Old 01-05-2020, 04:25 PM   #1
Default Shredding Service ?
I have a lot of old files, with sensitive information, I need to destroy and thought I would shred them. I have a small office shredder machine, but have about 3 large boxes of files, and would take me forever to destroy. Each box weighs about 25-30 lbs. Maybe a 100 lbs total !
Staples has a shredding service but charges $1 a pound. UPS also has a shred service at 69 cnts a pound. At either rate it would be costly !
Any recommendations how to destroy these old files ?
Thanks !
Old 01-05-2020, 05:17 PM   #2
Susie Cougar
What about burning them outside?
The Following User Says Thank You to Susie Cougar For This Useful Post:
Top-Water (01-05-2020)
Old 01-05-2020, 05:26 PM   #3
Doobs41378
Agree, fire pit.
The Following User Says Thank You to Doobs41378 For This Useful Post:
Old 01-05-2020, 05:42 PM   #4
Scott_In_NH
Hi
If you can wait, you can take your boxes to a DCU shred event.
3 boxes would be no problem. I went twice with 5+ boxes each time.
https://www.dcu.org/community/shredder.html
Or
These guys are pretty reasonable.
http://www.theshredsource.com/
Scott
Scott_In_NH is offline   Reply With Quote
Old 01-05-2020, 06:00 PM   #5
Sue Doe-Nym
Default Frugal Frannie Dept.
I didn’t feel like shelling out big bucks for our old docs, so I set up the shredder next to my chair in the family room, and shredded away during commercials while watching the news. Relatively painless method and cheap.
Old 01-05-2020, 07:03 PM   #6
rick35
Originally Posted by Doobs41378 View Post
Agree, fire pit.
I have a metal trash barrel that i use. Put a little charcoal lighter fluid on it and throw on a couple of logs and that usually burns it all the way down. I have a shredder but it doesnt take much for it to overheat.
Old 01-05-2020, 10:08 PM   #7
SailinAway
In my experience it takes a very surprisingly long time to burn paper files and it's not an easy job. You can't just toss piles of paper on the fire because they will smother it. It's hard to keep the fire going. You have to tear the papers into strips and make sure the fire has constant air. It's pretty tiring and boring. You could also tear them by hand and take them to the dump, which is equally tedious. Best way might be to burn the papers on a hot wood fire and keep loading it with wood. Air pollution??
Old 01-05-2020, 10:27 PM   #8
Sue Doe-Nym
The heck with all of you. I like my method of shredding during commercials.....20 minutes of painless shredding per 40 minutes of news. 🙄 Easy and cheap, plus no air pollution.
The Following User Says Thank You to Sue Doe-Nym For This Useful Post:
upthesaukee (01-06-2020)
Old 01-06-2020, 09:13 AM   #9
Default Yup
When I worked for Staples, I would tell people if they want to get rid of that box of files and papers, buy the 29.99 cross cut shreddar that fits on the top of a trash can, and shred 3 or 4 pages at a time during commercials. Cheaper than buying the 200.00 shreddar, and just as effective.
Good job Sue.
Old 01-05-2020, 06:16 PM   #10
Outdoorsman
Thanks !
To be in possession of such "super secret" files with no insight on how to destroy them when needed is disturbing.
To be in possession of such "super secret" files without being able to drop $69.00 to destroy them is even more disturbing.
The Following User Says Thank You to Outdoorsman For This Useful Post:
Old 01-05-2020, 09:28 PM   #11
Default Are you Adam Schiff?
Where did you get the extension that "sensitive" is "Super Secret"? I'm sure you have "Proof" but, of course, you can't reveal it except to hearings in the locked basement. Waaaay overboard. "Sensitve" may be just somebody dancing on top of a piano.
Old 01-06-2020, 12:15 PM   #12
Thanks !
If its truly only 100lbs, $0.69 per lb for UPS to do it is only $69....Doesn't sound bad for piece of mind to get rid of sensitive documents properly?
Old 01-06-2020, 06:43 PM   #13
Default Credit Unions
Check the credit unions. Logix provide free shredding service to all the customers. Since the nearest branch is in Nashua, I found out Northeast Credit Union branch on 106 will shred documents from any CU members.
Libraries use to shred. Not sure if they do anymore.
This page was generated in 1.09525 seconds
