I am amazed how many people purchase a 60 to 100K boat and then try to use a $25 Wal-Mart anchor to hold her in place. I was a Sleeper's Sandbar today for most of the day and I am amazed at the amount of folks that came in, in the windy conditions, and tried to anchor with these cheap, crappy anchors, no chain on the rode, way too little scope, and then look around surprised that they are dragging their way downwind into other moorings. I saw at least a dozen boats do this, some stayed with some help from others and many just gave up and left. I also love when they only have one anchor, usually on a clothes line or a couple dock lines tied together. The rode sometimes comes out in one big knotted mess, which they do not figure out until they are already in place and started their drift into their neighbors.
Windy conditions and a busy sandbar in not a great place for these noobies to be cutting their teeth. I have not seen any serious damage caused by the drifting chaos but it can sometimes lead to high frustration factors. |
As a newbie boater, I would love constructive advice in that situation. We all have to cut our teeth somewhere, and some of us are very eager to learn.
| The Following User Says Thank You to Aguamenti For This Useful Post: | ||
GsChinadoll (08-15-2013) | ||
I use two 14 pound fluke style and each has about 5' of chain (no issues so far). The use of chains is a must and makes a world of difference. I also get out and check that both anchors are actually set good; I see many people do not do this. Part of the problem is a lot of dealers (mine included) only give you the rode and anchor with the purchase of a new boat and say that's all you need. You would think of all people they would know better. I learned about the use chains from reading forums like this one.
The problems you are describing don't seem to be caused by the anchor. More like rode issues and operator incomptence. Many occasional boaters don't realise that an anchor by itself is less effective without the weight of a chain or cat weight to help it bite into the bottom.
Some things I have learned that some may find useful.
Ground tackle - two anchors for sandbars, one bow one stern. - decent anchor sized right, I use a fortress danforth type on the bow and super hooker danforth on the stern, both sized one size larger than recommended. Cheaper, smaller anchors can work but rely on perfect technique and some luck. In high winds or a storm, you'll be very happy with your quality anchor, oversized one size larger than recommended. - chain, necessary for weight and rode angle to help the anchor set quickly. Also helpful to protect rope from scraping on rocks. I use 20' on the bow hook and 6' on the stern. I would say 6' minimum for the bow, 10' is better, one boat length is even better. The chain not only helps set the anchor but also keeps it set better in wind and waves by acting as a shock absorber. As waves hit, the bow lifts, as does the chain. This eases the shock of the wave on the anchor set, reducing the chance of pulling the anchor out of set before you are ready. Use good marine chain from marina recommendation. - anchor rope, 3/8" minimum, 1/2" is better. I like the 1/2" not for strength, but for ease in grasping and pulling. Three strand nylon is good choice. I would say 250' minimum for safety (if needed in deeper water) but 350' is better. - Note, The anchor rode may save your boat and health if you loose power in storm and need to stop dangerous drift. - I also marked my anchor line with 25' indicators to let me know how much line I have out. 3 times depth is minimum, 5 is better. Technique - if the bar is too crowded, especially if windy and you are not experienced, better to anchor (practice) somewhere else. - have both anchors ready before approach, no tangled lines or anchors buried under toys and coolers. - be sure your desired spot is clear of all swimmers, especially kids. If not, please wait for spot to clear. This is especially important when backing you boat into position. - bow anchor is positioned up wind from your desired position. This anchor holds you position and does most of the work. Stern anchor is only there to prevent swinging into other boats. - align yourself with other boats already anchored. They will have positioned themselves bow to the wind and waves. - drive or back in until bow is over desired bow anchor position. - showily lower anchor allowing anchor to touch bottom before chain. Allow wind to push you backwards, or slowly power back into position. - tie off anchor line, typically about 20 to 25' behind bow anchor at sandbar depths. - now allow wind to push boat back driving anchor into seabed, or gently power back to set anchor. Idle speed only, easy bump into reverse. - with decent anchor, chain and adequate scope, you will feel the anchor grab the sand bed and stop the boat with a solid stop. Your bow anchor is set and you are 90% home. - lower anchor off stern. Get in water, walk stern anchor back around 15' back, lay anchor, tighten anchor line leaving a bit of slack to allow movement with waves but not movement swaying boat closer to other boats. - lastly, check that both anchors are buried into bar bed and holding with a solid purchase. Departing - prep boat for departure. - pull stern anchor and manually hold boat in position - if clear, get in boat, manually pull boat up over bow anchor and pull straight up. It will be buried, especially on windy days. - if not clear, manually pull bow anchor while holding boat in position. Temporary stow anchors and rode while you idle out to deepens water. Once clear, stow anchors, lift ladders, etc. Hints - two experienced boaters working together make all of this look very easy. Alone is doable, but takes skill on a windy day. - relax, panic will not help you or you temporary neighbors. - do not throw anchors. Lower them slowly and controlled. A thrown anchor has a good chance of chain or rope fouling set into bed and makes you look inexperienced to others. - be curtious, if someone has been there since 10am, they are not likely to be too happy if you show up at 3pm after already crowded, and position right against there boat. - please do not drop your anchors right off the swim platform of another boat. Also, do not cross your anchor lines across other anchor lines. It is rude and can be unsafe. |
#6 | |
It is common to see these cheap anchors paired up with no chain, too little scope and perplexed looks when it does not hold. |
Forgot one additional thought,
If your neighbor is struggling, smile and offer to help. If your struggling, smile and ask for some help. It is a good way to meet you new neighbors. |
VERY WELL put NH Boater .... (in both Posts !! )
Kudo's .
