Hull number
Anyone know where to find the hull number on a Yamaha Jetski?
But if it was sold as a unit or one boat then the best guess is that the one boat has one serial number. But let others chime in. |
I'm fairly certain that by law it has to be starboard of center and facing aft (unless the stern is pointed like a canoe) on the rear of the boat, and no more than 2 inches below the gunwale. It also has to be somewhere else on the boat in a less obvious place.
I'll check mine when I get home.
Just found this: Its on the outside of the ski at the left rear of the hull on the side below the bumper. reply: Its on the right rear corner of the ski, take a knee and look up behind the sponson on the right side |
Check the back right side of the rear deck. If you were sitting on the back of the seat look down and over to the right rear.
http://www.yamaha-motor.com/assets/s..._Shos_1527.pdf |
Going crazy
Last year I was searching for the vin on my used seadoo. I searched online, called dasilva, and stared at my seadoo forever with no luck until I stumbled upon it. . As you face forward there was an inconspicuous black rubber patch with a faint etching of the vin in it on the edge of the right rear flat platform. I took wax paper and a crayon and rubbed it to etch the number. Registering it MA didn't matter. They could've cared less.
It was a Dummy Crane moment. DC |
| All times are GMT -4. The time now is 05:19 PM. |
