Termite Spraying?
Do you spray your wood houses for termites? If yes, can you suggest an exterminator who will come out to an island? Thank you!
JP Peat
Yikes, I didn't even know we sprayed for termites up here?!
Eastern subterranean termites are prevalent throughout New Hampshire. I use JP Pest for this and carpenter ants, etc.
As someone once said... "Set it and forget it". JP Pest Services 877-250-4315 |
Our problem was carpenter ants.
Got the granules from hardware store. Spread around house maybe 3 times per year. Also make sure there are no shrubs bushes and such near house. But an exterminator may be your best bet. |
I have an interesting one for you, several years ago I had to replace my above ground rubber pool liner (very large Kayak pool). Pool company said that termites had chewed through the liner. They showed me and I was amazed that they were right. Lots of tree roots from past removed trees running under the pool that attracted them.
I guess by law the exterminators cannot just treat around a pool, so I had to have them do my house so I could get my pool done too. They have been telling me that the mulch around my foundation has attracted the termites, so I guess it was worth the money. They used the in-ground traps around the house, pool and sheds and spray twice a year. When I tell people with liner pools, they look at me like I have 3 heads... |
| All times are GMT -4. The time now is 05:16 AM. |