Easiest way to anchor is to just tie onto NH Boaters boat.
Always here to help
I'm always amazed at how many people show up to the sand bar without a rear anchor.
In addition, simply dropping your rear anchor off the stern accomplishes nothing. Get in the water and sink it. |
The thing is, if you are new to sand bar anchoring, o boating in general, how would you know that you needed 2 anchors?
Getting ready for winter! |
We are all newbies once. My first trip to any sandbar was Winnisquam. Pulled in, dropped my only anchor, saw everyone else had two as I held my stern steady. I quickly left and bought a stern anchor on the way home. Problem solved, except the stern anchor was a grappling hook style that never held in any breeze at all. Talked to some folks, read a little, bought a super hooker one size oversized. Problem solved.
I am pretty tolerant of those that are obviously new, as I was once too. Funny that some of the boats having great difficulties I have seen at the same sandbar for four years. I won't identify them but one has two anchors that are too small and poor design, never drops enough scope and constantly swings and drifts into other boats with any breeze at all. I have helped them off my boat a few times, politely showing them to drop more scope and to consider a larger, better anchor and a chain. Here that are again this year with the same setup and same difficulties. I hear the wife complain and he just says that he cannot understand why their anchor won't hold the boat. Says anchors do not hold well on sandy bottoms. Forget the fact that no one around them is drifting or dragging. Then there is the guy that gets into position with no prep and then starts to look for his anchor. I had to jump in one day and quickly run around to keep his performance cruiser off my boat in the wind while he obliviously fought with his locked anchor locker. He was drifting into us, looked up, saw it, and just calmly continued to attempt to get his anchor. He would have 'slammed' into us if I did not jump in. Even if he got the anchor out, it was way too late to stop the drift. No problem, I positioned him, set his anchors and we talked for a bit. Feeling good that I helped a newbie who needed it. He did the exact same thing the next day to another boat. Then the same the next weekend and twice more (that I personally saw) last year. Probably a >100k boat. I cannot help but think how someone can do this, at the complete whim of others to protect a collision, again and again. It is pretty ease to do a little research and be more comfortable with your boat. Very little effort. |
Some people just aren't interested in doing things like that correctly. I imagine they are the same type of people that hang out in the left lane on the highway oblivious to the fact that they are behaving rudely.
I seriously doubt the repeat offenders would ever read a thread about how to anchor on a boating forum... |
I agree Dave.
#16 | |
Sandbars were a lot of fun when my kids were kids. Now that our kids have blessed us with grandchildren, sandbars...well not so much.
#17 | |
As an extremely new boater I really appreciate the information in this thread. We certainly want to do things the right way and will find a nice quiet place to practice these techniques before invading the sand bars
![]() One question. If you feel/hear your bow anchor scraping on the rocks and it doesn't seem to be holding perfectly what is the best way to take care of this. Pull up the anchor and try to reset in a different position ? As for the stern anchors, how do you exactly 'set' the anchor ? |
#19 |
NH Boater -
Don't judge an "anchor line" by it's size ![]() I got turned on many years ago to using "sail (mast) Line", it is only about 1/4" in diameter but has a 5,000# breaking strength. The down side is their is absolutely no "give" in the line. Being in a relatively smaller boat (23') space/ storage is paramount. With this line we can easily accommodate 125' on one of those Home Depot power cord storage reels and stow easily when we depart. (yes, we carry a stern anchor too) As for "chain" I have used chain, but quite frankly find no extreme benefit on Winni for some reason ! I know all the claims that it is heavy and lays flat on the bottom to better set your anchor -- but -- I seem to have the same luck with or without. Finally, Aguamenti -- don't fret .... Even the supposed "Seasoned Pro's" have to set & reset at times. Setting an anchor is 25% pure luck. I have seen 32' Cruisers slipping their anchors at sandbars and that's a treat when your a 23' next to them !! .
#20 |
I have 40 Ft. of chain and 150 Ft. of rope on my 258 Vista cruiser. have no problems setting anchor at the sandbars
dont worry be happy
