Old 02-28-2010, 06:37 AM   #1
Cool Too-Cool有and Maintenance Winch...
Where was this item thirty years ago?
Bolt up your chainsaw, secure to a tree, then drag 'most anything around your lot. Log? Boat? Dock? Raft? Boulder? Stuck truck?
Discussed HERE:
Old 03-01-2010, 07:10 AM   #2
Believe I saw a gas powered winch pretty similar to that, made by Makita, at Heath's Hdwe, just across from their freebie, courtesy hardware store coffee give-a-way. Did you know that Makita makes a gasoline powered chainsaw in Makita blue.
....hey...if you are look'n for something to do while waiting for the next snowstorm...could be a good opportunity to go hang at the local hardware and spend an hour perusing the world of Makita with a free cup of hardware store coffee...E M Heath Hardware....Centre Harbor....very close to the shore of beauteous Lake Winnipesaukee and the winter storage of the Mount Washington www.cruisenh.com/webcam.html
Old 03-01-2010, 08:42 AM   #3
pontoonbarge
pontoonbarge's Avatar
Default Makita 520i Chainsaw
Hello folks,
I got one of those blue makita's about 8 years ago -- it works like a champ.
Bought it after the cheapo one I had prior failed, the 5th time I used it. The cheap one probably made about 30 cross cuts total before the clutch bearing assembly siezed things up.
I got the makita at PJ Currier Hardware in Amherst.
Currently have it set up in a log slabbing assembly; tried making some birch planks with it this fall. Despite my inexperience, they look alright
Now that chainsaw winch is a beauty! (All sorts of uses for a tool like that!) When building my camp on rattlesnake, I used a harbor freight 8000lb rated jeep winch, bolted to boulders, to help pull the trees in the building site the right way before cutting them -- that worked great, too.
Gotta love tools...
Andrew
pontoonbarge is offline   Reply With Quote
The Following User Says Thank You to pontoonbarge For This Useful Post:
Rattlesnake Gal (03-01-2010)
Old 03-01-2010, 01:06 PM   #4
FLL is the only person who will burn $3.00 in gas for a free $1.00 cup of coffee.
This page was generated in 0.15279 seconds
