-   -   Carrier Heat Pump (https://www.winnipesaukee.com/forums/showthread.php?t=28025)
Not to Worry 06-09-2022 05:04 PM
Carrier Heat Pump
I want to install a 4 Ton nominal heat pump system similar to Carrier Co. 25 VNA 048. Or Carrier is fine too. Anyone know a company who can install this OTHER than Lakes Region HVAC.
Any help would be much appreciated.
TheProfessor 06-11-2022 12:10 PM
It's all right HERE
Of course no one knows if you have the unit. What you are using unit for.
Replacing a unit? Starting from scratch?
Not to Worry 06-11-2022 04:41 PM
Heat Pump
I want to replace my current Propane HVAC with heat pump. I had an engineer review my heating needs and he feels a heat pump would cost far less to run than heating with propane. Even when temps drop below zero.
So, I need a contractor who knows what they are doing AND a company that will service the unit after install.
So, far I have not found a contractor but I do have one that is now working with Carrier to understand how it will all lay out.
