frozen water lines
I draw my winter water from the lake but looks like its frozen. Never happened in the 10 plus years I have been here and especially surprising given this year I have been living here so heat always on and water never sitting for long. It seems fine where it leaves the basement so problem must be between house and lake. I am guessing it's right where pipe enters lake and ice has frozen down to lake bed. Moved my bubbler over there to try to clear surrounding ice. Any other ideas???? Unsure what else can be done at this point besides waiting for spring.
Another (temporary) pipe placed elsewhere in open water?
Dan |
I've only seen one other one that was a supply line.
They inserted a small pipe and jetted it with hot water to release. Not sure that is even plausible for you situation. |
Dan |
My first thought upon having no water was frozen lines. Made sense given the temps. I had a very slow drip that continued thru the night and I wondered why. Turns out issue was in my filtration system. Bypassed my filters and water flowed. I change the filters every month but for whatever reason they clogged up quick and almost completely stopped the flow.
Glad it was something easy.
| All times are GMT -4. The time now is 02:03 AM. |
