Window screen frame repair
Have a bent window screen frame, is there a company that can help me out?
I would really appreciate it. Thank you |
www.pemiglass.com in Meredith ...... very nice.
I also recommend Pemiglass in Meredith...
Pemmiglass it is. Very helpful and nice! Thank you
Manufacturer?
If the aluminum frame is a specific color... they will need to order the part/screen. |
Winilyme - you framed yours response well.
No one - No place had the color (light brown). With a lot of research - found the original manufacturer. Purchased new unit from them. But for ordinary metal - the advice above is excellent. |
You mean for a mill finish?
I believe Pemi also has white and brown in stock. But if it is an Andersen (which would not be mill), it uses an aluminum spline that can not be done by local shops. We cannot even replace the mesh on those - as removing the aluminum spline causes it to kink and never lie flat again. |
| All times are GMT -4. The time now is 01:30 PM. |
