Toilet leak.. HELP!
I noticed a water stain in my kitchen ceiling recently, but today has spread.
Directly above the ceiling is a bathroom. I noticed that to the back of the toilet the floor tile is stained and damp, but not wet. I suspect the toilet wax gasket is the culprit. No hoses are leaking and the tile floor itself is dry. I've replace dozens of toilets over the years, and always replaced wax gasket ring with new. Current toilet is original 20 yrs old, standard type bathroom version, nothing fancy. If it is the wax gasket ring, should I replace with 'standard' ring or 'jumbo' ring? What are the recommendations for use of each type? FYI, having a plumber coming onsite to evaluate, but I may do the job myself, since I'm familiar with the process. Still TBD, if he can do the job quick & reasonable the job is his ! Thanks for your feedback. |
I had a toilet that was always leaking because the floor was uneven and no matter what I tried the bowl rocked a little and broke the seal. I eventually re-tiled the floor but in the meantime I used one of these rubber seals and it held for a number of years.
http://www.supplyhouse.com/Sani-Seal...SABEgKJ3fD_BwE similar type used in RVs, because of the movement |
washers
Check the rubber washers around the bolts that bolt the tank to the seat. I've seen leaks there when even a professional plumber miss it! Simple fix. Turn off the water supply, drain the tank, unscrew the bolts and replace the gaskets. They have a kit that includes new nuts and bolts as well as gaskets.
if gasket
go with jumbo always also the flange itself could be rotted out |
OK, Wax ring or Waxless ? Pros & Cons ? (specific to my issue) |
I had a plumber come by a couple months ago for a similar situation, a leak in the basement that was coming from the bathroom upstairs. It turned out to be a toilet leak. $80 including parts. Well worth it to know it was fixed and fixed right.
and as mentioned above. check for an upper tank leak first. |
I tried to use a waxless this summer. It was in two pieces. A ring and a spacer. The ring alone was not thick enough and with the spacer it was to thick. The options were to little or two much, so I went back to a wax seal.
If your bothering to have a plumber come out just have them fix it. :confused:
I'm guessing you'll need to replace more than a wax ring. Often, by the time you set water, the problem has been going on for some time, resulting in rotted flooring. I wouldn't be surprised if, once you remove the toilet, you see more work is needed to repair the area around the base.
JMHO Dave Sent from my SM-T580 using Winnipesaukee Forum mobile app |
seriously?
call a professional
I bought this to fix a bad toilet installation by a plumber. After many years of adding bigger wax rings, etc. I decided to try this product. Well, it is OUTSTANDING. Works terrific. Took about 15 minutes to fix the toilet...wobbled, leaked, etc. Problem 100% solved. I am sold on it !!!
OATEY 43400 Set-Rite Toilet Flange Extension Kit, 1/4" - 1-5/8", Red, Yellow Check out this video....explains everything ! Set-Rite Toilet Flange Extender Installation - YouTube Video for OATEY 43400 Set-Rite Toilet Flange Extension Kit, 1/4" - 1-5/8", Red, Yellow▶ 5:17 <iframe width="560" height="315" src="https://www.youtube.com/embed/5hutLTIsm8o" frameborder="0" gesture="media" allowfullscreen></iframe> https://www.youtube.com/watch?v=5hutLTIsm8o |
1 Attachment(s)
If you have a rocking toilet because of an uneven floor, its easy to fix. I would put a new wax ring and use these wedges. I tiled my first floor many moons ago in a bathroom and I found out I needed more practice. It was uneven. These wedges worked great and are hidden after caulking.
Toilet Replacement
About four years ago I replaced an old, low-sitting, 5 gal. flusher with a higher-sitting 1.6 gal. flusher. When I got it apart, things looked pretty clean, all things considered. The problem that arose was that the metal ring (that holds the bolts) had a 5 inch id., which was needed to fit over the pipe. I couldn't find a replacement as it seemed everything available is 4 inch id. As gross as it may sound, the old metal ring was barely rusted, and barely bent. I straightened it out, thoroughly cleaned it, and gave it several coats of Rustoleum primer and finish paint.
Has anyone come across this problem? Believe me, I reused the original ring, because NO ONE could sell me one like it! |
I had a problem with a leaking flush once and the flange needed repair. Fortunately my plumber was able to do the trick. He heated up some lead in his truck and made the repair, saying that the young plumbers would not know how to do the job. He was a good find. Got him when I renovated a bathroom and needed a plumber to do the installation of the new sink, flush and shower. Also saved me much money. All the plumbers I called wanted $800 for each fixture.
| All times are GMT -4. The time now is 11:11 AM. |
