Old 08-14-2013, 08:39 AM   #1
Pineedles
Pineedles's Avatar
Default Currents in the lake?
I was wondering if currents exist in the lake? Aside where the damn(s) are built, but does the lake "flow" in a certain direction, where even slight movement of debris on the bottom gravitates towards a certain point?
Old 08-14-2013, 09:39 AM   #2
Coolbreeze
Default Flow
There are currents on the lake that are caused by the movement of the lake level by the release of the dam in the spring and fall; but these currents are more pronounced in areas like the channels into the back bays. Out on the broads the currents are usually wind driven. We call them the drift factor rather than a current factor. I'm sure there are places on the lake where the water moves more than in others due to natural spring activity or river/stream influence. There are no tidal flows like the ocean nor do I know of any natural currents due to the moon, gravity etc. Hope this helps.
Coolbreeze is offline   Reply With Quote
The Following 2 Users Say Thank You to Coolbreeze For This Useful Post:
Pineedles (08-14-2013), soupyjr8 (08-14-2013)
Old 08-14-2013, 09:42 AM   #3
Coolbreeze
Default Wind
To add more, the wind and air does impact the lake. Debris that falls into the lake that floats will drift from the southwest down to the east eand of the lake due to air movement of the water. If it sinks, the currents from the wind general become less in deeper water, if at all.
Old 08-14-2013, 01:41 PM   #4
Pineedles
Pineedles's Avatar
Thank you Coolbreeze. The reason I asked was that another member was having difficulty with muck and rocks in their beach area. We built a stone wall, many years ago as kids, underwater running perpendicular from the shore out about 20 feet. The "wall" wasn't more than 10" - 12" high, but I believe it helped create a nice sandy area downstream of the wall. Since the water depth wasn't more than 3 or 4 feet perhaps the wind/wave action kept the area clear. Thanks again, I hadn't even thought of wind action having an effect.
Old 08-18-2013, 09:07 AM   #5
Coolbreeze
Sure there are ways to manipulate the "water motion" around docks and breakwaters with the use of stones and boulders. The rocks and boulders can be carefully placed to trap sand. There is no way to explain it other than saying you just have to tinker and see what works, it's kinda fun to see from season to season.
This page was generated in 0.06553 seconds
