Tips for putting in a wooden dock without getting wet?
1 Attachment(s)
This is only our second year. Last year, well, it didn't go well. :laugh: As we all know the water is very cold still so even with a wetsuit it's not very comfortable and still limits the time you can be in the water. last year we tried waders but they ripped which made them useless and because the end of our dock is over 3' we still can't easily get out there to secure the poles. We did end up using various "techniques" (see photo) which worked okay but it feels less than ideal and there are probably tips and tricks out there from people who have done this before.
So, does anyone have a better way to do this, ideally without getting wet (besides paying someone). |
A guy I know does similar to you but uses a small jon boat instead of the tube.
When I had steel framed pipe docks I put them in in a similar manner to what your picture shows. I had access to large truck tire tubes and doubled them up using a compressor to inflate them to the proper height for the dock.
I think you may be able to get tubes from the local tire shops. After a truck tube has been patched a couple times they usually replace them and will give the old ones away. I think that using junk tubes might be better than risking your expensive tube. |
What seems to work pretty good are the better quality waders, made with neoprene and cost about $100 and up ..... so far, have not gone leaky like the lower priced, rubberized canvas waders. The Walmart in Tilton has both styles.
Also, wearing clothes like long underwear under the waders helps too. Just one little leak in the waders makes it very cold, very fast. Foam noodles could roll that dock out, across the water! |
Looking at the big, high prices .... www.bmp-inc.com/Pricing .... for a new, aluminum dock, it sure 'nough makes good sense to be fixing and fixing and fixing that old dock forever ..... till it has more fixes in it .... than what is was, when it was new .... way back when.
Old docks never die .... they just get re-used by some poor slob .... who cannot afford a new dock ..... and needs a dock! |
I use the blue foam you often see under rafts. It needs to be about about a foot wider than the dock section on each side. Put it out in front of each section in the water and then feed the new section in right off the first. Catch the end of the section on the foam and float it out till you drop the back end into the bracket and pin it. Then walk out to the end and pound your poles in with foam supporting you.
I know how I feel...
I know how I would do it without getting wet.
Yesterday I helped my good friend put in his 60 ft dock, 6 10x 3 sections. He had a semi-dry suit on and I had on a 3mil wetsuit. 4 hrs in 44 degree water, with both of us having to dunk down to pick up a dropped nut in 4 ft water depth. Brrrrrrrr. So how are we going to do it next year? Hire someone !!!!!! :D |
Terry |
He's a good friend
We used to do similar, but with our canoe. Said canoe was much more stable, and us child laborers were pretty happy with that job compared to the others required to set up the dock. The only trick of course was whoever got the canoe in place usually had to sit and wait there, to keep it stable, and not every year but some years the person screwed up and fell in. :laugh:
I remember my parents putting a hinge on our dock. Removal at the end of the season wasn't too bad as the water was still fairly warm, and in the spring we basically flipped the dock section into the lake. It had adjustable feet on the bottom, steel plates that were about a foot square. The bottom was fairly solid where we were as well so that made it easier.
Variations of your idea get the job done... you have to create enough buoyancy to support your weight and get the dock level so you can put in the legs... Have you tried using a wetsuit? If you have not I think you will be surprised, and how comfortable it make the process. I did it for almost 30 years, before I turned the process over to my son, who uses the same wetsuit to do the job. While the cost of a wet suit may seem expensive, over time it is not. The other piece to this equation, is to have heat on, and a hot shower available... With all that said, if you are entering the water to do this, the single biggest thing you can do for yourself, is to make sure you are prepared, to work efficiently once your in the water. What this mean in my case is the following: - I have both a primary and secondary set of wrenches, it always seems one gets dropped. With a second set, you can wait until your ready to get out before getting totally wet to get the wrench or wrenches you have dropped. - My legs are at a fixed height, I found in the early years, I don't need to adjust much year to year, and the little bit I do can be done later in the season. so I leave legs attached when the dock comes out... yes this adds some weight but makes installation go quicker. - practice makes perfect. The more you do this the better you will get.... it does take some time. - last make sure you have seasoned help, the more they do it with you the better they get... |
A tip for a wet suit: Flood it with warm water before you get in, this makes it much more bearable. We do that with dives when the water is a bit chilly, makes for a much more pleasant experience.
