Old 07-08-2007, 04:04 PM   #1
Default Water temp readings
Just happened to notice that the Black Cat web cam says the water is 67.5, while the Lakeport Dam- State of NH's reading from this website says it is 70. Methinks 67.5 is correct after measuring myself with a good qualty thermometer and based on feel. Heck, it feels too cold today to be 70. 70 is a relatively warm temp, and a warm temp, it is not.
Is this some type of revenue-generating tourist trap foisted on us by our Blue-New Hampshire, Democratically controlled state goverment who are willing to compromise their professional political dignity just so's more tourists will drive here from anywhere, or what?
So, how come the State's reading is too high? Is there a temperature detective in the house? How.....who.....how.... are we the residents and visiters of NH supposed to believe?
Old 07-08-2007, 07:28 PM   #2
JTA
JTA's Avatar
Default Southern waters
Black Cat is in the north and the Lakeport dam is in the south. Everyone knows that southern waters are warmer than northern. Give the State a break. Not everything is a conspiracy (unless the statistics are controlled by the Fed).
Old 07-08-2007, 07:48 PM   #3
This one's easy, they rounded.
Old 07-08-2007, 08:05 PM   #4
Pineedles
Pineedles's Avatar
Default Tourist Forecast?
Right............ There's no such thing as a tourist forecast in the Lakes Region. Been hearing for years.. RED, Blue, it doesn't matter who is in charge.
Old 07-09-2007, 12:31 PM   #5
Weirs guy
Weirs guy's Avatar
You're also assuming both thermometers are calibrated and accurate. You could probably put both of them in the same bucket of water and have a 2-1/2° difference between them.
Is it bikeweek yet?
Now?
Weirs guy is offline   Reply With Quote
Old 07-09-2007, 01:10 PM   #6
CanisLupusArctos
CanisLupusArctos's Avatar
Default Thermometer
Not sure what the DES is using for a temp probe, but mine is a Sensatronics E4 temp monitor which is brand new. If you're curious about its techie specs, you can visit www.sensatronics.com and look at the E4. The company is located in Bow, and has a reputation of making very accurate instruments.
When I saw the differences in the readings I always figured it's because the state's probe measures the temp of the water going thru the dam in Lakeport at the end of Paugus Bay. Paugus Bay heats up more easily in summer and freezes sooner in winter than out here on the open lake. The lake gets stirred up a lot more out here.
Old 07-09-2007, 02:46 PM   #7
This'nThat
This'nThat's Avatar
Many possibilities, including the depth of the two gauges, instrument calibration, water turbulance, the exact time of the measurements, the amount of sunlight on the area just before the measurement, the surface conditions (temp, humidity), and so on.
I think better data is needed before anyone can draw any conclusions. Specifically, need to collect measurements at the same times over a long period of time, and we need to calibrate (not only the instrument, but the all the other conditions around the instrument). With a lot more data, you can perform a good analysis.
This'nThat is offline   Reply With Quote
Old 07-10-2007, 09:47 AM   #8
Grant
Grant's Avatar
Rock bass are a conspiracy.
Old 07-10-2007, 12:25 PM   #9
Weirs guy
Weirs guy's Avatar
Can they calibrate a temp probe?
Is it bikeweek yet?
Now?
Old 07-10-2007, 12:31 PM   #10
Grant
Grant's Avatar
They would, if they were actually in the Lake.
Old 07-10-2007, 12:32 PM   #11
Island-Ho
Island-Ho's Avatar
Default Location?
I thought the summer temperature readings on this site came from Jolly Island, or somewhere in that vicinity?
Old 07-10-2007, 12:51 PM   #12
webmaster
Moderator
webmaster's Avatar
Right at the top of the temp page it says:
The water temperatures listed here are from the
Winnipesaukee Dataphone at the Lakeport Dam (603-527-0071).
Some of the archived temperatures were posted by Ron from his
thermometer on Jolly Island. Thanks to Ron for his contributions.
