Old 04-27-2012, 10:27 AM   #1
Living the Dream
Default Missing marks
I was out traveling the lake this past weekend and noticed a red mark missing between Mark and Timber. People on the lake now could navigate without any marks out there, but thinking down the road when the ya-hoos come back into town, this might be an issue.
Any other things changed during the ice movement?
Living the Dream is offline   Reply With Quote
Old 04-27-2012, 11:01 AM   #2
Rattlesnake Gal's Avatar
Default Thanks foe the Heads Up!
If you haven't already, be sure to call or e-mail Marine Patrol when you spot sonething like this.
New Hampshire Department of Safety
Division of State Police
Marine Patrol Bureau
Headquarters - 31 Dock Road Gilford NH 03249
603-293-2037* Fax HQ: 293-0096 Disp: 271-1153
www.marinepatrol.nh.gov
Old 04-27-2012, 11:27 AM   #3
Barney Bear
Default Navigation Markers
Whenever we discover that a navigation marker is missing or in its wrong location, we call the Marine Patrol in Glendale [at the location indicated in a previous post]. Usually, the situation is corrected in a timely manner. Thanks Marine Patrol.
Old 04-28-2012, 08:41 AM   #4
Living the Dream
Called that in Monday morning. Have fun out there!
Old 04-30-2012, 09:13 AM   #5
Phantom
Phantom's Avatar
Just as an FYI
when I come across a missing or misplaced marker I have called it in over VHF #16 ...
To be Courteous , I do run through in my head how to best describe the exact marker before hailing them --
M.P. has always seemed grateful for the call
Old 05-02-2012, 04:16 PM   #6
W Clarke
Thumbs up I thought all markers had numbers
Originally Posted by Phantom View Post
Just as an FYI
To be Courteous , I do run through in my head how to best describe the exact marker before hailing them -- .
If I remember correctly the green lake map by Duncan has all the markers numbered, not just the flashing light markers. You don't need to describe where the marker should be, just let the MP know what the marker number is. They brag that the numbering system is one of their Duncan map selling points.
W Clarke is offline   Reply With Quote
Old 05-02-2012, 04:25 PM   #7
NoBozo
My Duncan chart from 1997-1998 does Not have all the marks numbered. I'm guessing there are Hundreds of un-numbered marks. Only the lighted marks are numbered..up to 83 in all. The Bizer chart (5th Ed) has 84. NB
Old 05-02-2012, 04:47 PM   #8
Phantom
Phantom's Avatar
Can't speak to the Duncan Charts
Last version I have is a early 90's version which I let guests in the boat use to "follow along" as it is less cluttered and is more visually pleasant for non boaters.
I'm hooked on the Bizer Charts for navigation purposes.
Old 05-02-2012, 05:07 PM   #9
NoBozo
Default Low and Behold...
I just googled Duncan Press.. http://www.duncanpressinc.com/
Apparently they NOW Have ALL the marks numbered...over 700. That should make for......interesting navigation.
"HONEY: Could you get out the binoculars and see if that buoy over there is #873...?" Which buoy Snookie...there's 12 buoys over there. NB
Old 05-02-2012, 07:51 PM   #10
The buoy numbers on the Duncan Press chart, are the same as they are in the Marine Patrol Dispatch office Duncan Press charts. If you see a missing buoy simply call the buoy number into the Marine Patrol, no need to tell them where it is at.
Old 05-02-2012, 08:17 PM   #11
NoBozo
Are the actual old UN-numbered buoys now actually NUMBERED....with PAINTED numbers...so I can see them.. Just wonderin..
BTW: If a Buoy is MISSING....HOW do you SEE IT....?
NB
Old 05-02-2012, 08:43 PM   #12
NB
N.B.
You look at your chart and reference the number then simply call it in to Marine Patrol. The actual buoys themselves are not all independently numbered.
Hope that helps explain.
Old 05-03-2012, 07:14 AM   #13
Bear Island South
Bear Island South's Avatar
What about bouys that have been broken off?
How many years are they left in before they are replaced? I know of one near Meredith Neck, Dolly Island (opposite FL #3) that has been broken for three years.
Is it worth a call to Marine patrol or do they wait until it is missing, it is now at at point that you can not identify the color.
Old 05-03-2012, 08:25 AM   #14
Phantom
Phantom's Avatar
Bear Island South --
Call it in ! and I know the EXACT marker you are referring to
My experiance in the past is that if the Marker is unidentifiable (no color) Marine Patrol is usually pretty darn good at a quick fix.
Numerous times I have called in the Red top just off Pitchwood, which seems to be a consistant marker hit as traffic curls in towards FL#44
This page was generated in 0.12532 seconds
