Old 05-23-2007, 01:06 PM   #1
Default ...getting rid of old gasoline?
Am stuck with about one gallon of three year+ old gasoline with two-stroke oil mixed in. It looks and smells like today's regular three dollar gasoline except it cost half that much and I am reluctant to mix it in with about twenty gallons of fresh gas and use it up in a pickup truck. Have been told somewhere it can damage the oxygen sensor, or something.
So, how do I use it up or discard it?
Is it usable in a one cylinder, four-stroke lawn mower or in a two-stroke weed wacker?
Does the tranfer station ever accept it?
Old 05-23-2007, 01:17 PM   #2
jrc
It won't hurt a 4 stroke lawn mower, it might smoke a little, worst case it might foul the plug. The weed wacker would be OK if the oil to gas ratio is about the same.
I would not put it in a modern car or truck, too many things to go wrong.
Old 05-23-2007, 02:26 PM   #3
Probably not an answer that most will approve of, but we use our old gas on our bonfires/campfires to help get them going. A little at a time of course. I have a gallon that came out of my generator that was bad and I used it up over the last few weekends this way.
Old 05-23-2007, 03:04 PM   #4
offmycloud
offmycloud's Avatar
Be careful if you use gasoline to start bonfires, especially large ones. That stuff can vaporize in the pile and explode when lit. Now that I have kids I stick to charcoal lighter fluid or kerosene for all bonfires - gasoline is really unstable. I wouldn't mess with it.
offmycloud is offline   Reply With Quote
Old 05-23-2007, 06:56 PM   #5
Sunbeam lodge
Sunbeam lodge's Avatar
Smile
As unstable as the gas price!
Sunbeam lodge is offline   Reply With Quote
Old 05-23-2007, 07:11 PM   #6
JTA
JTA's Avatar
Default gas/oil mix
If you decide to use the gas in another 2 cycle engine, make sure that your oil/gas ratio is the same. If your boat gas is 50/1, a weed wacker could be 16/1. Big difference.
I've had the same question about discarding gas (but haven't sought out an answer). I would think that a marina would know as they often deal with contaminated gas.
PLEASE DON'T USE THE GAS AROUND A FIRE!
Old 05-24-2007, 08:14 AM   #7
chipj29
chipj29's Avatar
If you put one gallon in your cars gas tank, mixed with regular gas I hardly see the risk. At very worst you have about 4 or 5 oz of oil mixed in with ~20 gallons of gas. Very very diluted (more than 600:1).
Old 05-24-2007, 09:45 AM   #8
I'd filter it and use it in the lawnmower. Boat 2/s oil is formulated differently from tool oil and can make a mess so you may not want to use it in a weed-wacker or chain saw.
When using gas to light a fire I pour a little at the bottom with the tinder and kindling. A dab will do you. Use a long match to light it if you can.
I know someone who was burning brush (in the winter fortunatly!) and spread a gallon under a large log. It did vaporise quite a bit and ignited with a perecptable WHUMP! His neighbor felt it inside his house apx 100 yards away and thought his furnace had malfunctionned.
Old 05-24-2007, 12:14 PM   #9
Weirs guy
Weirs guy's Avatar
I've got about 2 gallons of straight gas & water from a leaky gas tank a few years back under my porch. Anyone with a bonfire pile felling saucy?
Is it bikeweek yet?
Now?
Weirs guy is offline   Reply With Quote
Old 05-24-2007, 01:03 PM   #10
Fishy Cover
Default Evaporate it
Put it in a shallow open container like a baking pan or gallon milk jug cut in half, leave it in the sun and you'll be pleased at how quickly it evaporates, leaving a gooey residue because the oil will not evaporate.
Fishy Cover is offline   Reply With Quote
Old 05-24-2007, 04:38 PM   #11
I'll be over!
Old 05-24-2007, 08:35 PM   #12
Electric man
Default Old Gas
Find a gas station or machine shop that uses old oil burning equipment to heat their building. They may take it and burn it in there heating system.
I don't know if they are used in NH but in Mass there are quite a few places that do.
Electric man is offline   Reply With Quote
Old 05-24-2007, 08:40 PM   #13
Gavia immer
Gavia immer's Avatar
Give them a call. Transfer stations accept used oil, though waiting for an "amnesty day" for hazardous waste may be an option.
Gavia immer is offline   Reply With Quote
Old 05-30-2007, 07:02 AM   #14
Adding it (at a very thin ratio) will be ok in a car - about 1/4 of a gallon per fillup, I've done this many times. As mentioned earlier the ratio would be so small it wouldn't be noticable. I mean I would not do it every fillup forever but once in awhile to get rid of a gallon or so is fine. If your nervous about doing this in a car the same holds true in a mower.
Oh ya, just my .02 please don't call me if you ruin your engine.
But seriously, I've done it before.
This page was generated in 0.36923 seconds
