Old 06-27-2016, 02:14 PM   #1
CaptT820
Default Rock Relocation
I will start this post with the fact that I know a lot of the DES regulations in relation to removal or relocation of anything relating to public waterways, including Lake Winnipesaukee. I have yet to find anything regulatory relating to my case, so if anyone can shed some light on this, I'd appreciate it.
We are looking to properly remove of several significant rocks off our shore that were placed there during the previous homeowner's tenure. The rocks are clearly there by manmade occurances and are therefore not natural by any means. The previous homeowner created a submerged rock structure on which to anchor their wooden dock. The dock is long gone, some posts are submerged and all of the rocks are still there. The rocks inhibit full access to our dock. Does this require a permit to relocate the rocks, as the rocks are not in their natural state, or can we just move them?
I know it seems like we need permits to do everything these days, but I figured I'd throw it out there for discussion.
Old 06-27-2016, 10:32 PM   #2
secondcurve
How do you plan to move the rocks? Heavy equipment?
Old 06-27-2016, 11:09 PM   #3
Default Call your contractor
Most contractors are very familiar with the regs and can tell you quickly whether your job needs a permit. The resident expert on this forum is "Shore Things" (DES), so watch for her post. Or just call DES. They talk to everybody for free. Most permits also go through your local Conservation Commission. Since they usually meet monthly, a permit that goes through them is often on hold for a month or two until their next meeting. Not a big deal since many contractors are backlogged that far at this time of year.
Old 06-28-2016, 06:29 AM   #4
winnipiseogee
I'm not sure about the regs but I can share my experience. We had a home on the lake where a previous owner had built a half ass platform deck out over the water. To do so he had similarly made a big pile of rocks. under the deck. As you can imagine the ice flow each year significantly damaged the deck.
We wanted to remove the deck and the rocks because it covered a portion of our sandy beach. We hired a reasonably respected contractor to get the permits and were ultimately told that we could continually receive permits for replacing the deck but we would not get a permit to remove it.
2 years later the owner of one of the largest most respected waterfront contractors told me I was dumb to apply for the permit. Nothing I wanted to do would have require a barge or heavy equipment. He said I could have removed it all and had DES shown up they might have said I was "wrong" to do so but there was 0% change they'd have me rebuild the artificially made structure.
Old 06-28-2016, 07:19 PM   #5
CaptT820
Default Equipment for Rock removal
SecondCurve- I have tossed around a lot of ideas on how to remove the rocks and some form of buoyancy system seems to be the choice that is cheapest. To move a 500 pound rock (average largest rock we have) you only need 8 cubic feet of air buoyancy, so I was thinking some sort of PVC raft style system may work and then lift the rocks individually into deeper water.
I would love to avoid getting large equipment involved due to the cost if nothing else, albeit it would be the fastest and most effective way to deal with the problem. I am still kicking around solutions.
Old 06-28-2016, 07:31 PM   #6
secondcurve
More importantly if you stay away from the heavy equipment you should be safe doing it yourself especially since these rocks were placed there by the previous owner. Good luck.
The Following User Says Thank You to secondcurve For This Useful Post:
CaptT820 (06-29-2016)
Old 06-29-2016, 04:18 PM   #7
depasseg
You might find this thread helpful:
http://www.winnipesaukee.com/forums/...ad.php?t=19843
depasseg is offline   Reply With Quote
Old 06-29-2016, 05:06 PM   #8
songkrai
I think that Taylor Rental has a submergible backhoe.
Old 07-05-2016, 12:33 PM   #9
Onshore
Yes you need a Wetlands permit to relocate rocks within public submerged lands. and yes if they were placed there by a previous owner you should have no issues obtaining the permit that is required.
The Following User Says Thank You to Onshore For This Useful Post:
CaptT820 (07-21-2016)
This page was generated in 0.08613 seconds
