Old 10-26-2005, 02:52 PM   #1
Lake Lady 6
Default High Wind - High Water
Winds have been high today and along with the high lake level are causing considerable damage along the shore. Our shore wall is in danger of collapsing as the water (which is usually 5 to 6 feet away from the wall) is splashing over the wall and the walkway to the dock thas been eroded underneath by the constant wave action causing the flagstone to cave in.
The water level is up to dock height next door, ours about 4 inches below dock boards.
When or if there is a drawn down it will help the hundreds of residents along the shoreline and islands. Many residents have put barrels filled with water on top of their docks to hold them down.
There has to be some way to control the level to help control the damage or maybe they can lower our taxes to compensate for dollars lost - the same way they are raised for the view.
Lake Lady 6 is offline   Reply With Quote
Old 10-26-2005, 04:20 PM   #2
GTO
Default flooding
And to think they don't release enough water to protect people downstream (Lowell, Lawrence along the Merrimack) from having flooding problems. But its ok to flood us..mmmm
GTO
Old 10-26-2005, 05:08 PM   #3
RumGuy
Default Yes
I wouldn't want the responsibility of that decision: In all, everyone here is losing, it's just a matter of balancing, or triage. I am sure that they are running off all of the water that they can without causing EXTENSIVE (which can also be spelled with a P in the middle) damage downstream.
RumGuy is offline   Reply With Quote
Old 10-26-2005, 07:10 PM   #4
wildwoodfam
Location: North Andover, MA & summers up at the BIG lake
Default Flooding in your own backyard!
Actually GTO - the Winnie Dam is being controlled so you don't flood Winnisquam and Silver Lake. Lowell and Lawrence are NOT the chief reasons for flooding up there on Winnie. Why did you pick Lowell and Lawrence anyway....certainly the other cities along the river - Concord, Manchester, Nashua, Haverhill and Newburyport are as important and in danger of being flooded out as Lowell and Lawrence....actually Lowell and Lawrence have a relatively good anti-flood system in place with their own locks and canal and dam systems working just fine - funny how you chose Lowell and Lawrence. (curious)
Frankly GTO one wonders why you have this sense of entitlemen. The same message can be said about waterfront owners as can be said for riverfront owners...you chose to live on the waterfront - and with that come risks, such as FLOODING! Imagine that!
Your statement is niave and ill placed. While it is certainly unfortunate that you may lose a dock (as expensive as that may be for you) this pales in comparison to what could be lost downstream of the Winnie Dam - including massive industry and commerce in all of the cities I listed above should flooding occur! The dams are in place for a reason....to hold back the water!! The dam wasnt built for pleasure!! We downstream are sorry that the water is lapping on your beachfronts and eroding the shoreline. But we are glad that the engineers who operate the dam have a vested interest in the producitivity downriver...and the reasoned experience to protect it!
wildwoodfam is offline   Reply With Quote
Old 10-26-2005, 08:02 PM   #5
secondcurve
Default Take it in context
Wildwoodfam:
I think GTO's comment was light hearted in nature. Please take it in that context. We are a friendly bunch. No one wants to see anyone flooded!
Old 10-26-2005, 09:39 PM   #6
Resident 2B
Resident 2B's Avatar
Default From the Dam Bureau
I cut and pasted this from the Dams Bureau web site. Once you read it, you get the feeling them totally understand the situation and are doing all they can to address it.
October 26, 2005 11:45 AM
The discharge at Lakeport Dam (Lake Winnipesaukee) is approx. 2,250 cfs. The level of Lake
Winnipesaukee is nearly 505.20, which is about 10 inches above the normal full summer level.
DES is passing as much flow as possible at Lakeport Dam to both stem the rise in
Winnipesaukee and to prevent, in as much as it is possible, damaging conditions at locations
downstream (Opechee Lake, Winnisquam Lake, Silver Lake and the Winnipesaukee River through
the Towns of Tilton, Northfield, Belmont and Franklin).
