-   -   Water temp readings (https://www.winnipesaukee.com/forums/showthread.php?t=4828)
fatlazyless 07-08-2007 04:04 PM
Water temp readings
Just happened to notice that the Black Cat web cam says the water is 67.5, while the Lakeport Dam- State of NH's reading from this website says it is 70. Methinks 67.5 is correct after measuring myself with a good qualty thermometer and based on feel. Heck, it feels too cold today to be 70. 70 is a relatively warm temp, and a warm temp, it is not.
Is this some type of revenue-generating tourist trap foisted on us by our Blue-New Hampshire, Democratically controlled state goverment who are willing to compromise their professional political dignity just so's more tourists will drive here from anywhere, or what?
So, how come the State's reading is too high? Is there a temperature detective in the house? How.....who.....how.... are we the residents and visiters of NH supposed to believe?
JTA 07-08-2007 07:28 PM
Southern waters
Black Cat is in the north and the Lakeport dam is in the south. Everyone knows that southern waters are warmer than northern. Give the State a break. Not everything is a conspiracy (unless the statistics are controlled by the Fed).
ITD 07-08-2007 07:48 PM
This one's easy, they rounded.:D
Pineedles 07-08-2007 08:05 PM
Tourist Forecast?
Right............ There's no such thing as a tourist forecast in the Lakes Region. Been hearing for years.. RED, Blue, it doesn't matter who is in charge.:laugh:
Weirs guy 07-09-2007 12:31 PM
You're also assuming both thermometers are calibrated and accurate. You could probably put both of them in the same bucket of water and have a 2-1/2° difference between them.
CanisLupusArctos 07-09-2007 01:10 PM
Thermometer
Not sure what the DES is using for a temp probe, but mine is a Sensatronics E4 temp monitor which is brand new. If you're curious about its techie specs, you can visit www.sensatronics.com and look at the E4. The company is located in Bow, and has a reputation of making very accurate instruments.
When I saw the differences in the readings I always figured it's because the state's probe measures the temp of the water going thru the dam in Lakeport at the end of Paugus Bay. Paugus Bay heats up more easily in summer and freezes sooner in winter than out here on the open lake. The lake gets stirred up a lot more out here.
This'nThat 07-09-2007 02:46 PM
Many possibilities, including the depth of the two gauges, instrument calibration, water turbulance, the exact time of the measurements, the amount of sunlight on the area just before the measurement, the surface conditions (temp, humidity), and so on.
I think better data is needed before anyone can draw any conclusions. Specifically, need to collect measurements at the same times over a long period of time, and we need to calibrate (not only the instrument, but the all the other conditions around the instrument). With a lot more data, you can perform a good analysis.
Grant 07-10-2007 09:47 AM
Rock bass are a conspiracy.
Weirs guy 07-10-2007 12:25 PM
Can they calibrate a temp probe?
Grant 07-10-2007 12:31 PM
They would, if they were actually in the Lake.
Island-Ho 07-10-2007 12:32 PM
Location?
I thought the summer temperature readings on this site came from Jolly Island, or somewhere in that vicinity? :confused:
webmaster 07-10-2007 12:51 PM
Right at the top of the temp page it says:
The water temperatures listed here are from the
Winnipesaukee Dataphone at the Lakeport Dam (603-527-0071).
Some of the archived temperatures were posted by Ron from his
thermometer on Jolly Island. Thanks to Ron for his contributions.
Ron was kind enough to post the water temperature from his thermometer off Jolly Island for several summers. He stopped doing it a few years ago and I have been posting the temperature from the dam ever since.
When Ron was posting the temperature it was usually the same or very close to the dam readings.
Weirs guy 07-11-2007 12:04 PM
The probes or the bass? :D
I did read the specs CanisLupusArctos link lead to, the probe is ± 0.5° for this temp range, so assuming the states probe is equal that could be a full degree's difference right there!
fatlazyless 07-11-2007 01:06 PM
This time a year, with the outflow reduced to the minimum, the concrete dam structure becomes a heat exchanger transfering heat into the water. The concrete dam structure absorbs radiant heat from all the wonderfull sunshine and it gets transferred into the water as it flows though.
Not much water going through the dam this time a year, correctimondo?
ITD 07-11-2007 01:32 PM
Wait a minute, probe accuracy is +/- .5 degree. How is it Algore can predict climate change to absolute certainty if the measuring instruments have a 1 degree margin of error on them, I thought the science was settled?
Oops, thread hijack, Less would never do that to someone else's thread.;)
CanisLupusArctos 07-12-2007 11:44 AM
My guess
I would suspect that the difference is related to the size of the water. Paugus Bay, where the state's probe is, gets circulated a lot less than the water out here. Paugus Bay is almost its own little lake with only a small channel into the main lake. It wouldn't surprise me at all if the water temps there were warmer in the summer and if it froze earlier in winter.
Where my probe is, we see the lake getting continuously stirred from end to end - wind comes up from Wolfeborough (from the SE) and on days like today it blows from Center Harbor (NW.) The water here has always taken a good deal of hot humid weather before it warmed above 70 in summer, and in the fall it takes a good long time to cool down and eventually freeze. The trees within a couple hundred feet of the shoreline are usually a week behind the rest of the area during foliage season. We typically don't get our first frost until November, thanks to relatively warm water.
