Pump out stations?
Hi all, we pulled our boat out of the water this past weekend and, prior to doing that, visited both Fay's and Shep Brown's to try and pumpout our boat. Appears they are both shut down, not sure if this is a lakewide issue or we just had bad luck. This is the latest we've had our boat in the water!
Can anyone recommend where we could go to use a pumpout station now that our boat is on the trailer? Thanks in advance. |
Try an RV dealer. I don't know if the fittings are compatible but you will have to probably need to bring your own, and likely a pump.
Good luck! |
I made a few calls and it looks like Mountanview Yacht Club still has their station working and it's accessible to boat on trailer. Husband taking care of this week before we winterize and wrap it! The nice fall weather was certainly a double-edge sword this fall!
Try West Alton, they are usually wrapping boats this time of year, and they have a long pump out hose that should reach your trailer
Gas dock is closed. Not sure you can get close to the dock due to boats on jacks in the area. Call 875-7788
Sent from my GT-P5210 using Tapatalk |
We took care of it at Mountainview, but thanks all for the recommendation. It was easy in/easy out with the boat on the trailer today!
| All times are GMT -4. The time now is 08:06 AM. |
