Fathom Divers to be featured on Discovery!
It's a dirty job; but somebody has to do it.
Moorings for the Lake on the Discovery channel this Tuesday... http://gamma.unionleader.com/article...4-37622a825cb2 Quote:
Thanks for the heads up...
GWC!
This should be very interesting and it's always great to see our local Celebrities on national TV. By the way,.. DCR has some critters for your pet spider, over there. ;) |
Winni on Discovery
Excellent!! Am a fan of the show. Great to see a local segment.Thanks.
Excellent!
I like the show it makes me appreciate my desk job....I have had several jobs where I got dirty and or greasy. Try washing pans used to make head cheese!:liplick:
I love that show, it'll be great so see some local footage! |
Reminder!
Watch Dirty Jobs and see the LAKE!
It was just on....
I just watched it here in the Mountain Time Zone -- how fun to see Winni! Woohoo!
Disappointing!
OK....that was really disappointing. They showed Silver Sands Marina and it looked like the mooring went in Gilford harbor somewhere. The segment could have been more interesting and they could have shown the lake rather than the silly boat lift. I was hoping for more.
Jetskier:cool: |
I watched
Makes me want to strap on the gear and get wet. :laugh: They could have showed more of the lake but that is not a dirty job is it?
Dirty Job
We thoroughly enjoyed the segment over here in Gilford. We watch Dirty Jobs on a regular basis and love the show, so it was neat hearing Gilford and the Lake mentioned on this episode.
Has anybody figured out where the mooring field was? We didn't recognize the shoreline. At first I thought it might be in the LSP area??? Thank you for the heads up to watch tonight! Gravy |
Neither is singing the National Anthem
they kinda shortchanged the Winnipesaukee segment. At least half was the marina footage and that was about as interesting as watching grass grow. I am glad they shot up at the lake, they just could have done much more. Jetskier:cool: |
Why so complicated?
Is installing a new mooring really as complicated as they made it seem? They dropped in the concrete weight, then went in and flipped it over, then attached a lift bad and moved it where they wanted it to go, then attached the mooring chain to it. I installed my own by dropping the mooring where I wanted it to be with the mooring chain already attached. I did go down in scuba gear afterward, but only to to check that it landed right side up. You would think that if they had a barge just for the purpose they could even skip that part by lowering it in slowly with a crane of some sort. A guess it wouldn't be such a dirty job though, huh?
I was confused by a portion of the episode. They took the mooring into what looked like shallow water. Then they placed it on top of some rocks. The way I thought moorings work were - 1. the weight and 2. the suction the mooring creates with the sand/mud on the bottom. That is at least they way my mooring works. After a year on so on the bottom my mooring is usually buried due to the chain dragging the sand/mud around the edge of the block. Every 2 years or so I dig it out to make sure the eyebolt that goes through the entire block is still properly attached to the bottom. It just seemed weird they placed it on top of a rock pile.
My mooring definitely relies on the burying/suction effect to stay put, but then again, it weighs far less than the one they were placing.
It was a decent segment, but I kept wondering what others have already posted: Why not attach the chain before dropping it, and why not drop it where you want it? |
Dave Put My Mooring Block In
I hired Dave Ferruolo to drop a 1000 lb mooring block in front of our place in 2005. Same barge was used. Sure enough, Dave dropped it over the side off the dolly and it landed upside down on the bottom. Dave had an air cylinder on the barge with a long air hose and scuba regulator attached. He slipped on a mask, regulator in place and jumped overboard and I watched in amazement as he hand flipped the 1000 lb'er right-side up just as he did on last night's show.
As a side comment, I was impressed with Mike Rowe's singing of our national anthem. |
Think about it
I am surprised that Senter Cove Guy did not anwer some of the questions. And I guess this is why in some cases, you might want to hire a "professional".
To your direct questions: A) Not all of Winni is sand bottom. There is lots of bottom that is all rock. Quite a bit in fact. Also, if the installer is good, they take that into account, as well as other things such as boat size to be moored. That way the customer doesn't need to buy more than needed. Others don't care. CYA. (No need to go into the mathmatics of suction at this point.) B) Sometimes you need to understand the details. In the show, they were doing an installation in a "mooring field". It is absolutely critical to get the correct placement. Off of your our personal property, close enough can be good enough. C) Like driving a car, the more miles you drive, the better the odds of getting into an accident. I don't know of ANY "professional" that would drop a weight with a chain attached. Too dangerous. You may get away with it once or twice. Not worth the chance over time. You have to get in the water anyway. Wait to attached the chain after the weight is set. Also, fouling of the chain under the weight is a possibility. Sometimes it goes easy. Sometimes not. Anyone can do the easy ones. Then there is liability ... |
mike rowe
he use to sing opra. thats why he sound good
Mike's a trained opera singer. Gotta listen to O&A on XM Radio to get treated to his vocal talents. He's a classic. |
| All times are GMT -4. The time now is 07:38 AM. |
