Old 08-24-2018, 02:31 PM   #1
Sundancer320
Default Cottage flooring
Ok experts and camp owners. Looking for advice on pro’s and con’s of flooring types. Seasonal cottage on post and piers and want to find best flooring replacement. It’s between glued down vinyl planking or a floating type of vinyl planking. Anyone have experience with these?
Sundancer320 is offline   Reply With Quote
Old 08-24-2018, 03:48 PM   #2
feb
Default Floor Creaking?
Not sure how old your place is but if the floor has some give to it and creaks then I'd say avoid anything glued down. My kitchen and bathroom are glued down linoleum. When the temps are warm it isn't an issue. But if I come up to check out the place in the cold temps and walk on it, it sounds like cracking glue and makes me worry I'm ruining the adhesion so I limit my contact with it.
But this is a seasonal place where the inside temp is the outside temp during the winter.
Old 08-24-2018, 03:58 PM   #3
Sundancer320
I am leaning toward something that flex’s with the temp...worry if glued down surface buckles than the whole floor will have to come up vs. a few snap in pieces...
Old 08-24-2018, 04:17 PM   #4
DBreskin
I have floating vinyl plank. I’m very happy with it and although I’ve never had a problem, I like the peace of mind knowing I can easily replace a damaged piece by disassembling the floor.
Old 08-24-2018, 05:14 PM   #5
Formula260SS
Formula260SS's Avatar
Wide pine, nail it, sand it and poly it.
More work but well worth it. 10 yrs no issues. It gets banged up a bit in a good way.
Old 08-24-2018, 05:23 PM   #6
Seasonal camp? Why yes real wood.
Old 08-26-2018, 06:19 AM   #7
Grady223
Grady223's Avatar
A high grade glued down vinyl. We have Tarkett Permastone in our island cottage. 15 years old and still looks like new. Indestructible and very realistic.
Old 08-26-2018, 06:59 PM   #8
I have floating vinyl plank and do not recommend it in a seasonal camp. It expands and contracts to much with temperature changes and after a few winters you are likely to get some of the interlocking seams that do not go back together in large spaces.
Rattlesnake Gal (09-04-2018)
Old 08-26-2018, 08:37 PM   #9
What about wide pine blanks?
Old 08-27-2018, 09:06 AM   #10
can't say enough about the flooring we put in our place last year. It is Tranquility from Lumber Liquidators. 100% vinyl all the way through, can basically put it in the floor of a pool, has a great texture and grain to it, we get compliments from people over and over again, it is thicker than pergo and Armstrong version, well pergo does not have full vinyl, even the builder love it.
here is a link to the main page of the LVP (luxury Vinyl plank)
https://www.lumberliquidators.com/ll...d=SUBNAV_Vinyl
it is considered a season cottage, and we have had it over a year now - it does pay to put a good close cell foam for underlayment - I did not purchase the one form lumber liquidators, I purchased from a website called best laminate - was a much better product
https://www.bestlaminate.com/floor-m...-underlayment/
Old 08-27-2018, 11:12 AM   #11
That is same Flooring (Tranquility/Limber Liquidators) I put I put in the finished upstairs of my garage. I also used the foam underlayment. It was fine for the first 3 winters but last winter I had three planks pull away from the ends of the planks they butted up to. This is in a large room thats about 12'x24'. The smaller two rooms up there are 10X12 and those rooms have had no issue. No idea why it was fine the first few winters and then became a problem. I asked around before I installed it if it would do OK under seasonal use. Some said yes some said no. It was gamble and I knew it going in. Im going to watch it this winter and next.
AC2717 (08-27-2018)
Old 08-27-2018, 01:16 PM   #12
Laminate flooring is plastic. Plastic doesn't react well to extreme temp changes. I personally would not use it if it was a seasonal cottage. Wood is much more forgiving during temp changes. JMO.
This page was generated in 0.10041 seconds