Ron was kind enough to post the water temperature from his thermometer off Jolly Island for several summers. He stopped doing it a few years ago and I have been posting the temperature from the dam ever since.
When Ron was posting the temperature it was usually the same or very close to the dam readings.
Old 07-11-2007, 12:04 PM   #13
Weirs guy
Weirs guy's Avatar
The probes or the bass?
I did read the specs CanisLupusArctos link lead to, the probe is ± 0.5° for this temp range, so assuming the states probe is equal that could be a full degree's difference right there!
Is it bikeweek yet?
Now?
Old 07-11-2007, 01:06 PM   #14
This time a year, with the outflow reduced to the minimum, the concrete dam structure becomes a heat exchanger transfering heat into the water. The concrete dam structure absorbs radiant heat from all the wonderfull sunshine and it gets transferred into the water as it flows though.
Not much water going through the dam this time a year, correctimondo?
Old 07-11-2007, 01:32 PM   #15
Wait a minute, probe accuracy is +/- .5 degree. How is it Algore can predict climate change to absolute certainty if the measuring instruments have a 1 degree margin of error on them, I thought the science was settled?
Oops, thread hijack, Less would never do that to someone else's thread.
Old 07-12-2007, 11:44 AM   #16
CanisLupusArctos
Default My guess
I would suspect that the difference is related to the size of the water. Paugus Bay, where the state's probe is, gets circulated a lot less than the water out here. Paugus Bay is almost its own little lake with only a small channel into the main lake. It wouldn't surprise me at all if the water temps there were warmer in the summer and if it froze earlier in winter.
Where my probe is, we see the lake getting continuously stirred from end to end - wind comes up from Wolfeborough (from the SE) and on days like today it blows from Center Harbor (NW.) The water here has always taken a good deal of hot humid weather before it warmed above 70 in summer, and in the fall it takes a good long time to cool down and eventually freeze. The trees within a couple hundred feet of the shoreline are usually a week behind the rest of the area during foliage season. We typically don't get our first frost until November, thanks to relatively warm water.
The last couple days the water temp reached 71, but now with lower humidity and a NW wind I'm wondering if it'll drop back into the 60s by evening.
Old 07-12-2007, 02:58 PM   #17
steadyon
Default its summer, smile
so, because the states reading is 2degrees higher, tourists will be coming
in droves and the Democrats get the points.
this is almost as silly as the Rusty McMeredith thread
steadyon is offline   Reply With Quote
Old 07-13-2007, 12:06 PM   #18
Weirs guy
Weirs guy's Avatar
So, why waste your time reading it and responding?
Is it bikeweek yet?
Now?
Old 08-01-2007, 01:19 PM   #19
CanisLupusArctos
Default Depth readings now online
Just installed a second probe at 12 feet deep. The "surface" probe remains at 3 feet. Right now it's showing 80 degrees at 3 feet and 75 degrees at 12 feet. They update every 15 minutes at www.blackcatnh.com.
Old 08-01-2007, 03:16 PM   #20
SS-194
I like analyzing temps as much as the next guy but hey it is the middle of summer. It may not get any better than this. Forget the #'s let's all go swimming!!
SS-194 is offline   Reply With Quote
Old 08-01-2007, 10:25 PM   #21
Bear Islander
Bear Islander's Avatar
My water temps are very close to yours. I measure at 3 feet. My lake temp is online, it updates when you refresh the page.
The way you display the data makes me believe you are also using the Sensatronics E4
www.bearcam1.com
Old 08-07-2007, 11:07 AM   #22
My water temp sensor is at the surface on my boat.I was on the lake 5 days last week and consistantly saw 80-82 degrees.At one spot in the broads of all places,I had 86 degrees!Wow,the water is wonderfull!!!
Old 08-07-2007, 02:59 PM   #23
chipj29
chipj29's Avatar
Been on the Merrimack lately? Last Thursday in Bow the water temp downstream of the powerplant was around 90. Talk about unrefreshing!
Old 08-07-2007, 03:48 PM   #24
Merrymeeting
Merrymeeting's Avatar
Default Record?
