I discovered quite by accident that these lights REALLY last. They have 3 AAA battery's.
I accidentally left one of these lights ON the night before last..under a bookcase where I was searching for something. I forgot to remove the light from under the bookcase and turn it OFF. At least 24 hours later i discovered the light STILL under the bookcase..and still ON...AND Still BRIGHT. http://www.amazon.com/s/?ie=UTF8&key...sl_3ipggv5rd_b Impressive... NBPS: I've turned the light back on and placed it on the coffee table...Let's see how long it takes to run the battery's down. BTW: The battery's are the original battery's......FOUR years old..?? |
Interesting info. I'll be very interested in the results of your test.
I was thinking this battery thing... may be like the Kramer Road Test thingy. (Seinfeld) Will we run out of gas...?? I found the video on You Tube..BUT it left out the hilarious "Punch Line" ...where the car finally ran out of gas..somewhere in NY... and Kramer got out of the car and hailed a cab..leaving the car salesman stuck with the car.
NBPS: I left the flashlight ON All Night (10 Hours) on my bed table. It was still ON at 6:30 AM....I turned it OFF at dawn. . NB |
I bought an extremely bright and cheap flashlight at Loews it's only one bulb but supposedly (so the packaging says) is 200 lumens. It's only one of the smaller ones around 5-6 inches long and bright as hell. Problem is I'm finding now it dulls fairly quickly for an LED light. It was just under 10 bucks so I bought 4 or 5 of them. Using one a lot taking the new pup out in the dark but have replaced the three AAA's already in three weeks. Still worked just dulled a bit I like them like a spotlight (which it is with newer batteries.) Awesome light for the $$.
I turned the light ON again last night on my bed stand when I went to bed. At about 4:30 AM I got tired of opening one eye every now and then and still seeing the light ON...so I turned it OFF. It was still Bright.
I think the LESSON here is that LED lights seem to require a whole lot less power than anything I have seen. I am NOT a Global Warming... Tree Hugging... Commie..Environmentalist..... ![]() This is just my small personal experience with one flashlight.... Consumer Reports has a report about light bulbs..Maybe I need to read it.. maybe learn something. NBPS: Only us Old Coots will remember the OLD flashlights that would go dead in maybe an hour..if you left it on..inadvertently.. |
| The Following User Says Thank You to NoBozo For This Useful Post: | ||
old coot (11-11-2013) | ||
No science involved in this response but its my thought. Incandescent lights use a lot of energy that is wasted on heat. Led are cool to the touch.
SIKSUKR |
#7 | |
NB
#8 | |
Look at it this way... Consider case 1: A 100W (Watt) bulb running off 12 Volts = 8.333A (ampere). If the battery is rated for 85 AH (AmpHour), it would would supply 100W for a little more than 10 hours. Now consider case 2: A 50W bulb running off 12 Volts = 4.166A. Now we're talking 20 hours...i.e. you double how long the battery will last. Keep in mind the above cases are straight theory and not necessarily what you will see in real life, but you can use the same approach for a 60W incandescent and 10W LED bulb. |
I have a "shake" LED flashlight. No batteries. Paid $2.00 8 years ago.
Still works. |
#10 | |
We have been subscribing to Consumer Reports for 4+ decades. They actually used to TEST Stuff and report....... NOW...Not so much...........but you HAVE to read it, if you want to be informed.... there "may be" a little tidbit that you didn't see somewhere else. Use JUDGEMENT... NB
This week I had a need for a NEW Drop/Work light. My 50 foot corded drop light had a plastic cage around the light bulb. It melted. SO: I went to Home Depot to look for a replacement Cage...for the light bulb. What I found didn't look like what I wanted.
