Old 04-30-2015, 12:21 PM   #1
gecko1
Default Island help
Opened up my place on the island last weekend. Two challenges I would like to get some guidance on. First, my hot tub is not working....may be the breaker or it may not. Any one know of an electrician or someone who can do hot tub maintenance on the islands?
Second, I have a squirrel (no sure how many) in the house. Any recommendations of pest management companies that do work on the islands?
Glad it's spring but always hate the opening issues!
Thanks much for any advice.
gecko1 is offline   Reply With Quote
Old 04-30-2015, 12:36 PM   #2
I know that Steve at ISS has an electrician that he can bring out for island work. Pest management is not on his list of services but he may be able to arrange to bring someone out. You could send him an email and ask.
http://islandsupportservice.com/services.html
Old 05-01-2015, 11:16 AM   #3
I would certainly check that breaker before I'd pay for an electrician to check it. Locate your panel and look for that tripped breaker. The circuit may be labeled for it. If your not sure which one it is and no red trip indicator is showing on any of them, shut off each double pole (twice as wide as the small one) breaker and and turn back on. It may be as simple as that. There could be a reason its tripped and when you reset that breaker it will trip immediately again if there is a problem.
Old 05-01-2015, 09:09 PM   #4
Misha888
Misha888's Avatar
Default I know my friend does island electric . . .
J.P. Carter Electric. 603-729-0001
And I second checking your equipment before calling.
A good cat is usually good at eradicating a house. If not, Havah{e)art traps. Let the Eagles and Fox take care of them on the outside.
Good luck.
☮ _/♥\_ & (✿ˆ◡ˆ✿)
Misha888 is offline   Reply With Quote
Old 05-02-2015, 10:35 PM   #5
Default Geography is always important
Gecko1, you don't say what area or island you're in/on. That can impact a lot of answers, or bring recommendations that don't work because the vendor is at the wrong end of the lake.
I'm a routine customer of Island Support Services mentioned above. With a wide range of services, I call ISS and let them figure out if I need an electrician, a plumber or a handyman. In other words, are you sure your spa problem is power, or is there plumbing problem with the pump and/or neater that trips the breaker? Hard to say from here. Since they're out on the islands for other jobs, they frequently have somebody stop by to size up a job and determine needs. Call them at (603) 293-HELP
One other thought. Most island residents develop some fix-it skills. My neighbor and I often visit each other's tool shed for parts and advice/solutions before we get in the boat to head for the hardware store. An important note here: Next time at the store, we replace that parts used. That's much more valuable than having $5 in your pocket for reimbursement.
This page was generated in 0.07398 seconds
