Old 06-05-2024, 03:19 PM   #1
winterh
Default Trampoline leak
Anyone have any ideas on how to find a slow leak. I took out of water and brought home so I could soap it up and look for bubbles. Nothing. Went over every inch listening for air being released. Nothing. I am quite sure there is a leak somewhere as it softens considerably within a day or so of filling to max.
Old 06-05-2024, 07:21 PM   #2
CampEye
Maybe it just has lower pressure when the temperature dips over night or when cloudy. I try to fill mine up early in the morning, the opposite of Tom Brady.
CampEye is offline   Reply With Quote
The Following User Says Thank You to CampEye For This Useful Post:
codeman671 (06-06-2024)
Old 06-06-2024, 07:57 PM   #3
winterh
I tried pouring soapy water over filled trampoline but got nothing. Saw online to spray simple green straight from the bottle. Tried and found 4 small leaks that were easy to ID as they created big bubbles. All patched and ready to go.
The Following 2 Users Say Thank You to winterh For This Useful Post:
ApS (06-20-2024), Descant (06-06-2024)
Old 06-07-2024, 08:42 AM   #4
The Real BigGuy
I’m glad you found a solution!
I was trying to think of a colored gas you could pump in that would show the leaks and the only 2 that came to mind were chlorine & fluorine. Don’t think either of those ☠️ ☠️would be something for this particular application!
Old 06-19-2024, 06:33 PM   #5
WagonWheel
Default Looking for professional aqua glide repair
Does anyone know a professional who repairs leaks in Aquaglide lake trampoline in lakes region area? I tried soapy water and simple green but that didn't work for me.
Last edited by WagonWheel; 06-20-2024 at 03:28 PM. Reason: put in more information
WagonWheel is offline   Reply With Quote
Old 06-19-2024, 06:49 PM   #6
Now stop jumping on it with your golf shoes!!
Hillcountry (06-19-2024)
Old 06-20-2024, 05:35 AM   #7
winterh
The hard part is finding the leak but the method I tried above with the simple green worked very well. Once you find the leak patching it is easy. I have used 2 types of patches over the years. There is a ready made peel and stick that works ok if you get it perfectly flat but the kind where you mix the glue with a hardening agent and brush it on seems to hold better.
This page was generated in 2.17825 seconds
