Old 07-20-2017, 08:11 AM   #1
mogulmamna
Default Dock question
Hi. I'm new to this forum and have a question about dock size and strength. I just purchased a 21' Cobalt (3850 lbs). We have an aluminum frame with wood planks dock that is 6'x30'. It's a seasonal crank up style dock. We are located in Moultonborough bay. While we plan to get a mooring, I am wondering if it will be secure at my dock for the time being. It could be several weeks before the mooring is in place.
mogulmamna is offline   Reply With Quote
Old 07-20-2017, 10:22 AM   #2
If it is one of the watermark style crank ups that is more than sufficient. We are staying on six mile this week, with long exposure and have a bigger boat on a crank up dock with pipes instead of posts. No concerns.
Old 07-20-2017, 02:14 PM   #3
mogulmamna
Thank you. Dock is actually 4' wide,not 6' but hopefully still strong enough.
Old 07-20-2017, 06:21 PM   #4
Do you know who built the Articulating Dock?
As stated by Codeman, a watermark dock would be more then strong enough, and so would one done by Center Harbor Dock and Pier. If you know who built it go to them directly. What I would suggest if the boat is going to sit at the dock for a while is to look into Mooring Whips, they help relieve stress on the dock and the boat. You may even find that with the whips you don't need to constantly put the boat out on the mooring....
I myself have a wooden dock with a 18' boat that weighs in at around 2800. With the whips, I leave the boat at the dock all the time. I am only considering a mooring in the next couple of years, because I could extend my season, do to water depth at my dock in the fall.
A neighbor has a 28' cruiser that he leaves on the dock with whips as well, and his boat is probably in the 7K-8K category....
Bayview Girl (06-26-2018)
Old 07-21-2017, 07:30 AM   #5
If you doubt the robustness of the dock, it is very easy and cheap to dramatically strengthen it with a pair of cables connected to the corner posts on the diagonal directly under the deck framing and tightened up with turn buckles. 1/4" is plenty strong enough. They can't be loose, but they don't need to be guitar string tight. That said, an extra set of diagonal cables between the deep end posts and some posts near the middle would probably be a good idea considering how skinny and long the dock is. Diagonal leg bracing under water is always a good idea too.
Old 07-25-2017, 11:59 AM   #6
Dave M
Default Another thing to check
If it has galv pipes with foot bases instead of 4X6 post, that's a trait of Raise-A-Dock, another good dock company. I have one built by them. Another thing to check if the dock has cross pieces under the deck. It stiffens the dock. I have two of them since my dock is 33'X6'. I have a 20' boat tied directly to dock, nothing moves.
Dave M
Old 07-25-2017, 02:36 PM   #7
My dock also is 6x30, aluminum frame crankup. The header bar was bolted to a huge pile of boulders at the shore end and the frame hung from it before ice-out a couple of years ago. The crew (Center Harbor Dock & Pier) delivered it by truck and trailer over the ice. They couldn't install the 4x6 legs because of the ice, so the frame was cranked up just a bit to await ice-out. In that position, I crawled out over the frame to the end, expecting some teetering. Boy, that frame barely moved at all. It's quite torsionally rigid.
I do have a pair of 8-ft whips for the boat, more for protection of the boat. I had the welder install a pair of mounting brackets for the whip bases, which bolt through the deck directly to the brackets. On summer weekends, when the boat wakes are unending, the boat pitches up and down vigorously, pulling on the whips, but the dock itself doesn't budge.
Kayla (06-26-2018)
Old 06-26-2018, 01:35 AM   #8
Bayview Girl
Bayview Girl is offline   Reply With Quote
Old 06-26-2018, 05:05 PM   #9
Kayla
Kayla is offline   Reply With Quote
This page was generated in 0.07433 seconds
