Old 02-02-2016, 01:02 PM   #1
Alongtheshorerentals
Default Adding sand behind existing retaining wall at shoreline?
I have a retaining wall at the shoreline, currently there is crushed stone, do I need a permit to replace with sand to make a sandy area?
Alongtheshorerentals is offline   Reply With Quote
Old 02-02-2016, 01:35 PM   #2
"It's easier to ask forgiveness than permission."
The Following 2 Users Say Thank You to thinkxingu For This Useful Post:
JasonG (02-04-2016), Reilly (02-04-2016)
Old 02-02-2016, 01:44 PM   #3
TheProfessor
As far as I can tell you need a permit/permission for everything near the waterfront. Trimming some trees may be an exception.
Possibly if you do a little at a time with a wheel barrow no one will notice or care.
A note about sand. The sand you get delivered by dump truck is not beach sand. The dump truck sand potentially is full of weeds that are not now on your property.
But let others who have done this recently chime in. The rules change and get interpreted constantly.
secondcurve (02-02-2016)
Old 02-02-2016, 03:41 PM   #4
Mirror Lake's BB
Default Phosphorus in sand
Something to consider is the fact that there is phosphorus in sand. As we all know by now, phosphorus is bad for lakes. Here is a link that discusses the situation in a lake in Maine.
http://www.yorkswcd.org/Lakes/ADDING...%20BEACHES.pdf
While you are not putting in a beach, over time some of the sand will end up in the lake.
Just something to consider.
Mirror Lake's BB is offline   Reply With Quote
The Following 2 Users Say Thank You to Mirror Lake's BB For This Useful Post:
diz (02-02-2016), secondcurve (02-02-2016)
Old 02-02-2016, 07:40 PM   #5
secondcurve
You'd probably be able to get a permit since you effectively have a perched beach in place. Another nice alternative is to do the whole area over in pavers. Again, you would need a permit.
The problem with the state of NH permit process is that is extremely cumbersome and time consuming. As a result, folks just do what they want as suggested above. The state should do two things to make the process work: 1) outsource the permitting process to a private company to eliminate the extreme bureaucracy in the system 2) Impose huge fines for anyone violating the system. If this happened we would all be better off.
Old 02-02-2016, 07:53 PM   #6
I'm sure there are large fines in place already.... I was going to write a diatribe here but thought better of it. Let's just say that the call for more laws and bigger fines invariably only disrupt and discourage those who would have and do follow the rules.
Old 02-03-2016, 08:16 AM   #7
Dad sold the C * C
Working that close to the water there are several things that could trigger your needing a permit. When reading the regulations the one thing that pops out is "machanical equipment", that usually triggers some sort of permit or Notice.
I would call the state and ask, yes it may require more work and money, but that's part of having waterfront property on our beautiful lakes.
Old 02-03-2016, 05:52 PM   #8
Default DES Website
There are several overview pamphlets at
http://des.nh.gov/organization/divis...ocks/index.htm
Old 02-04-2016, 08:30 PM   #9
secondcurve
I'm not so sure if the fines are actually spelled out but I may be wrong. I do agree enforcement is key and that is perhaps what I should have more clearly stated.
Old 02-05-2016, 11:22 AM   #10
CateP
CateP's Avatar
Default Grass
Why not grow grass there? Makes a nice carpet for feet, looks nice and won't pollute the lake. Go GREEN
Old 02-05-2016, 11:30 AM   #11
Merrymeeting
Merrymeeting's Avatar
Only if they are willing to accept that most of it will be weeds and weak grass. I have a section like this and it is green and comfortable on the feet. But if, like many, they also put down fertilizers and weed killers, it will greatly harm the lake.
The Following User Says Thank You to Merrymeeting For This Useful Post:
secondcurve (02-05-2016)
Old 02-05-2016, 11:34 AM   #12
Geese love grass, I wish my water front weren't grass, when 30 or 40 geese stop by and leave a wheel barrow full of "presents" it's not fun.
Old 02-05-2016, 01:27 PM   #13
CateP
CateP's Avatar
Okay--grass is a bad idea. Belay that suggestion. I would go with pavers then. No maintenance, no harm to lake, no messy sand getting all over the place and time to enjoy the lake.
Old 02-05-2016, 02:27 PM   #14
Default question.
When you have lakeside, or riverside, or any property bordering water that the State has an interest in, don't you have to be concerned with a proper ratio of impervious vs. pervious surface?
That I read that in a thread here in the forum, or maybe it was elsewhere.
Possible consideration to pavers if there must be a balance with the types of surface.
Old 02-05-2016, 03:30 PM   #15
MeredithMan
MeredithMan's Avatar
Default Lakeside = Pervious Pavers (or other substance)
That is correct. When our and our neighbor's driveways were put in, the permits dictated that they be of a pervious substance to mitigate / prevent run-off into the lake, due to their close proximity to the water.
upthesaukee (02-05-2016)
This page was generated in 0.10547 seconds
