Anyone know if this is legal? White and red seaplane with no tail numbers pulls up to shore in 19 MIle Bay and has guys waiting with multiple red gas cans and they climb on top and refuel it sitting in the water. Does not look safe or environmentally friendly at all. Just wondering.
Thanks |
#2 | |
Very cool, why would it be illegal? Is it illegal to fuel a boat on the water?
| The Following User Says Thank You to ITD For This Useful Post: | ||
Smith Point (08-07-2023) | ||
It’s definitely not illegal but could be against some town ordinance. For example I know refueling boats at the Glendale docks is not allowed most likely for liability reasons…
winterharbor59 (08-01-2023) | ||
My guess would be the plane requires a fuel not available on the lake, most likely 100LL or something similar. I don't think it is illegal to refuel on the lake, but you def open yourself up to some liability if there is a spill. (We all know marinas spill small amounts of gas all the time)
The biggest issue would be the lack of visible registration numbers. Woodsy
| The Following User Says Thank You to Woodsy For This Useful Post: | ||
BroadHopper (08-03-2023) | ||
That’s what I thought.
#7 | |
"Your N Number must be at least 3 inches high when the maximum cruising speed of the aircraft does not exceed 180 knots CAS. If the maximum cruising speed is over 180 knots CAS, then the size of the registration number must be 12 inches high." |
| The Following User Says Thank You to Descant For This Useful Post: | ||
LIforrelaxin (07-31-2023) | ||
The one that applied to do rides out of 19 Mile Bay is red and white.
I would bet a hundred burgers that the plane has tail numbers.
They are likely small but legal. Please remember that things that are not made "illegal" by laws or regulations (don't get me started on those) are in fact "legal". Sometimes things that are unfamiliar to us appear to be odd, unusual or even illegal. These things might be quite routine in the circles in which another person might travel. For example, have you ever seen a banner towing aircraft pick up a banner? It looks like a Kamikaze attack!
| The Following User Says Thank You to 8gv For This Useful Post: | ||
Broken Glass (08-01-2023) | ||
1) The Town of Wolfeboro demanded that Wolfeboro Airpark remove its 100 octane fuel pump from the vicinity of its floatplane ramps. A 500 gallon fuel container was placed in the bed of 1920s Ford 1-ton pickup truck and gravity-fed gasoline to floatplanes which occasioned Winter Harbor. A logbook was placed on the passenger's seat so bills could be mailed out.
https://www.winnipesaukee.com/forums...2&postcount=14 When the truck was removed before 1997, floatplanes were fueled using hand-carried containers. 2) Something you seldom see with banner-towing aircraft. Off Hampton Beach, New Hampshire--just Saturday: https://www.mynbc5.com/article/new-h...nding/44680422 |
| The Following User Says Thank You to ApS For This Useful Post: | ||
stingray (08-01-2023) | ||
This aircraft might have been an ultralight, which don't need to be registered.
It isn’t an ultralight. It is a Cessna float plane. I don’t believe it’s top speed exceeds 180 so it is only require to have 3” registration numbers.
Correction: it is not the speed of the aircraft, it is the date numbers were first applied or manufactured. From National Aviation Center - “These must be at least 12 inches high, with a few exceptions. An airplane that displays marks at least 2 inches high before November 1, 1981 and an aircraft manufactured after November 2, 1981, but before January 1, 1983, may display those marks until the aircraft is repainted or the marks are repainted, restored, or changed.” If this is the seaplane that wanted to sell rides from Pier 19 I believe it’s owner stated it was a pre 80’s model in one of his posts.
#15 | |
Trying not to get too far off subject, but the OP didn't give much description or a picture, so there is speculation running through the thread. |
You can see the tail numbers, but can read them because of the original photo’s resolution, if you enlarge the picture. They are in the white just in front of and below the horizontal stabilizer. Sent from my iPhone using Winnipesaukee Forum mobile app |
#17 |
Seems like a lot of work to be lugging those gas cans around when you could be at Laconia or Moultonboro in a few minutes, land and fuel up. Maybe he has an autogas approval for the engine, but still, gas isn't light and I'm sure it takes much more than 5 gallons to satisfy that monster.
That have 6 or so 5 gal containers in a cart that the wheel over to the plane. Still carrying the containers down the rocky incline, over the pontoons, and lifting up to the wing can’t be fun.
| The Following User Says Thank You to The Real BigGuy For This Useful Post: | ||
ITD (08-03-2023) | ||
#19 | |
It appears to me this is something done to resolve an immediate fuel need, not something the pilot wants to do routinely. |
#20 |
Don’t know if this is the case here but, most float planes have retractable wheels in the floats.
