I know the question has come up before, but I was wondering is it possible to get an inexpensive good GPS that uses the Bizer information. I have never used GPS, but every time I come back to the marina from a night trip I get the question did you use a GPS. I am not sure if I really need it, but wonder what kind of investment I would need to make to get a useful one.
Thanks in advance Bill |
Two cheap options I am aware of:
NAVMAN 5500 at $450 or so and Standard Horizon CP 155C at $500 or so. The NAVMAN can be purchased with a built in antenna which dramatically simplifies installation but requires an open cockpit boat to work well. The SH has an external antenna which can be a real pain to mount and mounting hardware is not free so expect to pay a bit more. The SH has a lower profile and may be better suited to some crowded helm stations. The NAVMAN comes with a better mounting bracket that swivels as well as tilts. The SH only tilts. I went with the SH because the NAVMAN would have blocked my tach. It works extremely well and I will never have another boat without a chartplotter. Running at night is totally unstressful, even through trickier bits of lake. Gunkholing at any time with utter confidence is fun too. Bizer has done a wonderful job with the chart and I have visited parts of the lake I was always a bit nervous about before having GPS on board. |
I have a Magellan Meridien Color handheld GPS (Online runs about $330). Added Mapsend software for street level and topgraphic detail ($110+/-). Added Bizer waypoint file ($29) for a total of roughly $466. Now, this is NOT a marine chart like the C-Map Bizer full scale maps, so you can't go blazing around the lake at night in unfamiliar waters and assume every thing in your path is mapped (some chucklehead used a land based GPS at night and ran into Parker Island some years back as I recall!). However, if you use the track feature to mark your routes and take advantage of the waypoint file, you have a functional GPS for a limited purpose such as yours. I use mine primarily for fishing to track speed and location but have set routes for common trips as well, just in case of foggy or night travels. Not sure you even need the Mapsend software since the basic unit has resident maps on it. I hike as well and wanted the topo detail so bought it with the GPS. The nice thing about a handheld is you can use it for other non-marine purposes as well. Works great for me.
Bill...
I have a 2yr old Standard Horizon CP-150 I will be willing to get rid of cheeep. All you will need to do is intall it and get the Winni chip... $225 I got a good deal on a CP-160 model. Woodsy |
I have an older Magellen model 410 and have the Mapsend Lake Winnipesaukee map. It does a really nice job, but has no Navaid (buoys) info. I therefore bought the Bizer Waypoint file and installed it. It has a lot of great information. You should be able to also add additional waypoints as needed for the areas you frequent. For me, it was the black tipped spar off the SE end of Treasure island. I keep my boat at West Alton, and returning from Wolfeboro or Alton at night or in the "gloom" can make spotting this spar interesting. Sooooooooo, I just sidled up next to it one day and established my own waypoint for this spar.
A nice feature with the Bizer Waypoint file is the "safe passage" waypoints he put in, such as by Sandy Point - Echo Point - Little Mark in Alton Bay, and off the eastern end of Rattlesnake, I believe the area between Rattlesnake and Diamond has one... Learning these waypoints, coupled with common sense and the chart, navigation is a lot easier. As I have said before...thanks Bizer!. Also, most GPS units create a visible track, so if you are returning the same way you came, you can follow the "cookie crumbs" you left on your way over/out there. Biggest thing though is the common sense, and don't rely on the GPS alone. Always know where you are at, and know that you can continue if the GPS goes out. Whatever way you go, fancy or plain...Have fun .
I have the SH CP150c, which is the predecessor for the 155. The screen is a little small but that's my only serious gripe about it. If you get the SH, be careful of the co-ax mount. If the locknut loosens you will spin the bolt around and break the internal wires. They are good and fast about repairing under warranty and their help desk is helpful.
I've got my antenna mounted to the front bow of my bimini. I could have spent $20-30 for a special mount but got a threaded PVC "T" and a threaded reducer coupling at the hardware store for >$5. I did paint the thing to protect if from UV. A couple wraps of tape took up the slack and there was a little sewing involved. (editted slightly because I was at work and rushed to close) Last edited by Kamper; 09-08-2005 at 09:06 PM. |
#7 | |
DRH |
#8 | |
#9 | |
DRH |
My boat and consoles are aluminum. If I had a glass boat I might have hidden the antenna but I decided a better signal was worth the effort.
Thanks Woodsy I will keep that in mind. I am still trying to decide if I really need it.
Bill. Get one. Just do it. You will NOT regret it.
Do you *need* one, no, probably not. But you will never be without, once you have it. Trust me. As for units, I have the Navman 5500i. Works great. I wish you had asked sooner because there was a GREAT rebate on this unit through the end of August. It basically cost me $315 for the unit, no external mountings, just add the C-map. As Dave said, the best part about it is that it's just power and ground to install (he knows, because he helped install mine!). The best price I found for the Navman was $489. The same place sells the Standard Horizon for $571. Both are great units, and Dave listed pretty accurately the advantages and disadvantages... But buy one. |
I also bought the Navman 5500 with the $175.00 rebate and paid well under $400. Bought the Bizer C-map chip and I have been really pleased with it. The unit has great color graphics that can be seen in direct sun and is very easy to use and quick to hook up. Takes alot of stress off of boating especially at night.
What is there out there for GPS software for laptops, and is Bizer chartplotter software compatable? I already have a laptop on the boat and I have seen GPS software with USB port reciever. Would seem if Bizer chartplotter is compatable with the GPS software, that would be cheaper than a new complete GPS unit. With the advantage of a larger screen. Any thoughts?
I had this on my last boat. Color and very easy to use. One of the cheaper ones out there. B&W is even cheaper.
I liked it though. Boat US was the best price
Wendy "Wasn't Me!" |
Aqua,
Check out Bizer's GPS page. They do sell a waypoint file, and they do have graphic images of the lake available, and a chart kit for maptech software... Using those, you might be able to get something running on a PC and use the GPS to plot your position... ...Jim |
#17 | |
http://www.oziexplorer.com/ http://www.fugawi.com/
Mee'n'Mac "Never attribute to malice that which can be explained by simple stupidity or ignorance. The latter are a lot more common than the former." - RAH Last edited by Mee-n-Mac; 10-19-2005 at 04:13 AM. Reason: corrected spellin, added URLs |
If you check out Bizer's web site, he is checking on interest in porting his map data to Garmin-compatable format. These handheld GPS units can be used in the car, for hiking, and in the boat and have come down in price significantly. The portable flexibility means you can buy one unit and use it in any boat, car, or on foot.
The default map data on these units do not accurately show all the islands, so the ability to import Bizer map data would be great. If there is any interest in getting the Bizer map data for Garmin, please make sure you let him know or it won't happen. Here's the link to the info and how to respond...... http://www.bizer.com/ |
#19 | |
FWIW : I looked for, but never found, a program to take a bitmap chart and turn it into something a Garmin GPS could load and understand. I'm a little surprised that someone hasn't hacked Garmin's proprietary format but I guess there's just not that much demand. I hear Garmin's Bluewater charts are comparable to the competitors. It's us marginal people who are getting left out because the market for Winni (or other small lakes) is apparently too miniscule for Garmin to bother with.
#20 |
ThePlut,
Thanks. I sent a note to Tiger GPS to see if they are still giving the rebate. I know it says 8/31, but it is on every site. It is worth a shot. How is it with the C map? Thanks Bill |
#21 |
It really is killer. Having all the details of the Bizer map at your fingertips with your exact position and course plotted right on it. My mounting location blocks part of my speedo, but I use the speedo in the GPS now more than anything.
I haven't taken the map out of the glove box since I got it. |
