winterize my mooring
Getting ready to pull my Mooring for the season, Last year I tied a 3 gallon jug to chain and sunk couple of feet below surface,worked real well except had a difficult time finding it in spring, maybe to deep, is anyone doing anything different .
Rather than tying off to the shoreline, I sink mine near the shore in a area where I can reach it with an iron rake in the spring. This way it stays below the ice and doesn't get caught or cut. |
Tying rope to dock sounds like best idea, I can get a rope that sinks as my mooring is about 150 feet away from dock. thanks for info.
One word of advice...I used to tie the chain off to the shore with rope, until one year, when trying to pull the rope in the spring I discovered a big sunken tree had settled right on top of the rope...was a nitemare trying to get it off.
Sent from my SAMSUNG-SM-G930A using Winnipesaukee Forum mobile app |
1 Attachment(s)
I guess I overdid it a bit last year but I bought a couple of Jim Buoy winter spar buoys. I got one to mark my mooring anchor and one to mark the raft anchor. They are tapered starting at a 6" diameter and 36" long. The taper is there so that when the ice moves, the bouy will just pull through and go under the ice. That's exactly what happened last winter to one of them and it worked as advertised with no damage to it. I did also use it once as a mooring when I had removed the regular mooring ball earlier in the fall. If I remember correctly, it cost around $60.
1 Attachment(s)
One Blue, One Red...
1 Attachment(s)
| All times are GMT -4. The time now is 10:44 PM. |
