-   -   Row Boats and Lighting (https://www.winnipesaukee.com/forums/showthread.php?t=20684)
dpg 05-31-2016 08:40 AM
Got a question and well I'm just to lazy to try to find the answer, everyone here knows EVERYTHING! Does a small aluminum row boat with a tiny outboard on it need any "lighting" after dark?? Wondering if there's a size limit or what the rules are about lighting. Thanks!!
Dave R 05-31-2016 08:54 AM
If it has a motor, it needs bow lights (red and green) and an all around white light
Slickcraft 05-31-2016 09:05 AM
See page 8:
https://www.boat-ed.com/abc/abc_spec...dfs/nh_law.pdf
fatlazyless 06-02-2016 08:08 AM
Believe that starting 30-minutes before sunset, a rowboat without a motor, is required to have a white light visible for 360-degrees.
So, if you use a rowboat or kayak or canoe that is rowed or paddled that doesn't have an electric or gasoline motor, something like a five dollar, battery powered lantern with a white light positioned appropriately is required......and common sense tells you that a 24' boat moving at 30-mph with a gps navigation screen in the dark will probably not see your small paddle or rowboat with the small white light. A personal injury situation that may likely become a 'hit & run.'
Dave R 06-02-2016 08:20 AM
It's actually sunset to sunrise. 30 minutes is for cars if memory serves.
chipj29 06-02-2016 08:44 AM
Seriously? What makes it likely that it would be a hit and run?
thinkxingu 06-02-2016 11:07 AM
I read it as the cruising boat might not realize it hit/swamped the rowboat and, thence, be called a "hit and run" (hence the quotes).
Slickcraft 06-02-2016 11:16 AM
Correct, link to law in post #3
laketrout 06-03-2016 01:57 PM
To me its just common sense. Go to West Marine, Amazon etc or your local store and buy an Led light with a small pole and clamp its worth the $20 and might just let a power boater etc.. see you at night. I carry extra light poles on my power boat one is battery powered.