The last couple days the water temp reached 71, but now with lower humidity and a NW wind I'm wondering if it'll drop back into the 60s by evening.
steadyon 07-12-2007 02:58 PM
its summer, smile
so, because the states reading is 2degrees higher, tourists will be coming
in droves and the Democrats get the points.
this is almost as silly as the Rusty McMeredith thread:rolleye1:
Weirs guy 07-13-2007 12:06 PM
So, why waste your time reading it and responding?
CanisLupusArctos 08-01-2007 01:19 PM
Depth readings now online
Just installed a second probe at 12 feet deep. The "surface" probe remains at 3 feet. Right now it's showing 80 degrees at 3 feet and 75 degrees at 12 feet. They update every 15 minutes at www.blackcatnh.com.
SS-194 08-01-2007 03:16 PM
I like analyzing temps as much as the next guy but hey it is the middle of summer. It may not get any better than this. Forget the #'s let's all go swimming!!
Bear Islander 08-01-2007 10:25 PM
My water temps are very close to yours. I measure at 3 feet. My lake temp is online, it updates when you refresh the page.
The way you display the data makes me believe you are also using the Sensatronics E4
www.bearcam1.com
SIKSUKR 08-07-2007 11:07 AM
My water temp sensor is at the surface on my boat.I was on the lake 5 days last week and consistantly saw 80-82 degrees.At one spot in the broads of all places,I had 86 degrees!Wow,the water is wonderfull!!!
chipj29 08-07-2007 02:59 PM
Been on the Merrimack lately? Last Thursday in Bow the water temp downstream of the powerplant was around 90. Talk about unrefreshing!
Merrymeeting 08-07-2007 03:48 PM
Record?
Has anyone figured out what the highest recorded temperature is of those that have been captured in the readings on the site?
I haven't had time to look yet...
Merrymeeting 08-07-2007 03:54 PM
79
Answering my own question,
Assuming it had to happen in July, Aug, or Sept (I didn't look at other months), 79 is the highest recorded temp.
Aug 9-10, 2001, July 19, 2006, and several times in July 2005
New record this week?
CanisLupusArctos 08-09-2007 04:24 PM
79 is the record on which body of water? I seem to remember that in 1988, Winnipesaukee hit a record high of 92 degrees. It was in the news, alongside articles about duck itch and unusual aquatic plants popping up everywhere. That was a really, really hot summer as I recall.
Last year my old probe got to 84 degrees at 3 feet, during the heat wave of early August. This summer (with new probe) 82 has been the highest.
Merrymeeting 08-09-2007 05:06 PM
I was referring to the records on this website. They only go back as far as 2000.
I too recorded 83 last week on Merrymeeting (which seems to track Winni fairly well). This is with a probe about 3' deep below my dock, about 20' from shore with water depth about 6'.
SIKSUKR 08-10-2007 01:13 PM
Actually yes I have.I live in Bedford and was on the river last week.Although I launched at Lambert Park and was below the Hooksett dam.I didn't look at my temp gauge though.
SIKSUKR 08-13-2007 11:04 AM
Big drop
From last weeks surface reading on my boat of 82-84,this weekend I had 76 on Saturday and 77 yesterday in the Broads off Welch Island.
CanisLupusArctos 08-13-2007 09:38 PM
Dry weather is here
A little wind on the surface seems to have blown warm water elsewhere... meanwhile the humidity dropped off a ledge this afternoon. From a dewpoint of 65 this AM (very muggy) to 48 at sunset (Fall-like dryness.) When the air is very dry the lake water cools off quick. Today I had 76 water temp on Black Cat.
Channel 6 in Portland just mentioned "Fall-like" temps for this upcoming weekend so I'd say enjoy those water temps while they're still in the upper 70s.
Weirs guy 08-14-2007 12:22 PM
I drove by Winnisquam this a.m. on the way to work and saw the dreaded "heat loss fog" rising off the water. :( :(
Merrymeeting 08-15-2007 12:53 PM
Based on the Winnipesaukee.com temp readings...
... the downward slide begins...:(
CanisLupusArctos 08-16-2007 08:59 AM
Autumn nears...
Heat loss fog, already? I haven't seen that yet but it does make for some *great* sunrise pictures.
The last few days the surface temp has been running cooler than the 12-foot temp. Just another sign of autumn. The hornbeam trees also have their first red leaves - they always start turning a few weeks before all the others but they still peak about the same time as the others.
Ch. 6 Weather (Kevin Mannix) said mountain valleys would probably get down into the 30s on Saturday night.
Grant 08-16-2007 09:36 AM
Personally, I think 70 is the ideal lake temp. Just right. And once you get into 80 and above, the algae blooms go into overdrive.
Weirs guy 08-16-2007 12:10 PM
Bad news update, saw it again on the big lake on Meredith bay yesterday morning about 5:30. :(
CanisLupusArctos 08-18-2007 08:56 AM
The downward spiral begins...
It felt like November suddenly roared in about midnight last night. Calm quiet summer night became hefty gusts out of the northwest in a matter of minutes and the wind is still increasing. Dewpoint now in the 40s, temp in the 50s, wind still increasing and tossing up the whitecaps.
Not surprisingly the water temp is now steadily dropping from 72. Based on weather forecast I think it'll get down to around 67 before this first-of-the-season cold wave is done with us.
