Eversource Lowering Rates
From Eversource:
Two rate changes will be implemented beginning Feb. 1. Overall, customers should expect a decrease to their bill. Your total bill will depend on how much energy is used, the rate you’re on, and weather conditions. The Energy Supply rate will decrease by approximately 10% and will be in place through July 31, 2023. The cost of energy supply is dropping from $0.22566 to $0.20221 per kWh. The average customer using 600 kWh per month will see about a $11.55 or 5.7% decrease in their total bill compared to January if Eversource is your energy supplier. While the energy supply rate did decrease, overall, the price of electricity still remains high compared with previous winters primarily due to the global demand for natural gas. Natural gas is the primary fuel source for electric generation in New England. |
https://www.iso-ne.com/isoexpress/web/charts
According to the real time, at 10Am... we are actually burning some coal. |
I am a resident of New England.
And an Eversource customer, The ISO NE is actually a federal agency. It doesn't directly own transmission or generation facilities. So ''we'' is more of a general term for the residents of the region. Though I probably own stock in several of the generation and transmission corporations as part of a mutual fund within my portfolio. |
It wasn't rhetorical.
It was a snide remark. |
I don’t think it was a snide remark. I think it was an attempt at humor and it went over your head.
Here is the key, if you want lower electric rates, think Nuclear..... Unfortunately because of a steep learning curve, we have moved away from it.... even though it runs our Naval Fleet.....
It didn't go over my head. |
Our hydro is rather small, and can't be fully utilized based on demand, the lakes would fluctuate too much. NG has been the choice to replace coal and oil for at least the last decade. It has the right thermal properties, lower emissions, and can easily handle the distance from the base load to the peak. |
Bridgewater Power Co, Bridgewater-Plymouth town line
Just south of Plymouth NH, actually abutting the town line on Rt 3/25 in Bridgewater NH is an electricity generating plant that burns wood chips to power a steam turbine that creates electricity that goes somewhere via its' power line to the power grid.
It apparently does not have its own website. Besides the clean looking mix of white steam and white smoke that shoots out its tall smoke-stack is that it gives work to a lot of locals who cut the trees, grind up the wood chips and drive the big trucks loaded with wood chips to the plant. Most of the tractor trailers haul'n wood chips are older trailers with the upper half of the two rear doors cut away, to load and unload their heavy load of wood chips. Unlike nuclear, natural gas, oil, hydro, wind or sun powered electric utilities this Bridgewater Power Plant puts everyday local guys to work who supply it with wood chips and that is a very big difference. It makes electricity and it also spreads the money around to local NH guys from northern NH, north of the notch. |
Not with only three choices.
I am sure ''They'' would have also issued a response. Basically, I am spending my time focused on the new IECC specifications. We've been so busy we are all way behind the curve. |
The CT PPA for Millstone was above the market rate when entered into... it ends in 2029.
The VT PPA for Seabrook (NextEra... I have stock) goes until 2035(?). It doesn't appear that any of the other sites with significant transmission infrastructure is being looked at... though I believe the technology exists. |
| All times are GMT -4. The time now is 08:12 AM. |
