Old 10-26-2020, 09:56 AM   #1
rick440
Default Harris Cruiser 220 - question on trolling motor setup
Just purchased a Harris 220 pontoon boat and am interested in adding a Minnkota trolling motor. Wanted to get some opinions on what size trolling motor to get along with the length of the down rod. Since I plan to install it on the bow of the boat which has a solid front door, I wanted to see what mounting plate you may have used to permit the trolling motor to lie in a horizontal position when stowed left to right. Much thanks for any thoughts!
rick440 is offline   Reply With Quote
Old 10-26-2020, 10:23 AM   #2
I had a 36 volt Minn Kota Terova 101 mounted on the bow of a 24’ tri-toon. Minn Kota makes a low profile flat quick release mounting plate that works great.
You will want the longest shaft available which I think is a 72” as you will want to see the head of the motor above the playpen walls on your pontoon.
Depending on the clearance from the floor to the bottom of your door you may have to modify it so it clears your motor when closed. Most manufacturers make bow doors to allow clearance for trolling motors.
Edited to add...you may be OK with a 60” shaft depending on the height of your deck off the water at the bow.
Old 10-27-2020, 09:09 AM   #3
MIKE RGR
Default Minkota Site
Hey Rick
Take a look at this site and give them a call
They are very helpful
https://www.minnkotamotors.com
Take care
MIKE RGR is offline   Reply With Quote
This page was generated in 0.06153 seconds
