Old 04-19-2018, 02:02 PM   #1
Dave M
Default Septic System ?
Need info on septic system in Moultonborough. My understanding is they go by the number of bedrooms for the size of system. Also they define a bedroom that has a closet. If you don't have closets in the bedrooms how does that work for the septic system. Is it still the number of bedrooms.
Thanks Dave M
Old 04-19-2018, 04:03 PM   #2
MeredithMan
MeredithMan's Avatar
Default I believe that is true...
...when we were looking to buy back in 2012, we came very close to putting an offer on a place in Moultonboro. It was a great house, great location, new construction, but it was listed as a two-bedroom septic. Master BR was on first floor, and 3 other "bedrooms" on the 2nd floor. However, only 1 of the "bedrooms", was a true "bedroom", as it had a closet. The other two rooms did not have closets, so they were technically not "bedrooms". I suppose you could have used them as a home office and sewing room or something, but they were clearly "bedrooms".
We decided to pass due to the 2-bedroom septic specification for what appeared to be a 4 bedroom house. I guess it didn't matter much, as someone came along right behind us and bought it!
Old 04-19-2018, 05:39 PM   #3
Our situation was a bit reversed. When we built the new house in 2010, we had the septic system sized for five bedrooms, even though two of the five would be used for sleeping (when family comes to visit) but had no closets and thus were "utility rooms." The windows were sized and positioned for emergency egress purposes, as required for bedroom purposes, and one room since has acquired a free-standing closet ("wardrobe," I guess it would be called). I would think that instead of squeaking past legal septic requirements it would be more important to be sure that septic capacity is appropriate for actual use of the house. An undersized system, relative to use, is asking for trouble at some point.
Old 04-19-2018, 06:26 PM   #4
TheTimeTraveler
If possible always engineer and build a larger system than code actually requires so that if you decide to add on or sell you can get your project done without a lot of hassle...... Codes are revised over time so it can make upgrading to a newer system to be very cost prohibited (especially if you are dealing with ledge or near wetlands).
Also, ALWAYS design your system to be compatible with the use of a garbage disposal, even if you don't use a garbage disposal. Subsequent buyers or user usually do want a garbage disposal.
A new septic system should be pumped at least every other year and it will provide a lifetime of worry free use.
Old 04-20-2018, 10:28 PM   #5
FlyingScot
Second all of the above--it's a serious thing for both your family and the health of the lake. Like MM, we passed on a 4 bedroom house with a 2 bedroom septic. An undersized or unmaintained system is just a time bomb waiting to go off on a weekend with lots of friends/family up to visit.
Plus, septic rules in general are likely to get tougher over time, so even if you do skate by without incident, that introduces financial exposure when someday you try to sell.
Lamprey Septic has been great with the house we did end up buying.
Old 04-21-2018, 06:00 AM   #6
The whole thing doesn't make a lot of sense anyway. I know somebody who had several adults and 9 kids at a one bedroom camp with a loft area. I am sure it had a small septic system. The number of bedrooms doesn't have anything to do with how much the the septic is used. But I guess you can't control the number of people in a house so how else other than bedrooms would you figure what you need? I don't know why anybody would want to put in a smaller septic system, other than the lot is too small for the size they want.
Old 04-21-2018, 08:30 AM   #7
swnoel
What's more important is if there is area large enough to accommodate a larger system. A 2 bedroom system can clearly handle 3 bedrooms! It is assumed there will be 2 people per bedroom!
Old 04-21-2018, 08:38 AM   #8
I bought a home with a 2 bedroom septic. It's a second home so it only gets used on weekends and vacations. It actually has 4 bedrooms but the onther two rooms don't have closets. Some weekends we can have as many as 12 people in the house but most of the time only two bedrooms are used. It's legally only a 2 bedroom house so if we ever sell that's what it has to be listed at.
This page was generated in 0.10512 seconds
