Registration
I am in the process of purchasing a used PWC from another state (NY). Can I use the old registration and a bill of sale to register it in NH? This is a machine I owned back in 2003 and am buying back. I may even have the old NH registration from 2003. Would that work better?
Thanks in advance. Bill |
Use your old NH registration...
It is probably easiest giving the agent your 2003 NH registration, some like to "fill in the blocks" for the new reg directly off an older registration.
However, either State registration should have the necessary info for the new reg (make/model/colr/vin). Skip |
Thanks Skip
Some how I knew it would be you. |
I'd bring both sets of documents. Let the agent make the decision. They may need to make a note about the changes in owenership. At any rate there will be no question that you are acting above board.
Kamper. Good idea. I found the 2003 reg. so I will bring both and the Bill of sale. Thanks Bill
| All times are GMT -4. The time now is 05:30 PM. |