Flows along the Winnipesaukee River system WILL remain high for the foreseeable future, as
the storage in Lake Winnipesaukee MUST be passed downstream in advance of any future
precipitatin event. This also means that the levels of all of the lakes listed above will
also remain higher than normal during this process.
Old 10-27-2005, 12:19 AM   #7
webmaster
Moderator
webmaster's Avatar
Default High Water Pictures
Submerged docks like these were a common sight in the Lakes Region today. Check PhotoPost for more pictures of some the effects of the high water.
Old 10-27-2005, 05:09 AM   #8
spotsink
Exclamation Those DAM Operators
Judging by the data shown at the link below, output at the Lakeport Dam has been just about maximum for several days. It does not appear they are holding anything back right now...
http://www.bizer.com/bztnews.htm#lakelevel
spotsink is offline   Reply With Quote
Old 10-27-2005, 05:41 AM   #9
Old Hubbard Rd
Default Waterlevel-Highest I've Ever Seen it!!
This is the highest I have ever seen Winnipesaukee. How high have you seen it get???
Old Hubbard Rd is offline   Reply With Quote
Old 10-27-2005, 11:02 AM   #10
DRH
DRH's Avatar
The lake is now about 4" below the top of our dock. In July of 1998, the lake was level with the top of the dock.
Remember the "No Wake" restriction during all of the July 4 week that year?
DRH
Old 10-27-2005, 11:29 AM   #11
spotsink
Exclamation Lake Level - historical data
If you look at the graph in the link below it shows two times in the recent past when the lake was higher than it is now: late June of 1998 when it was about 3" higher than todays level and early/mid June of 1984 when it was about 6" higher than today, the 27th of October... I do not know how far back Bizer's data goes but this looks like the third highest level in the lake in the last 20+ years...
Old 10-27-2005, 01:55 PM   #12
GTO
Default Frankly......
dear Wildwood,
Just so your curiosity does not keep you up at night, I picked (on) Lowell & Lawrence because......mmmm..I hate towns and cities that begin with the letter "L". Ooops, but I like Laconia...that take care of that theory. Lets try this one, I beleive, that even though I grew up in Lowell for 23 years, that it could use a flood to clean it up....no, thats not fair, my parents still live there. Ok, I got one. I went through Lowell a day before I wrote this and saw that although the river was quite high, it could still go up another 2-3 feet before even coming close to any flood stages. Where the day before that, I was at the lake and saw docks and property underwater.
And Frankly, to the "one that wonders", Unfortunately I do not own lakefront property (imagine that) and fortunately. I am not effected by any high waters. But I see others that are, including people from this forum.
I wish no flooding for anyone, anywhere. It was just an observation but thanks for jumping on board. (I'm starting to like towns with the letter L. Maybe next time I'll name towns that begin with "H")
Is it true that the dam operator at Lakeport (another town with an "L") is from downstream? J/k on that one
GTO
Old 10-27-2005, 02:48 PM   #13
Orion
Orion's Avatar
Default highest level
While this may not be the highest level the lake has ever seen, it appears to be the largest deviation from normal for any given time of the year.
Old 10-28-2005, 09:36 AM   #14
Rattlesnake Gal's Avatar
Unhappy High Water Level
I guess we should be thankful it isn't peak season with all the summer boat traffic.
Hopefully the level of the lake can be lowered enough before the formation of ice.
Can you image what spring is going to be like if the level starts out high?
Old 10-28-2005, 10:18 AM   #15
hazelnut
hazelnut's Avatar
Default Union Leader Article
http://gamma.unionleader.com/article...1-d02b48ec4ec2
hazelnut is offline   Reply With Quote
Old 10-28-2005, 10:38 AM   #16
Woodsy
The Lakeport dam has the capability to drop the lake about 1" ever 24hrs or so. The problem is the lakes and rivers downstream. Opechee and Silver lake are way over full and flooded. The Winnipesaukee river can only drain so much from them into the Merrimack river.It's expected that Winni will crest sometime today at about 12" over full lake.
