So I am getting ready to re-institute my lake water system to provide water to the camp. The reasoning for this is that sharing a well, has come at to high a cost, and as I didn't pay for the well, and really have no financial stake in it, I am opting, to stop sharing my neighbors well, and will go back to lake water.
To that end while I still have the pump and pressure tank saved, I don't have the line to the lake anymore. So I need to get a new main line a foot valve. I was looking at doing this with PEX tubing, and thought I would see if anyone has done this. I figured it might be better and easier to work with then the heavy black pipe that we used to use.
I'm pretty sure that PEX is not any good if exposed to sunlight. Most plastics need protection from the UV in sunlight. PEX is made for indoor use and doesn't hold up.
Pex is for use inside a building and not rated for exterior use. Because of the exposure to UV sunlight and run across the ground or underground where it could be crushed you need the heavy walled black water line that you used before.
Just Sold ![]() At the lake the stress of daily life just melts away. Pro Re Nata |
Everyone is right, Do not use pex piping where it will be expose to sunlight. What I have done in the past was bury the pex pipe between the pump house and down to several inches below the low water line. I usually leave the pipe in year round relieving the pressure during the winter months by dismounting the pipe at the pump. After several years, you will fine the pipe will harden and crack. I simply replace the pipe with a new one.
I never had trouble with the ice in the winter. I believe it freezes inside as well as outside the pipe so there is even pressure, preventing the pipe to burst.
You really should use the black polyethylene piping. I cant remember all the reasons but they are many
#6 | |
We had a well dug last fall and removed our lake line. I saved the black plastic pipe and would be happy to give it to you if you want it. If I remember correctly, we have about 25 or 30 feet.
A standard 1" black plastic tubing is commonly used, matter of fact that is what most wells use between the well pump and the house. You can get that stuff in the plumbing section of any home depot or lowes. It's not terribly expensive for a 100' roll.
One suggestion I would make to you is if you're going to do this help yourself out and make the system easy to break down or put together. I just ordered some cam locks a few male/female pairs with plugs (for winter time) so when I assemble or disassemble my water lines I'm not screwing stuff together, messing with clamps, or otherwise needing tools. These things are awesome, female on one end of a break, male on the other. They just lock the levers in place and pin insert lock pin, instant water tight connection. Easy and hassle free. Well worth the investment. I swore when I took my water system apart this past fall I would fix it so it wasn't such a pain in the neck next time. They are inexpensive and well worth the money, here's where I got mine.. http://www.globalindustrial.com/g/pl...mlock-fittings Best thing I ever bought can't wait to fix my system for good. |
| The Following 2 Users Say Thank You to MAXUM For This Useful Post: | ||
HEP170DW (04-25-2013), Slickcraft (04-22-2013) | ||
#9 | |
• Remember that polypropylene pipe will float, and attaching a brick every six feet will keep it from being a nuisance—to fishermen. ![]() • I used a nylon cable-tie and a twist of heavy copper wire on each brick. Only the copper has endured the years. ![]() • 'Wish I'd known of this brick's availability back then: ![]() ("Hollow Partition Tile") ![]() More: http://www.winnipesaukee.com/forums/...ead.php?t=3401 |
| The Following User Says Thank You to ApS For This Useful Post: | ||
GreensKeeper (05-08-2013) | ||
That's a great idea, those look like clay flue tiles they use in chimney construction. You can get concrete footing blocks that are similar in design as well that may stand up better over the long haul submerged in water.
As everyone knows, water expands about 10% when it turns into ice, and will crack the standard black 1 1/4" diameter black poly flex tubing. For more money, one can get a high-pressure black poly tubing that expands and does not crack when the water inside it freezes and still works with no leaks after the ice thaws out.
Gilford Well sells a waterline heated cable made either by Pyrotennax or now by Tyco that includes a hi-pressure black poly tube of, for example, 100 or 150' length, an inside-the-pipe heated cable, and a 220-volt control box with a thermostat sensor that will turn the heated cable inside the black tube on & off depending on the thermostat which gets placed into the yard outside your cottage. A set-up for 125' runs on 888-watts. And, of course, the pump and water tank needs to be kept in a heated space, like in the kitchen near the kitchen sink or somewhere. I installed one of these systems back in 1992, and it has worked perfectly ever since because I am the greatest waterline installer ever, ever, ever, in the world history of water! ![]() So, if I can do it, maybe you can too, but I seriously doubt it?
#12 | |
Another trick that Misty Blue taught me was to install a boiler valve close to the water's edge... great to drain down in the fall and then hook up a small pump to in the spring and prime the entire system. Think ice out!!! -PIG |
#13 | |
Well of course I used the regular black pipe, and everything went swimmingly... I found a heat gun which I already had, helped with those horrible connections that I used to remember struggling with.
The biggest aggravation of the project was wondering why I had ever stopped using the system...
I'd be interested in hearing more about 3 way connection at lake end, so I can prime system..And a small pump to connect to it... (Buckets from lake...Not so fun
"Honesty is the best policy." |
Did that this year after reading about it on the forum last year. Worked real slick. We had a kitchen faucet open and when water came out we shut the faucet and the boiler valve at the lake end, shut the small pump off, turned on the main pump and watched the pressure dial ramp up. Done.
| The Following User Says Thank You to Slickcraft For This Useful Post: | ||
dayvsea (05-07-2013) | ||
#17 |
Slickcraft can you supply a link to the valve?
Here is a link at Lowe's:
http://www.lowes.com/pd_248921-33599...lve&facetInfo= I also bought a T to insert into the 1" black plastic pipe that the "boiler drain valve" screwed into. Most small pumps have a male garden hose type fitting as does the boiler drain valve. To connect the two you will need a short section of hose with a female fitting on each end such as a washing machine connection hose. BTW when I asked the Lowe's plumbing clerk in training for a boiler drain valve he was sure that they did not carry such an obscure item. Then the senior clerk walked over and right away led me to the item, then spent a few min talking to the in training guy. Last edited by Slickcraft; 05-07-2013 at 12:13 PM. Reason: add comment |
#19 |
Yah, at HD, you need to skip the 15 year old clerks and go right to the head 17 year old managers!
Thanks, Slickcraft, I'm on the hunt for parts!
#20 |
Hay Fatlazyless.. "a high-pressure black poly tubing that expands and does not crack when the water inside it freezes". Do you have a brand/supplier on this? I think I can use the speedy disconnect in the above posts, and your tubing, and leave the business end in the lake..Maybe... Let me know when you can..
