Hi! A former student has made an electric trolling motor contribution to my son's first boat project, but I'll need a battery/charger. Would I use a 12v trickle, regular car battery charger, etc.? Is a solar charger reasonable $? And what type battery would I be looking for?
Thanks! Sent from my SM-G950U using Winnipesaukee Forum mobile app |
#2 | |
Any deep cycle battery can be used. Any 12v charger will work but get one that charges then “floats” so it won’t overcharge. (I think today’s chargers all have this protection) a good investment would be a “Battery Tender” if you want to keep the battery charged and ready for action, and it will maintain your battery over the winter.
I have used the Schumacher brand charger for years with good luck but there may be more or better brands out there. I use a solar Battery Tender for my UTV and it works great. I have the solar panel on my shed and it maintains the battery year round. The BT brand is a bit more but there are Chinese ones on Amazon that will do the job. Lol...while I was typing so were others... |
#4 | |
And this charger? https://www.amazon.com/DieHard-71219.../dp/B077742Y1H
#6 | |
As for the battery, just get any “deep cycle” Not sure if the one from Oreilly is a deep cycle or a high cranking start battery. |
#7 | |
Thoughts on the battery I linked above? The person giving it to me said he used to use an old car battery, so I don't think it's very powerful. Sent from my SM-G950U using Winnipesaukee Forum mobile app |
Any 12v battery, car, marine or otherwise will make the electric motor run.
It’s the repeated charging and discharging that a deep cycle battery will handle better than a cranking battery. |
#9 | |
Hillcountry (09-29-2019) | ||
#10 | |
https://www.batteriesplus.com/produc...iABEgJX7_D_BwE Dan
Ok, I think I might just hit up Batteries+. This is $80 after discount, and it looks like I can find a charger there within a few dollars of Amazon's.
https://www.batteriesplus.com/produc...ultra/sli24mdc Sent from my SM-G950U using Winnipesaukee Forum mobile app |
#12 | |
thinkxingu (09-29-2019) | ||
#13 | |
And I'll confirm it works with AGM as well. Y'all are the best! Sent from my SM-G950U using Winnipesaukee Forum mobile app |
#14 | |
Just thought you should know... Dan
#15 | |
#16 | |
#17 | |
#18 | |
#19 | |
#20 | |
I hear ya....but a lot of AGM batteries are installed in boats these days because of their extreme low self discharge rate, their ability to take abuse, and they are spill proof. They also charge much quicker than a lead acid battery. However they are sensitive to overcharging and why you need to be careful on how you charge them if and when needed. All my boats now have AGM batteries in them... Dan
#21 | |
Anyone have an idea of the rough amount of time these things run on a single charge? Sent from my SM-G950U using Winnipesaukee Forum mobile app |
#22 |
Scratch that--just found this. I think 75AH with a smaller motor would be fine--at least 2-3 hours and more likely longer. I'll look at the specs when I get the motor.
#23 | |
#24 |
AGMs are lead acid batteries too, but they are different than the more common FLA (flooded lead acid) in that they are maintenance free and don't like overcharging (which is something you should periodically due to FLAs to equalize them). They both recharge at roughly the same rate, but AGMs can be left in a partially discharged state for a long time without the sulphation issues seen in FLA batteries. This feature is irrelevant if you are putting the battery on a charger overnight or longer after every use.
Don't discharge your lead acid battery below 50% capacity, it will damage it and reduce the lifespan of the battery. Thus, if you calculate that you need 100 AH of battery capacity, buy 200 AH of battery and consider 50% depth of discharge "empty". |
| The Following User Says Thank You to Dave R For This Useful Post: | ||
thinkxingu (09-30-2019) | ||
#25 |
Since you wrote "INEXPENSIVE" in your original post, don't buy an AGM battery. They are awesome, but the benefits they offer will likely be irrelevant for your application thus they are not worth the extra cost IMO. AGMSs are great for situations where the battery cycles through partial discharge and partial recharge cycles most of the time. I cannot fathom that happening in your application. You will very likely have plenty of time to recharge. You should just get a regular flooded lead acid battery and keep it on a charger that has a float phase every time it's not being used.
AGMs are popular for people that spend a lot of time anchored and not connected to shore power. In this use, they are often discharged to 50% state of charge and re-charged to around 80% (end of the bulk charge phase) state of charge. To get them above 80% SOC, you need to go through the absorption phase which takes a really long time and most people that anchor out multiple days in a row don't want to run a generator that long. Leaving them at 80% SOC does not hurt an AGM like it does a flooded lead acid battery. |
| The Following 2 Users Say Thank You to Dave R For This Useful Post: | ||
#26 |
I ended up grabbing the 90AH battery and this charger: https://www.batteriesplus.com/produc...ultra/slc10004.
The 90AH should give L'il Buddy around 2-3 hours at max, which is plenty (of actual run time). He can row, otherwise! The charger was a bit more than I wanted to spend, but it does 6 and 12V, AGM, and a reasonable 3.8AH charge rate, so we can full charge overnight (given 70% draw). Thanks for your help! Sent from my SM-G950U using Winnipesaukee Forum mobile app |
