Need insulation removed from a basement area (floor insulation)
Hi !
I need to have the insulation of a floor area completely removed. This is a botched floor insulation homeowner job from the previous owner. The insulation was installed with the vapor barrier DOWN - and then plastic installed over that. So the insulation is damaged due to sustained moisture due to condensation within the insulation. It has to be removed and properly disposed of. This is in Tuftonboro. Anyone know of a reasonable contractor who could do this. At some point, after some serious renos are completed, the floor will need to be re-insulated. But for now, the old insulation needs to be removed. Thanks and Regards, Steve |
A question...
The insulation installation is "botched"?
Can you provide a picture of what you're seeing? :confused: |
Besides degradation of the insulation due to having the vapor barrier on the cold side (in winter), resulting in condensation of interior moisture diffusing through the insulation to the cold surfaces, I have to wonder if long-term accumulation of moisture has damaged the bottoms of the floor joists. Wetness held there by that plastic vapor barrier won't dry to the exterior easily.
As part of your later renovation efforts, and assuming you have a crawl space under the living space, you might think about enclosing that crawl space, eliminating any air leaks into it, insulating its walls, and having a sturdy vapor barrier over the ground. A lot of good information on all this can be found on greenbuildingadvisor.com. |
The best insulation for a basement is spray foam.
However, yes, job 1 here is to get this crawl space (about 5 feet high) sealed up properly (after the old insulation has been removed of course). |
So, during the cold months (the people lived here year round), the warm, relatively moist air from the living space will work its way through the insulation until the dew point is reached, at which time the vapor will condense and form water dropletts. And then the condensed water is more or less trapped there due to the vapor barrier. It appears to me as if the house was built with uninsulated floors, and then the homeowners installed insulation after the fact. |
| All times are GMT -4. The time now is 08:10 AM. |
