Old 07-12-2011, 09:57 PM   #1
Heading4thelake
Default sprinkler system
Can anybody suggest a company that is reasonably priced to install a sprinkler
system i Wolfeboro . Thanks
Heading4thelake is offline   Reply With Quote
Old 07-13-2011, 10:41 AM   #2
skibum
Gilford Well at 603-524-6343 if you mean outdoor irrigation.
skibum is offline   Reply With Quote
Old 07-13-2011, 07:13 PM   #3
ACutAbove
Just make sure who ever you use to do it knows what they are doing because if you have to add more sones or the pump is sized wrong for the amount of pressure you need can get costly in repairs or having to redo parts of the system. It is the type of project you should only have to do once and with the right amount of seasonal maintenance can last you a long time.
I send my irrigation work to Lacey in Moultonboro...they are the bast around.. its all they do.
Old 07-13-2011, 07:21 PM   #4
For someone who is handy, lawn irrigation can be a do-it-yourself project. Lowe's-Gilford sells everything you need to get it done. Deciding to spend five thousand dollars for a contractor installation or only five hundred to eight hundred dollars for a very similar do-it-yourself installation is pretty much what it is all about.
http://www.lowes.com/cd_Install+an+U...tem_920603261_
Old 07-13-2011, 10:30 PM   #5
MarkinNH
Very well said.
An irrigation system designed and installed properly is a joy to own and an asset to the property. An improperly designed and installed system will give the homeowner nothing but headaches and problems.
I second the reccomendation of Lacey Irrigation. I have known and worked with Tom for several years and if I were in a position to install a system at my home, a call to Tom Lacey would be the Only call I would make.
MarkinNH is offline   Reply With Quote
Old 07-14-2011, 07:15 AM   #6
Winnisquamguy
Winnisquamguy's Avatar
You get what you pay for, the stuff you get there as far as fittings and the heads are junk!! You should use the correct clamps and you need to use Rain Bird or Hunter products. It can be done by a DIY, but I would not recommend getting your products from Home Depot or Lowes. Also a good rule of thumb to go by is around $100 per head for a contractor to install everything soup to nuts.
Old 07-14-2011, 07:41 AM   #7
Obviously the size of the yard depends on the cost but five thousand dollars would (should) be a HUGE system. I have one in Mass in the front and side of the house. All Hunter heads/equipment, 2 zones app 11-12 heads in total. Control box in the garage, electrician wiring the system and the sprinkler guy installing it...Everything $1,600. I'm not very handy but still wouldn't attempt one myself. Some things just aren't worth the potential savings. My neighbor bought his own compressor to save the 75.00 winterizing at the end of the season. Last fall he did something wrong and his system went frozen...925.00 to fix this spring (and that was his best quote.) Lets do the math 925.00 divided by 75.00??? Yeah that was a bargain.
Old 07-14-2011, 12:23 PM   #8
Doing a system yourself is not hard provided you can read some simple instructions and there are plenty of do it yourself guides out there. The two biggest things to understand is local laws regarding how to do the installation if it's tied into a public water supply and how to plan head locations and spacing so you get good head to head even coverage based on water pressure and feed line diameter. Some towns are very strict about anti siphoning setups and if you need to feed off a separate water meter usually you have to coordinate that with the city/town and probably pay a plumber to do that part of the installation. You may also need to have it inspected, I've done a couple where that was the case.
Putting one in is a piece of cake, I've installed several the largest being at my house which consists of 10 zones and 50 heads (3/4" line, 3/4" zone valves @ 75PSI on my well head spacing the heads at ~22 feet). Did it in a little over a day and cost me about $1500 bucks in parts and 100 bucks to rent a ditch digger for a day. Labor... free! Had I paid somebody to do that kind of system I have no idea what it would cost but I bet it would have been expensive based on what I've heard typical costs to be. Won't comment on brand names other than I've installed both Orbit and Hunter products and my experience with both is they are comparable. Like anything you can spend a lot of money on a name brand.
As a side note I highly suggest putting in an inline sediment filter if the system is drawing directly from a well or lake. If you pump sediment into a system it can be a total pain in the blank to clean out and can ruin the heads and zone valves. Always make sure to put in a blow out point ahead of the zone valves so all the water can be evacuated from the system in the fall. I piped in a simple spigot on the systems I've put in and put together a screw on nipple to fit my air compressor.
If you have any questions if considering a DIY PM me.
Old 07-14-2011, 12:37 PM   #9
Yup, you had a big money system to install. You did well doing it yourself but your correct about lots of rules concerning the piping, etc. I'm not sure in Mass a spigot is allowed. Seems I was told about certain rules concerning that. 1,600 didn't break me and I've enjoyed trouble-free operation, my (front) yard likes it too.
Old 07-14-2011, 01:09 PM   #10
Lowe's-Gilford has Rainbird products. Lawn irrigation is a good project for someone who likes to fiddle and diddle with all-plastic plumbing fittings, plus it is totally separate from your domestic water supply, so you can just take it slow & steady and expect to have some challenges along the way. Good water coverage for a lawn makes all the difference between a burnt out lawn and a nice look'n lawn.
Thom Lacey does terrific work, but some of us like to save a buck and just do-it-yourself. What the heck....if the do-it-yourself lawn irrigation project turns out to be a MAJOR BLUNDER, you can always call in a contractor to correct your mess. Something that cannot always be said about doing-it-yourself and the doctor, dentist, or car mechanic!
Old 07-14-2011, 02:02 PM   #11
I can only imagine what that mine would have cost to have installed but no doubt it would have been more than than this cowboy would put out that's for sure. Plus it's not hard to do, just labor intensive. Use good stuff and it'll operate trouble free, mine has been in now for 7 years and it's been great. I don't miss the days of hauling hoses and spike heads all over the place!
Never done one in MA, but a couple NH towns were a little touchy on how they wanted things done where I was tapping into the public water supply. Of course if you're using a public water supply calculating the head per zone and coverage is easier since you don't have the varying pressure of a well head. The big deal is putting the irrigation system on a meter so they can charge appropriately for water because in both cases the sewer bill was calculated based on water consumption, with the irrigation system the water is never put into the sewer so that's why it's done separate. Never had anyone say anything about a spigot installed in the system, but again you have to know what the local laws are to know what you can or cannot do. Either way some sort of access point needs to be installed to blow the system out properly in the fall.
One thing to think about if you do it yourself or not... if using a well make sure you have the recovery rate to run a system and NOT run your well dry. Not all wells can handle a massive draw down of water especially in the middle of the summer when it can be dry for extended periods of time. Find this out ahead of time before calling in a contractor, as it could save you a whole lot of time and money!
ApS (07-22-2011)
Old 07-15-2011, 06:56 AM   #12
I do not have a well in Mass but I just need to keep dealing with watering bans, all the time. That's another reason a system is nice because we usually begin with odd/even day waterings allowed. It's nice to just set the controller to do that for me again, no worries. Problem is those bans usually turn into no lawn watering which means you need to become a little creative.
Old 07-15-2011, 07:27 AM   #13
XJLPS
Dave Pounder , Moultonborough, Old Man Fire Protection.
XJLPS is offline   Reply With Quote
This page was generated in 0.12632 seconds