#21 |
My active flying days are well in the past, but when I was active few floats had retractable wheels and the floats were changed out for winter flying and back to floats for summer. I also flew on skis for winter when I was operating out of a grass field.
#22 |
Out of curiosity, with no wheels, how did you get the plane in a position wher you could remove the floats, mount the skis, then get it to a surface where you could takeoff?
COW ISL TIME (08-20-2023) | ||
#23 |
Didn't he live on Mirror Lake? Not sure if he still does.
#24 |
If you enlarge the previously posted picture you can see the nose wheels on this 180. Clearly an amphibian.
LoveLakeLife (08-03-2023) | ||
#25 | |
https://admiralcloudberg.medium.com/...1-664af542dee6 |
| The Following User Says Thank You to Excalibur For This Useful Post: | ||
The Real BigGuy (08-03-2023) | ||
#26 | |
With that said, I also met a gentman, that had his home by a pond that was just big enough to land his plane and also take off.... He built a trailer, so that once a year he could move the boat to and from the pond.... and then kept it out on Winnipesaukee at a friends (my neighbors place) home for the float plane season.....
Life is about how much time you can spend relaxing... I do it on an island that isn't really an island..... Last edited by LIforrelaxin; 08-03-2023 at 03:25 PM. Reason: because I like to create typos |
#27 |
Thanks. That is interesting but sounds like a ton of work. I guess I’ll stop complaining about trailering my boat a couple times a year.
#28 | |
| The Following User Says Thank You to LIforrelaxin For This Useful Post: | ||
ApS (08-03-2023) | ||
#29 |
Most float planes I've seen have retractable landing gears. Having a float only plane seems impractical to me.
#30 |
So curiosity got the better of me, I am not sure what plane is picture but to understand how much fuel a Cessna 180 would hold I decided to look it up... it appears a Cessna 180 holds between 55-60 gallons.... there was a long range option that added an additional 20 or so gallons of capacity.
With that said 6 5 gallon cans would give you 1/2 tank of fuel..... what that equates to for flight time I have no idea..... When you look at the argument that ensued over crating a official runway, and float plane base in 19 mile bay, this looks like a stunt to me, to push the limits of what is allowable, to try and prove a point. From the photo, I can see the wheels on the floats so the plane is amphibious, and could easily land at Moultonborough or Laconia airports and fuel up, which would be much more convenient.........
#31 | |
Maybe they fueled the airplane this way because the fuel was cheaper than what they would pay at an airport. I know some boat owners fuel their boats from cans or the containers on wheels that hold about 20 gallons just to save from paying the high price at a marina. I am just not sure I would jump to the conclusion it is a stunt. |
#32 | |
Not sure why this guy opts to fuel like this, there are many potential reasons. My best guess is that he has an STC for autogas (car gasoline) and saves himself a couple of bucks a gallon doing it this way. I can almost guaranty that this guy is not doing this to irritate you or someone else or as a "stunt". Think positive thoughts. |
#33 |
If he has the ability to run that off of Autogas, which I never knew you could convert it but, I haven't flown light GA aircraft in a long time, he is saving a ton of money. 100LL which is the normal fuel for a light piston aircraft will run $6-7 a gallon.
#34 |
Certain engines can run on regular gasoline. But he's doing a lot of work, spending a lot of time, to save $60. I'm figuring from the time he puts 6 5 gallon jugs into his car, gets the gas, drives to the lake, lugs the cans from the car to the shore, lifts them up to the wing, empties them, then brings them back to his car, he's almost 2 hours into it. 30 gallons of gas weighs 180 pounds, that's a good workout for most people.
#35 |
I didn't mean stunt necessary in a negative sense. If this person is who I believe them to be, they are doing it to show that right now breaking no laws they can re-fuel their plane in 19 Mile Bay. I personally think it is being done to see if someone complains.... While the efforts to get a runway designation, and establish a float plane base appear to have stopped. I think that has only happened in the active sense. I believe we will see a continued push for this in the future.... The more activities that can be recorded over time as happening in the area, legally the better the chance are in the future for the agenda the desire to go through...... I personally don't understand all the objections... I think that it would be a nice feature for the area.....
#36 | |
#37 | |
#38 | |
#39 | |
