I have a Angler Center Console, and will be having a ladder installed at the stern.
Going to purchase a 2 step type folding ladder, which will be mounted to the left of the Outboard. I know this is probably a common installation, but concerned because of the placement. I have a fresh water bait-well on same side as where mounted holes would be drilled? Also, besides using stainless steel bolts in mounting bracket, was thinking of using plastic washers, inside and out. Since I'm a little hesitant about drilling holes in my hull, going to have this professional installed. Thoughts appreciated ! |
My 2 cents...
I suggest that you consider a longer ladder. I find that going from swimming to climbing the ladder is much easier when the bottom rung is deeper in the water. Also consider the step from the ladder up into the boat. Is a small platform appropriate? Try to mount the ladder in such a way that there is ZERO chance that your prop will ever hit it. Sooner or later you will motor away with it down. Drilling holes through the transom is a serious task especially if there is wood in it. Seepage can ruin the transom so seal it well. Use "Bedding Compound" that is specifically made for hull penetrations below the water line. Use a backing plate for the washers and nuts inside the hull. This will spread out the pressure when you tighten the bolts. |
| The Following User Says Thank You to 8gv For This Useful Post: | ||
Dave R (02-03-2016) | ||
#3 | |
The older we get, the more we need more steps to get into the boat. I agree with 8gv on this... also on his ideas on installation.
Don't know what a console boat looks like at the stern. I have a platform on my boat with a foldout ladder that drops down into the water. Maybe use the foldout idea on your boat. Be able to mount out of the water or have something that mounts over the top of the stern. I have grab bar on my stern to help getting out. Use Velcro strap to keep together when not using.
Dave M |
Paying the installation makes good sense if your nervous about it at all..
Transom space on CC boat is usually at a premium.... the transom goes straight into the water with the OB engine mounted to it. Most runabouts have a "shelf" type transom design with a built in/bolt on swim platform design that makes folding ladders easy to use.
Most CC boats I have seen use a removable Diver type ladder to get in and out of the water. An example... http://www.amazon.com/Garelick-EEz--...ladders+diving Woodsy
Woodsy reminded be of another. On our older boat we used a boarding ladder (4-step)that dropped over the gunwale. It has supports that was used against the side of the boat. It also folded flat for easy storage. No drilling holes. Amazon sells them, just search for "portable ladders for boats".
Dave M |
| The Following User Says Thank You to Dave M For This Useful Post: | ||
upthesaukee (02-01-2016) | ||
By all means get a ladder that extends well below the water as others have suggested. Imagine trying to get an injured water skier or an exhausted hypothermic individual out of the water and into your boat. A strongly installed permanently installed ladder can be a life saver. Imagine falling over board fully clothed with jacket or coat and trying to get back aboard. Even a strong crew member would find it hard to hoist what could easily be 250 pounds of dead weight onto the boat. They may easily fall overboard themselves. A permanently installed ladder can be equipped with a release that can be used to deploy the ladder by an individual in the water. This can be as simple as a slip knot or spring catch. If you fall overboard when boating alone this may be your only chance to get back aboard. It is hard to justify the meager cost savings of a temporary ladder against the possible loss of life.
I have attached a suggested installation drawing for your consideration. If this idea is not suitable for your ladder or boat let me know and I will see about sending you something more applicable. One thing you might note is when mounting anything to a cored surface never screw or through bolt without back cutting and filling as shown or similar. |
Sorry I forgot to change the drawing format to PDF.
In rougher water when one is more likely to fall overboard having too many people trying to help someone up a side mounted temporary ladder may contribute to swamping or even capsizing in a smaller boat.
Be very selective using plastic washers as many plastics exhibit cold flow where under pressure the material is squeezed away over time. Also some sealants do not bond well to various plastics. If you are fastening a SS ladder to your boat you will most likely be better off with SS washers as their greater stiffness (given sufficient thickness) does a better job of spreading the load over a greater area. Always consider the use of backing plates.
On a rocking boat it is easy for some ones foot to slip off a ladder rung with out side rails. This could result in injury.
Here is a revised version of the previous ladder installation drawing.
Proof that haste makes waste
#15 | |
The other lesson from that experience is make sure there is a solid handhold to grab on to. Sent from my XT1254 using Tapatalk |
Definitely agree about the longer ladder. I could use the 3 step (extends 36 inches ) but while in the water I needed to put my feet up to get on the bottom rung and then pull myself upright. Just called to have a 4 step ladder installed and it will extend 45 inches, I think it will make a big difference!
