Old 01-14-2008, 10:50 PM   #1
Rinkerfam
Rinkerfam's Avatar
Default Photo question
I have a photo that I'd like to insert into a new post. The problem is that the file is too big to be accepted. How do I handle this? Thanks in advance for any help.
Education is hanging around 'til you've caught on - Frost
Rinkerfam is offline   Reply With Quote
Old 01-14-2008, 11:21 PM   #2
trfour's Avatar
Post In The Site Support Forum
This should help you.
http://www.winnipesaukee.com/forums/...6551#post46551
Old 01-14-2008, 11:48 PM   #3
Default a little work
Depending on what you have on your computer to work with photos, you can resize the photo, making it smaller (3" x 5") for instance. You may also be able to change the resolution by adjusting the "JPG" setting (JPG is the file typ for a JPEG file that most of us use to email photos, post photos, etc). And you may be able to save the file to "web", which really cuts down on the file size.
I have Adobe PhotoElements, and can work very nicely with pictures. Realize that a photo to fit into this frame that I am typing on doesn't have to be much wider than 5 inches to fill this frame. After adjusting the size, click on "file" then go to "Save as", and you will be able to save the newly sized photo (rename it xxxxxxx2) or some other name from the original. Perhaps when you go to save this new picture, it will also let you select the JPG option, low or medium or high or maximum. I would select "medium" and hopefully that will allow you to post your picture. If you can "save to web", that will be even better, but not a necessary thing.
Good Luck.
Old 01-15-2008, 12:42 PM   #4
Are you talking about the file size to big to handle or size as in dimension size?
Old 01-15-2008, 06:04 PM   #5
jeffk
jeffk's Avatar
Default Faststone Image Resizer - Nice tool (Free)
This link is in the other thread (I believe SteveA posted it) but you have to search around a bit for it.
FastStone-Photo-Resizer
Faststone also has an image viewer. Both very nice tools.
For the resizer, shrinking the pixel resolution will shrink the file size at the same time. From the initial resizer screen navigate to your photo and then select the "advanced options" button. Then click the "Pick a standard size button" and pick a pixel resolution. I have found that 800x600 usually gets the file small enough (pixel resolution and file size) to include in a forum post. You may want to specify an "output folder" so that files can be converted without overwriting the original. Then hit the "Start" button.
This is obviously a simplfied walk through of the Resizer but its pretty easy to use. Lots of options and choices if you want to get into it more.
The photopost section is much more generous in the resolution/file size allowed.
This page was generated in 0.23146 seconds