Has anyone figured out what the highest recorded temperature is of those that have been captured in the readings on the site?
I haven't had time to look yet...
Old 08-07-2007, 03:54 PM   #25
Merrymeeting
Default 79
Answering my own question,
Assuming it had to happen in July, Aug, or Sept (I didn't look at other months), 79 is the highest recorded temp.
Aug 9-10, 2001, July 19, 2006, and several times in July 2005
New record this week?
Old 08-09-2007, 04:24 PM   #26
CanisLupusArctos
79 is the record on which body of water? I seem to remember that in 1988, Winnipesaukee hit a record high of 92 degrees. It was in the news, alongside articles about duck itch and unusual aquatic plants popping up everywhere. That was a really, really hot summer as I recall.
Last year my old probe got to 84 degrees at 3 feet, during the heat wave of early August. This summer (with new probe) 82 has been the highest.
Old 08-09-2007, 05:06 PM   #27
Merrymeeting
I was referring to the records on this website. They only go back as far as 2000.
I too recorded 83 last week on Merrymeeting (which seems to track Winni fairly well). This is with a probe about 3' deep below my dock, about 20' from shore with water depth about 6'.
Old 08-10-2007, 01:13 PM   #28
Actually yes I have.I live in Bedford and was on the river last week.Although I launched at Lambert Park and was below the Hooksett dam.I didn't look at my temp gauge though.
Old 08-13-2007, 11:04 AM   #29
Default Big drop
From last weeks surface reading on my boat of 82-84,this weekend I had 76 on Saturday and 77 yesterday in the Broads off Welch Island.
Old 08-13-2007, 09:38 PM   #30
CanisLupusArctos
Default Dry weather is here
A little wind on the surface seems to have blown warm water elsewhere... meanwhile the humidity dropped off a ledge this afternoon. From a dewpoint of 65 this AM (very muggy) to 48 at sunset (Fall-like dryness.) When the air is very dry the lake water cools off quick. Today I had 76 water temp on Black Cat.
Channel 6 in Portland just mentioned "Fall-like" temps for this upcoming weekend so I'd say enjoy those water temps while they're still in the upper 70s.
Old 08-14-2007, 12:22 PM   #31
Weirs guy
Weirs guy's Avatar
I drove by Winnisquam this a.m. on the way to work and saw the dreaded "heat loss fog" rising off the water.
Is it bikeweek yet?
Now?
Old 08-15-2007, 12:53 PM   #32
Merrymeeting
Default Based on the Winnipesaukee.com temp readings...
... the downward slide begins...
Old 08-16-2007, 08:59 AM   #33
CanisLupusArctos
Default Autumn nears...
Heat loss fog, already? I haven't seen that yet but it does make for some *great* sunrise pictures.
The last few days the surface temp has been running cooler than the 12-foot temp. Just another sign of autumn. The hornbeam trees also have their first red leaves - they always start turning a few weeks before all the others but they still peak about the same time as the others.
Ch. 6 Weather (Kevin Mannix) said mountain valleys would probably get down into the 30s on Saturday night.
Old 08-16-2007, 09:36 AM   #34
Grant
Grant's Avatar
Personally, I think 70 is the ideal lake temp. Just right. And once you get into 80 and above, the algae blooms go into overdrive.
Old 08-16-2007, 12:10 PM   #35
Weirs guy
Weirs guy's Avatar
Bad news update, saw it again on the big lake on Meredith bay yesterday morning about 5:30.
Is it bikeweek yet?
Now?
Old 08-18-2007, 08:56 AM   #36
CanisLupusArctos
Default The downward spiral begins...
It felt like November suddenly roared in about midnight last night. Calm quiet summer night became hefty gusts out of the northwest in a matter of minutes and the wind is still increasing. Dewpoint now in the 40s, temp in the 50s, wind still increasing and tossing up the whitecaps.
Not surprisingly the water temp is now steadily dropping from 72. Based on weather forecast I think it'll get down to around 67 before this first-of-the-season cold wave is done with us.
This page was generated in 0.15834 seconds
