid soldering but, the issue with that is that it is far to expensive for a homeowner. |
#20 |
Moderator
I have to add that after we had renovations to our house we found that two new compression joints in the basement were dripping and had to be redone. Six years ago I put in eight Sharkbites myself to connect pex to copper and none of them ever dripped and are working perfectly.