Alas: I wasn't finding what I wanted: My EYE was wandering about and I spotted a 21st Century replacement. An 45 LED Work Light. "No need for a cord" to 120 volts...(except to charge the battery). It has a very powerful magnet in the base...to stick it on your car anywhere... as well as a hook to hang it up. The "Light Time" is 2.5---4.0 continous hours The LED Light Head is totally Swiveling. I AM impressed. OH: I bought it. It comes with a 50% charge. It's now on the charger to bring it up to 100 %. . NBhttp://www.homedepot.com/p/Defiant-L...9#.UnwwzOL91NQ Last edited by NoBozo; 11-07-2013 at 09:40 PM. |
Pine Island Guy (11-08-2013) | ||
I've been so impressed with LED lights lately that I bought my first LED light bulb for the house. I have a a 60 watt incandescent bulb in my den which stays on for most of the day...next to the computer. The incandescent just popped.. AGAIN today...They are made in China (GE) and they don't seem to last.
The NEW LED bulb is a 60 watt bulb that looks like ...same size and shape as the old bulb. It's heavier (weightwise) than the old bulb. The card says it uses 11 watts to make the light that the old 60 watt bulb did. ....The light "color" is the same.... The cost at WallyMart was $10.95. I'm going to get another one for the living room. I'm going to replace the bulbs that spend the most time ON.. NBPS: I have a 60 watt "Compact Fluorescent" bulb over the kitchen stove. Not impressed. Once it comes up to full light it's fine..BUT It takes forever to come up to full light. The LED is Instant. |
#13 | |
Some math... Electricity around here is about 13 cents per kilowatt hour "all in" (meaning, factoring in taxes and all the other costs beyond the raw KwH cost). A 60 watt bulb is ~1/16th of a kilowatt (duh!), so it costs 1/16th of 12 cents per hour to operate, or about .07 *cents* (less than 1 cent) per hour. Your payback on an LED bulb is about 10 years in normal use (figuring lifespan relative to replacing incandescent bulbs, and the power savings).
[insert witty phrase here] |
#14 | |
2 years+10 weeks. This is assuming NB leaves his light on 24 hrs/day and does not include the added savings of replacing blowing incandescents. |
#15 | |
10 years = 3650 days. 3650 days * 5hours/day = 18,250 hours of operation over 10 years. The replacement cost is harder to factor. The LED bulb *should* last that entire time, though you'll be approaching the point where its light output is probably starting to fade noticeably. An incandescent bulb lasts about 1500 hours, so you'll be on your 12th bulb by that point, having spent about $8 on bulbs, depending on how/where you buy them. That could put the breakeven point closer to 5 years. In either case, don't buy LED bulbs for anticipated cost savings...
#16 | |
Much better then CFLs for looks, warm up time, and color spectrum... - PIG weather aside, last weekend was beautiful on the island, and yesterday Misty Blue came by to help harvest firewood for the winter, we are ready! p.s. Thanks to NB I purchased the LED worklight from Home Depot... already has several hours of usage on it, and the magnetic base is really useful! Last edited by Pine Island Guy; 11-12-2013 at 10:15 AM. Reason: the p.s. |
#17 |
Yeah, you can't put a price on a fear of heights
Here is the bulb I bought. It is "dimmable". Although that wasn't a requirement for my application.
NBhttp://www.amazon.com/GE-Lighting-68.../dp/B00AC7RBEO |
#19 |
Try Home Depot - they have the cheapest LED lighting with the NHSAVES program. The Cree LED bulbs I have found are really cheap, and work really well.
Also note: don't put LED bulbs near certain types of garage door openers. The switching circuit from AC to DC is very noisy and will cause interference. I found this out the hard way. Cold weather seems to make it worse.... I thought someone was jamming my garage door opener in the morning but not at night. Turns out the lights were on when I left in the morning but weren't activated by the motion sensor in the afternoon when I got home so it would work. |
#20 | |
Maybe the NSA is ...... ....
#21 | |
My kitchen lights are on 18 hrs/day, the center of action. My bedroom light is on maybe 5 mins per day.. Err, check on that one
