Old 05-14-2025, 04:48 PM   #1
retired
Default Treadmill Repair Service
Our treadmill died yesterday. I see some regional repair services on the interweb. Can anyone recommend someone? This is our first need for a repair and don't want to get taken.
retired is offline   Reply With Quote
Old 05-14-2025, 05:08 PM   #2
That is impressive. Most people I know use their treadmill for a coat rack. You wore yours out? Wow!
Old 05-15-2025, 05:40 AM   #3
TheProfessor
Telephone the manufacturer.
See if there are any authorized repair facilities available.
Old 05-15-2025, 02:47 PM   #4
Unless it's an extremely high-end Treadmill, it's probably cheaper to buy a new one.
Old 05-15-2025, 05:32 PM   #5
retired
We have had it for about 20 years. Maybe it's time. If so, how do I get rid of it?
Old 05-15-2025, 05:46 PM   #6
TomC
TomC's Avatar
junk removal service or take to the dump.. might be easier to handle if you partially disassemble it first.
Old 05-15-2025, 06:20 PM   #7
If you will be junking it, maybe do some DIY exploratory surgery on it. There may be an obvious problem that can be fixed easily. Worst case: you can't fix it, can't put it back together again, and you have to junk it anyway! Are there obvious symptoms of it's "failure?"
Old 05-16-2025, 11:10 AM   #8
retired
Exploratory surgery sounds like a plan. I'll make sure to unplug it first. New ones are under $1,000 at Dicks, and Belmont will pick the old one up at the curb for $25. Decision made.
Old 05-16-2025, 11:13 AM   #9
I agree at about 20 years and if it's used any kind of regular it's time for another.
Old 05-17-2025, 09:55 AM   #10
icg56
icg56's Avatar
Default Fix using U=Tube
We fixed our 20-year-old Precor using YouTube and a part from eBay. Works like new. We were told by a professional that the treadmill is no longer supported, and it was junk.
icg56 is offline   Reply With Quote
Old 05-20-2025, 11:08 AM   #11
retired
The operation has begun. Based on the patient's symptoms, I removed the power switch, which was working intermittently. I ordered a new one on Amazon and am waiting for delivery. To be continued....
Old 05-20-2025, 07:58 PM   #12
icg56
icg56's Avatar
That is what I was talking about. Be bold, nothing to lose.
Old 05-21-2025, 07:47 AM   #13
And you're getting exercise working on it!
Old 05-28-2025, 12:51 PM   #14
retired
Default Fixed!
Good news! The power switch was the problem. I was able to easily remove it and replace it with a part from Amazon for $14.95. It is running fine again. Thanks for the advice to try to fix it on my own.
The Following 2 Users Say Thank You to retired For This Useful Post:
Senter Cove Guy (05-29-2025), upthesaukee (05-28-2025)
This page was generated in 0.11508 seconds
