-   -   While it is out of the water... (https://www.winnipesaukee.com/forums/showthread.php?t=9667)
JonLevis 04-06-2010 10:15 AM
Manitou is hoisted up at Fay's getting a new coat of bottom paint and a good cleaning (she is not the easiest to clean while afloat!). I am also installing a new thru-hull transducer for my chartplotter. Any suggestions on other preventative stuff that I should be looking at while she is high and dry? GO SOX!!!!!
NoBozo 04-06-2010 10:21 AM
Is it a wooden boat and how old is it and how big..?
JonLevis 04-06-2010 10:24 AM
She is a 51' Bluewater Cruiser. Fiberglass construction all around.
Woodsy 04-06-2010 10:34 AM
While she is out of the water its a good time to replace the seals on any thru hull fittings below the waterline... bellows in the case of I/O drives.... packing in the case of propeller shafts...
Woodsy
BroadHopper 04-06-2010 10:37 AM
seals
All seals and bellows. If you have a sea strainer, that should be cleaned thoroughly.
