Old 08-22-2014, 10:21 AM   #1
BigLake
BigLake's Avatar
Default Need Company to put in Pipe Dock Annually
I have a pipe Dock that I have been putting in and taking out for many years. The time has come for me to have this work done by someone other than myself.
Are there any recommendations for company's who do this type of work?
My home is located in Moultonborough on Moultonborough Neck in the Kona Section.
BigLake is offline   Reply With Quote
Old 08-22-2014, 10:53 AM   #2
I believe Center Harbor Dock & Pier, on Rte 25, is one outfit that does seasonal in/out work.
Another option to consider is what I did after wrestling with heavy wood dock frames every spring and fall. I had a crank-up aluminum frame dock installed. This fall, the deck sections will come up easily, as I can lift and carry each section easily. Then I'll attach the cables and crank up the frame for the winter. No more back-breaking dock removal.
Old 08-22-2014, 12:05 PM   #3
X2 on CH Dock. They get busy in the spring, so get on the schedule early!
Old 08-22-2014, 06:54 PM   #4
JTA
JTA's Avatar
Yup, CH Dock put in a nice crank up for me a few years ago. You still have to remove the decking sections but still doable for me at age 69. Still, I might look into an electric winch at some point in time.
The Following User Says Thank You to JTA For This Useful Post:
KPW (08-23-2014)
This page was generated in 0.60525 seconds
