Old 09-29-2014, 10:31 AM   #1
Chickie
Default Rhino Shield
Has anyone in the area had their homes/cottages painted with Rhino Shield? It is touted to be better than paint or vinyl siding. If it works it would be better than having a house painted every few years. Is it all that it's cracked up to be? Your thoughts or experiences, please.
Chickie is offline   Reply With Quote
Old 09-29-2014, 11:03 AM   #2
Default Rhino Sheild?
Maybe on vinyl or fiberglass sidings, definitely NOT on wood or other porous surfaces. They need to breath to prevent moisture problems.
Never knew you can Rhino Shield a house.
Old 09-29-2014, 11:49 AM   #3
Phantom
Phantom's Avatar
Broadhopper-- Not according to their website
see below cut/paste:
Protective Finish Coat (PFC)
Protective Finish Coat is a highly breathable exterior elastomeric acrylic waterproofing ceramic coating. It offers insulation and solar reflective benefits with a very high permeable rating.
Rhino Shield PFC is applied over the Rhino Shield Self Priming Coat and is ideal for extreme climates and challenging wood surfaces
Old 09-29-2014, 07:03 PM   #4
Winni4life
Default It is not what you think
Do you think a small company can outsmart chemist and industry giants? From someone who knows the industry...don't do. The failures and difficulty to repair are too great. Never mind the price. Read the reporting magazine and they will tell you true testing results.
Winni4life is offline   Reply With Quote
Old 09-29-2014, 07:17 PM   #5
Originally Posted by Phantom View Post
...... It offers insulation and solar reflective benefits.....
The insulation value of anything the thickness of a layer of paint is essentially negligible.
Old 09-30-2014, 07:06 AM   #6
SUPER expensive a neighbor in mass priced them when painting again this summer. Rhino was literally the cost of four full blown "professional" paint jobs. That being said if you paint about every 5-6 years which is reasonable your payback is around 20 years. My neighbor said he'll be "pushing up Daisies" in 20 years so he'll let the next person worry about it. Not sure I can argue with that logic??
Old 09-30-2014, 07:37 AM   #7
Phantom
Phantom's Avatar
That was simply a "cut/paste" from their website.....
I was simply responding to the statement that it was not meant for "wood".
Personally, I have never used or know of anyone who has used the product.
Old 09-30-2014, 11:28 AM   #8
Steveo
Default Don't know if it is the same
The dock was in need of repair or replacement of the surface, lots of checking and splinters for the grandkids to run into. Can't afford to replace with composite so looked into this heavy duty paints (like Rhino Shield) but wanted to apply myself. Many of these paints are referred to as 3X or 10X which stands for their thickness compared to regular paint. Rustoleum makes one as well as Olympic and others. After reading all the reviews we have decided to stay away, far away. Really had problems staying down on decking maybe due to moisture under. Decided to go with outdoor carpet for now.
Old 10-11-2014, 11:11 PM   #9
AB_Monterey
AB_Monterey's Avatar
Default Not the same
I think you're referring to Deck Restore. I doubt it is the same thing.
I used it on my deck which had splitter and checking issues.
We're two years in now and I have to say that I am happy with the results. They claim that it will extend the life of a deck by 7 years. One thing is that it is hot in direct sun.
Before and after:
Old 10-15-2014, 01:52 PM   #10
Steveo
Default Restore on decks versus docks
I was told if you do a really good job of cleaning (like in your picture) using cleaning solvents then the Restore takes. But since this is on the dock the most I will do is pressure wash with plain water. Because of that and with the moisture from the water underneath it won't work for me.
Old 10-17-2014, 11:04 PM   #11
AB_Monterey
I cleaned that deck with straight water and my pressure washer.
Took 2 layers of solid stain off.
No need for anything else.
This page was generated in 0.14101 seconds
