#1 | |
...and running into roadblocks from the zoning board. The subdivision is proposed for the area between 28A and Rt. 28 between the cascades and Swan Lake Trail off of Rt. 28 on the east side of the bay. There has already been some building in this area (Sanctuary Road) clearly visible from the west side of the bay (from Alton Mountain Road) as well as a lot of ridgeline development from the bay up towards Wolfeboro. This area from 28A up to 28 is steeply sloped indicating potential problems with rainwater run-off and sewerage finding it's way down to the BIG LAKE. The link below shows a Google Satellite map clearly indicating Swan Lake Trail, but I am unable to locate Austin Road.
click here for GOOGLE SATELLITE MAP Quote:
Well, I'm not sure how that really differs from the 53-unit "elderly" housing project that will go in on Route 140, just above the Irving station, that will be on only 14 acres. The land was clear cut about a year ago and construction hasn't started but it was approved and all the standards for approval were met.
Here you're talking about 42 homes on 102.5 acres - that's a far batter ratio. Plus they're single family homes; that's better than "units". The drainage and runoff issues are certainly a concern. I question if the septic standards can be met and if the houses will receive town water. That being said... It is my opinion that Alton is one of the better planned towns around the Lake. I believe the members of the Planning Board are well qualified and they give due diligence to every case that comes before them. Alton is a unique town because of our location, low taxes and standard of living. I believe the Planning Board is aware of this and wants to preserve this but at the same time, allow change to happen. This will, no doubt, be an interesting case to watch. At least it's not another cell phone tower case.
Hopefully the town will stick to their guns and keep this from happening. Significant issues appear to come into play based on the concerns of the Board. The "view shed", as they put it, is already significant with what has been done in that area to date. (Being selfish as I own property on the other side of the bay). Regardless - do we really need 42 new homes in the bay? Especially with this economy – how long will they “sit” unoccupied? Do we need them packed into that small of a space with less than 2.5 acres per home? In Alton is there a minimum lot size requirement for a single family home? (I assume that is not an issue here as the Board did not mention it).
My part of town has it - going up Route 140, the last house to get it is just before the Doll Museum. The school, town hall, and up to the circle (I think) all receive town water. I do know that Riverside Cemetery is watered with town water.
======= Lakesnake - As I understand it, the application wasn't complete. The Board doesn't start officially reviewing the details until all the criteria of the application (administrative process) is found to be complete. Things like acreage, set backs, etc. would be reviewed after the application was accepted for review. (Accepting an application and approving an application are two totally different things!) |
Thanks Argie's Wife - I am certainly no expert on these things but will keep my ears open on this one.
#7 | |
We get town water at Sandy Point; however, since the water lines run above ground at the bridge over the Back Bay, the water is turned off around 10/15 - 10/20. If you live west of the bridge on Rte. 11 you need a well to live there year round.
From the town's website:
Today the Alton Water Works supplies approximately 700 residential and commercial water services in the Alton, Alton Bay area and also supplies water to and maintains 55 fire hydrants. As a townie, I'm glad I don't have to have a well. My house is grandfathered in on 0.33 acres, with about a 10' setback from the road and I don't know where we'd put a well! |
We also get town water on the summer plan. I don't know if it runs past us up Rt28A. Our neighbor has a well but that could be by choice.
Town water: The shiny cover just north of Bay Hill Rd & Rte 28 is a storage tank. The water area going out rte 11 westbound goes to Boat Cove, and GH, you're right, west of Back Bay bridge, it is seasonal water. It goes up Rand Hill Rd to the Advent campground, and all the cottages therein, and I believe down Spring street (not sure here.). Out 28A to about abeam Sandy Point (M&M, you could be close to the last of the service area. Uptown and out Rte 140 as Argie's Wife pointed out.
A lot of the pipes are old, and need replacing, keeping the water dept pretty busy. Pumps are behind Jones Field, Levey Park, and I believe next to the water dept, next to the fire station on 140.
#12 | |
I am having trouble figuring out exactly where the property under consideration is located. If I read the story correctly (but I confess I couldn't read it all), it is lakefront? As far as I can tell from our trips from Echo Point to the bay, there isn't any lakefront left. The only undeveloped property I can see are the camps (Kabeyunk, etc.)
nj2nh
#14 | |
I find it hard to believe that no one else has questioned the validity of speculative development in this economy. Building starts are down, banks aren't lending and mortgages are not being written. It is pretty apparent that this is a non-issue. This economy is the answer to bad zoning, over crowding, water runoff and setbacks. |
#15 | |