www.heatedwetsuitreviews.com/
For about $200 you can purchase a Quiksilver Cypher heated wet suit vest that's powered by a lithium re-charging battery .... not too shabby for cold water and extending actual time in and on the water? www.swimoutlet.com has 'em. Almost as good as a 104-degree hot tub and a cup of hot coffee ..... well, make that just a 102-degree hot tub? Or, for about $8.50, you can buy a two quart, old fashioned, leak proof, red rubber, hot water "bottle" from ebay .....w/ free shipping .... and put that to work inside your waders or wet suit! This should hit the spot ..... and at $8.50 w/ free shipping ..... is more in my price range .... should be a winner item, as long as it don't leak. .....the $8.50 hot water bottle inside your wet suit trick ..... how to stretch out the Lake Winnipesaukee, in-the-water, shoulder seasons of April-May-June-Sept-Oct & Nov ..... that's like six extra, get wet, in-the-water, months for the year ... :eek:! But, does it really work any good??? |
A good set of chest waders gets our dock installed. That, and a strong magnet on a string to retrieve dropped items.
We also use a third temporary support pole when adding another section. This is fixed in the 'center' of the end of the section (it's put in place using waders). This allows one to then work from above on the left and right poles, driving and adjusting. |
Wow, great responses!
I think we're going to try to put the poles in first but not drop them down fully so they are ready to drop when we get it in place. Part of the difficulty last year was trying to put a 10' pole in place while sitting in a boat or in the water not wanting to get wet; if they are already in place and we just have to loosen the set screw that should make that job easier. Order two sets of wadders, just in case and I'll go to the wetsuit as a last resort. :D |
Dry suit
A wet suit is great - but for cold water a dry suit is even better. I was a winter paddler when i was younger so had a dry suit. On cold spring days, warm clothes under the dry suit allowed me to be in water up to my neck more comfortably than my helper who had a wet suit.
I use my Goretex waders to put in the waterline; they are much more comfortable that neoprene waders. More expensive, but as I am an avid river fisherman, they get more than enough use to justify the expense. The problem with waders when putting in the dock (now my son's problem!) is that where we are, the high water in the spring means waders aren't enough. |
I was really thinking about a drysuit but they are so expensive. I guess it comes down to either me paying someone to do it or get the drysuit it might pay for itself in 3-4 years
I have never liked drysuits, most of my friends swear by them but I have always had them leak etc. I purchased a 7mm wetsuit and you can do 4 docks easy before you even think about being cold. Heck I even ocean surf with it all winter!
www.mythicdrysuits.com, located in Maine, has excellent dry suits which are probably made in China(?), starting at $329 ..... I have one .... need to go get into it and get my dock done .... and stop with the yard work .... already. Is a myth that they are made in Maine, but so what .... they are made in China ..... and sold from Maine .... or something.
Walmart in Plymouth has these large air mattresses, made for camping or something, made by Intex, in their mark down aisle close to the greeting cards .... selling for $9.00 .... and they look like it could easily float a dock section .... you can probably stand up on the floating dock and paddle it all the way to Weirs Beach to go visit The Dive .... which apparently has left the dock area ..... but I digress here .... oops? Hellooooo out there ...... calling The Dive ...... where r u? ...... I need a drink ..... real bad! ..... in order to properly install the dock ..... a good drink always helps with this antique dock installation .... for correct alignment! Oh well ..... before the Chinese tariffs took effect, you could buy one for $229 .... what I paid ..... but is now $329 ..... so sorry and too bad. |
| All times are GMT -4. The time now is 12:55 AM. |
