Old 09-06-2014, 01:18 PM   #1
Andrea.wiltfong
Default Wood Stove
We are looking into purchasing a wood stove off craigslist. We are looking for someone to install. Trying to get a general idea of what it may cost, and recommendations for who may install without having to purchase through them.
Andrea.wiltfong is offline   Reply With Quote
Old 09-07-2014, 09:29 AM   #2
Is this your first wood stove? Just wanted to suggest buying one with a glass door....so relaxing to watch the flame.Like having a fireplace without all the inefficiency issues.
Old 09-07-2014, 09:33 PM   #3
Andrea.wiltfong
Default yes it is our first
We have a fire place at the house, we were hoping to get a woodstove for the other side of the house to better heat the upstairs...but don't want to spend an arm and a leg for it
Old 09-07-2014, 09:37 PM   #4
Andrea.wiltfong
Thanks for the suggestions! I will give them a buzz this week. Thinking between the fireplace and woodstove we just may be able to reduce the amount of oil we use this winter. This is our first winter in this house, its been empty so there are no service records as to how much oil was used in the past, its making me nervous LOL so thinking a woodstove would be a great idea.
Old 09-08-2014, 09:59 AM   #5
A fireplace is fine for providing radiant heat to the immediate area surrounding it, but in general it isn't a very good way to heat a house. A typical fireplace draws far too much air up the flue, way more than is needed for combustion, and that air is drawn from the house's interior, and ultimately from the outside via all the cracks and minor holes in the exterior shell. In other words, while the room with the fireplace may feel cozy, the rest of the house may feel cold and drafty. Moreover, after the fire has died but while there still are glowing coals, the damper can't be shut, and so the chimney draws interior air up it all night long. Finally, a fireplace damper often does not close tightly later on anyway, so that it may leak air badly even when not in use. There are top-side, cable-operated dampers that can be installed to provide a much better seal than the hearth side damper.
A woodstove is a very different device, designed for careful control of combustion air, to minimize the air drawn from the interior of the house. Further, depending on the model, it may be possible to attach an "Outside Air Kit" (OAK) directly, with a duct to the outside, so that combustion air isn't drawn from conditioned space. It also nearly eliminates the cooling effect of continued air draw after the fire has gone out but before the air control can be closed.
If you are concerned about heating cost for the upcoming season and want the biggest savings for least investment, have a blower-door-directed energy audit and air-sealing project done. Much of the air sealing is a day of DIY effort. Start in the attic, moving aside insulation where wiring coming up from below is, and put a squirt of can foam into the wiring hole. Look for light fixtures and seal around them, too. I hope you don't have any can lights poking up into the attic; typically they leak air badly. However, you can build insulation boxes to go around them, using rigid foam board and with joints sealed with can foam. In the basement, go around the sill areas and apply sealant where sill meets foundation and where rim boards sit on the sill. Find and seal any places where wiring or plumbing penetrates the building envelope.
A good site to search for all sorts of information on air sealing and related topics is www.greenbuildingadvisor.com.
Old 09-08-2014, 09:01 PM   #6
If you plan on using both wood heat sources at the same time, you'll definitely need an Outside Air Kit (previously mentioned).
For the woodstove, I'd brush up on Canadian "code", which is more strict than US' codes. Those details will likely help you decide which woodstove to buy from Craigslist. Also check Craigslist for double-walled stovepipe, as it is pricey. I have a few left over. (Have to check).
When we refitted our outside chimney last year, we moved our "tried and true" woodstove to a more convenient location, fitted the stovepipes, and had a local chimney expert install only the chimney part. With a little trimming, we put the "kit" together, and are happy with the result.
Remember, that woodstoves get a real workout up here, and some will have literally "burned-thin". If you're in it just for the heat, don't buy a woodstove that is enameled. (All-black is best for heat transfer.) A glass window is OK, but if you burn unseasoned wood, it will blacken quickly, and is difficult to clean.
More wood stove advice at:
http://www.winnipesaukee.com/forums/...ad.php?t=17249
Old 09-07-2014, 09:40 AM   #7
hig
Install cost depend on the installation and especially the length of stove pipe required. Double wall stovepipe is about $250 per 4' section and code dictates how high you need to go. For example, if you have to go 16', you are at 1000 in stovepipe alone, even before you factor in any other cleanouts, couplers or direction changes.
All up, installation parts and labor can get up over $3000 for a two storey house with the stove going on the ground floor.
Look on servicemagic.com for independent nstallers in your area.
hig is offline   Reply With Quote
The Following User Says Thank You to hig For This Useful Post:
Andrea.wiltfong (09-07-2014)
Old 09-07-2014, 11:09 AM   #8
whalebackpoint'r
Danny Richardson is great!
Country Sweep
Dan Richardson
603-569-6498
whalebackpoint'r is offline   Reply With Quote
The Following User Says Thank You to whalebackpoint'r For This Useful Post:
Old 09-07-2014, 07:31 PM   #9
Default hearth.com is a good site to frequent
Hearth.com has various subforums, much like the assortment on winnipesaukee.com. If you have questions on installation details, firewood, size of stove needed, etc, you'll have no problem finding answers there. It's a good place to supplement whatever information you fine here.
Installing a woodstove at this time of year makes me think that a related question you'll have is about where to get properly seasoned wood for the upcoming burning season. There is "seasoned" wood and then there is wood that actually has been seasoned properly (dried out). You'll learn that some species, such as oak, while good burners, need as much as two years under cover to dry out adequately, depending on split size, while others, such as ash, need less time. If you try to burn wood that was keeping green leaves up in the air this summer, you'll be turned off anything connected to woodburning rather quickly, and your neighbors will be wishing you had learned what "seasoned" really means.
Old 09-07-2014, 07:39 PM   #10
pjard
Call Mike at Lakes Region Chimney Pro...603-520-7217
The Following User Says Thank You to pjard For This Useful Post:
Old 09-07-2014, 08:07 PM   #11
Dad sold the C * C
I'll second that suggestion.
The Following User Says Thank You to Dad sold the C * C For This Useful Post:
Old 09-09-2014, 07:03 AM   #12
Another recommendation for Hearth.com. Although I use the pellet forum, the info on their site is great.
BT
Blue Thunder is online now   Reply With Quote
Old 09-09-2014, 11:28 AM   #13
HellRaZoR004
Another thing to consider is the cost of wood has risen considerably. We are paying $275 p/cord seasoned cut/split for 3 cords ($825 total).
Old 09-09-2014, 02:47 PM   #14
hig
And a lot of places are already sold out of seasoned wood.
This page was generated in 0.12327 seconds