Woodsy
Old 10-28-2005, 01:48 PM   #17
Orion
Orion's Avatar
Default Relativity
There is also a "relative" impact to take into account. Winnipesaukee represents about 278 miles of shoreline and associated property impact whereas the next largest lake, Winnesquam is only about 25 miles of shoreline. Not pitting one against the other, but that surely must be factored in when determining relative outflows. I know the rivers represent a significant amount of shoreline on top of that but one would think that riverfront properties would be more durable against higher levels and flows than the anomaly currently being reflected on Winni.
Old 10-28-2005, 04:20 PM   #18
I've seen it higher, but I've never had driftwood on top of my dock!
Old 10-28-2005, 05:22 PM   #19
RumGuy
Default lake level
I remember in my-er...childhood, the lake being 10 inches over our dock. That was in '72 or '73. Judging by photos of our dock sent BEFORE Wilma/Alpha, the lake is just lapping over the top now. Of course the Wilma/Alpha storm has undoubtedly added a few more inches.
Old 10-30-2005, 09:04 AM   #20
Lake Lady 6
Default Drh
Yes, I remember the "No Wake" over the 4th in 1998 - neighbor had huge sign on his roof to help boaters who may not have heard about it. There was one west side Rattlesnake Island man who refused to adhere. Maybe it was the sign that irritated him but he would go wide open from the island past the neighbor towards the WAM several times a day.
In the mid-eighties there was a "No Wake" (maybe just weekends) for a couple of months as I remember due to high water. It was necessary to walk through water at Trexler's Marina to get to your boat as the docks were under water.
The good news is that at this time of year there are fewer boats causing wakes and one can only hope the water level will be down by next boating season.
Sincerely hope that no one, either on the big lake, or down stream suffers too much damage.
Old 10-31-2005, 12:12 PM   #21
spotsink
Question It is all relative...
With Winnipesaukee sitting at about 10 to 12" above normal and outflow at the dam at maximum people are still worried about property damage from the high water. After reading the article in the Union Leader (see excerpt below) I am happy the lake is ONLY 12" above normal! Imagine a water level 28" or more above normal...
"Winnisquam is 28 inches higher than normal for this time of year and many docks around the lake are actually under water. Silver Lake is nearly four feet above normal and has flooded Gardners Grove Road in Belmont."
Our dock, if it were still in, would be just under water now... but I am concerned about errosion around the foundation at the shore.
Old 10-31-2005, 01:56 PM   #22
DRH
DRH's Avatar
Default Higher than that, I think
I just checked Bizer’s web site (www.bizer.com) and I think Winnipesaukee is more like 24” (2.04’) above normal for this date, not 10 – 12”.
What Bizer’s lake height chart indicates is that the lake level is now about 10” above its average annual high point (505.16’ above sea level now versus an average high point of 504.32’). That calculates out to the lake being .84’, or approximately 10”, above its average annual high level.
DRH
Old 10-31-2005, 06:41 PM   #23
Lets say you decided to sacrifice the shoreline of Winnisqaum to save Winnipesaukee. You'd have to raise Winnisqaum nearly 11 inches to drop Winnipesaukee 1 inch due to the mauch greater surface area of Winnipesaukee.
Old 10-31-2005, 07:54 PM   #24
Orion
Orion's Avatar
Default inflow vs. outflow
Dave R....that would be true if the outflow from Winnisquam were closed and there was no more inflow into Winnipesaukee. The reality is that the outflow from Winnisquam generally keeps up with the inflow from Winnipesaukee. The outflow from Winnisquam increases with the rise in lake elevation. Agree, more flow from Winnipesaukee will increase the level of Winnisquam, but it's not a direct ratio of surface areas of the two lakes.
Also, I don't think anyone is sacrificing one for the other, it was just a point of consideration.
This page was generated in 0.19582 seconds
