Old 08-21-2015, 06:10 PM   #1
Leoskeys
Default Washing Machine won't drain
The water has stopped draining out of our washing machine. We live in Alton. Any opinions, or recommendations for someone to take a look? It's probably cheaper to just replace.
Leoskeys is offline   Reply With Quote
Old 08-21-2015, 07:05 PM   #2
If you drain it into a dry-well, that may have reached the end of it's service life.
Old 08-21-2015, 09:29 PM   #3
lakewinnie
Default The pump may be clogged
There could be a clog in the pump. This has happened to my Whirlpool front-loading washer several times. I suggest unplugging the washer and removing the access panel (usually on the bottom of the front side of a front-loading washer or in the back of a top-loading washer). Sometimes the pump will have a separate opening for draining it, or you can remove the drain hose at the pump and check if it is clogged.
lakewinnie is offline   Reply With Quote
The Following User Says Thank You to lakewinnie For This Useful Post:
Old Hubbard Rd (08-22-2015)
Old 08-25-2015, 07:06 AM   #4
I have a front loader also and small things like socks keep going behind the gasket for the door seal. It's become a regular checking place to be sure nothing is behind the gasket when loading the dryer. Just this weekend had one of the ankle height socks there. Probably not your issue but just a thought.
Old 08-25-2015, 07:57 AM   #5
Washers and dryers are surprisingly easy to work on. The top of a top loading washer is only held on with a couple of spring clips in the front. The top will tilt back once these are pried open with a screwdriver and it's usually just two small screws to take the front panel off. Everything will be in full view at this point, including the pump that empties the drum. It probably just clogged with lint and hair.....
BT
Old 08-25-2015, 12:13 PM   #6
Ditto on washers being fairly easy to work on, for most things. If the washer is a top loader, then you likely have a panel in back that is easy to remove, for inspection of the drive mechanism, pump, and hoses underneath the drum. The pump would be easy to spot, as it would have hoses connected to it. Depending on the age, there likely would be a drive belt against the pulley on the pump. Your problem could be a broken or just loose belt. A belt is easy to replace or just retension. If there is something in the pump, disconnecting the hoses and removal of the pump isn't too hard. On some older models, you can remove 8-10 metal clips holding the bottom of the pump on, to expose the impeller and anything in the way of foreign matter keeping the impeller from turning, without even removing the pump or disconnecting the hoses.
This page was generated in 0.07320 seconds
