Old 12-11-2011, 12:52 PM   #1
Tomt
Default Saw Blade Sharpening
Is there someone in the Moultonborough area that sharpens saw blades? Table saw, skill saw, chain saw etc.
Tomt is offline   Reply With Quote
Old 12-11-2011, 01:08 PM   #2
If you have plain steel blades my suggestion is to get carbide tip blades for the table and skill saws. Then you can pretty much forget about sharpening.
As for a chain saw, sharpening is fairly easy. You should learn to do that yourself as it should really be done after each use. Or even in the middle of a use should you happen to touch that hidden rock.
Old 12-11-2011, 03:01 PM   #3
MarkinNH
I have always taken my chain saw chains and brush cutter & table/skill saw blades to Mark Richter Repair on Rt 25. He does a great job and cost has always been very reasonable.
MarkinNH is offline   Reply With Quote
The Following User Says Thank You to MarkinNH For This Useful Post:
Tomt (12-11-2011)
Old 12-11-2011, 07:24 PM   #4
Tomt
I do have carbide tip blades and yes, after a while, they do need sharpening. I could tell because I almost set the smoke alarm off today cutting a piece of pine. I also sharpen my chainsaw blades but sometimes I like to have someone do a professional job.
Old 12-11-2011, 08:46 PM   #5
Irrigation Guy
X2
Sent from my DROID X2 using Tapatalk
My Company: Interlakes Irrigation Company http://www.interlakesirr.com
The Following User Says Thank You to Irrigation Guy For This Useful Post:
Tomt (12-11-2011)
Old 12-11-2011, 09:09 PM   #6
Rattlesnake Guy
Rattlesnake Guy's Avatar
I brought 4 of my 10 inch carbide table saw blades to a shop in Nashua to get sharpened. They quoted me $1 a tooth. As you might imagine, it is cheaper to buy a new blade than to sharpen at that price.
Old 12-12-2011, 08:04 AM   #7
There's a guy that works out of his home on rte 104 coming off of exit 23 heading towards Meredith. "Bobs sharp all" if memory serves me right.
Old 12-12-2011, 08:13 AM   #8
I agree. My carbide blades last a very long time and then I replace them.
Old 12-12-2011, 08:57 AM   #9
Winnisquamguy
Winnisquamguy's Avatar
Not sure who that was but $1.00 per tooth is very expensive,a good blade will cost you around a $100.00 and maybe $15-$20 to get sharpen. Chain saws are around $5.00. Any lumber yard will have a service that will do it for you, it usually takes about a week.
Old 12-12-2011, 09:30 AM   #10
Default On line service pricing
Here's a link to the first thing I came up with when I Googled sharpening.
http://dynamic-saw-blade-sharpening.com/pricelist.html
Glad I don't know squat about carpentry!
Old 12-12-2011, 02:27 PM   #11
Rattlesnake Guy
Thanks for the reasonable prices. Next time I have a dull one I will take a fresh look.
Old 12-12-2011, 02:59 PM   #12
NHBUOY
Thumbs up
I use Bob's on RT 104. He is reasonable, does a great job, on time, and is a great guy to deal with.
Old 12-12-2011, 06:25 PM   #13
sa meredith
Default yes
Yep...I've used this guy for several diffent things...including a simple set of kitchen knives. Reasonable enough. Sharpens everything...except my intellect...said he did not have the needed equipment for that.
Anyway...right on 104, left hand side heading toward McDs (away from rt. 93). Right after you pass Wicwas.
sa meredith is offline   Reply With Quote
The Following User Says Thank You to sa meredith For This Useful Post:
Tomt (12-12-2011)
Old 12-12-2011, 07:11 PM   #14
jmen24
One thing you can do to prolong the life of your blades to to use the proper blade for each type of cut you are performing. Sometimes this does not makes sense (read as two or three small cuts), but using a combo blade to rip any volume of wood will eat it up pretty quick, no matter what the species is.
Having multiples of each style helps when sharpening is needed, as you always have a fresh knife on the peg. I am sure not everyone is this bad but in my personal shop, I have between 20 and 30 blades hanging around, most 10's and a few 12's. If you happen to have any real quality blades, send them back to the manufacturer for sharpening, most due this as a service to their customers (still costs money). My Forest blades only get sharpened by the manufacturer, they understand the tolerances and at $200 a piece, its not worth the risk.
Sharpening horror story for those that care. A friend of mine sent in his crown saw to "the local sharpening guy" and asked him multiple times if he knew how to sharpen it. The response was an "of course I do" with a touch of attitude. When the saw was picked up, it was nice and sharp and all the teeth were so straight they all would touch a levels edge. The problem is that a crown saws teeth swale from front to back creating an arched cutting edge. The sharpener thought he was correcting a flawed saw, but in reality ruined a saw that has not been produced in over 40 years. Its been sent out all over the country to get tuned back up and it always comes back with a note attached, that it can't be corrected.
So, always make sure that anything special receives the attention it deserves.
This page was generated in 0.09507 seconds
